tlundjr said:
Can there be codes when there isn't a CEL? I did have to have the fuel pump replaced already. Could that have something to do with it? Could it be because when its tuned it is requiring more fuel coming from the injectors, which is causing the issue?? Is the injector cleaner from autozone even worth trying?
Yes, there can be codes that do not set a CEL.
The fuel pump replacement was for the NoStart condition?
Yes, tuning will place heavier demands on the injectors (at heavy throttle), which will reveal weaknesses that would otherwise be well concealed when stock. Couldn't hurt to run some Techron or BG 44K through the gas tank, but be prepared to replace injector(s) if there is indeed a problem.
Pull the codes with the tuning device, see what it tells you. Do a datalog. Then try cleaning the MAP sensors with MAF cleaner, and datalog again. That would be a nice, simple fix
