P.Package traction control.
If anyone with a 13+ wants to play around with this it will entail running an additional wire to the instrument cluster (position 18 if I remember right).  When the vehicle is programmed for Perf. Package a ground signal to this changes the TSC/ESP status.  If you are willing to tear it apart and have access to change the build data I am in for helping you out.
If you have a 10-12 and want to try to add it I believe its just build programming data so if you have access to playing with that can work on it together as well.
Just hit me up.
Just hit me up.
Pardon my ignorance, but when you say Build Programming Data are you speaking of utilizing  IDS, SCT, or something different needed to modify the code?
Thanks!!
Nevermind, looked up some older posts you had running concerning the Advanced Stability Control.. I wonder if similar changes can be made using a different platform to modify the ecu....
