Open Air blow off?
LincolnMKS15
See that people disconnect the blow offs to vent to atmosphere.  Does this do anything other than make more noise?  Any performance gains with the stock turbos?
Never mind.  After checking some other forums think I found the answer.  Recirculate = more pressure when you let off the throttle which helps keep turbos spooled up.  Think I will leave as is in stock configuration.
