Picked up a Tremor, lots of fun going to be happening soon
Sail pod ready for paint and custom mesh grill
Custom trim rings in silver to match the AC vents. Dash mounted JBL DSP controller and the new volt and boost gauges flush mounted in the dash holes.
All that custom equipment and you’re running a ms-8?
Why no mosconi,  helix or hell even a Dayton dsp-408.
I’m running a ms-8 in my sho but it’s limited on what it can do.
I'm waiting for the Audio Frog one to come out, until then this is still one of the best DSP out there
Yeah the auto tune is pretty good. But having to rerun the calibration just to change crossover slopes is a major PIA.
All the tricks and ways you have to fool it to tune right are very cumbersome.
It'll work for now :)
Time for some more suspension work...
Viking Performance, Inc. coilovers and double adjustable shocks and Inez Hotrods adjustable upper control arms are on the way to go with the Maxtrac Suspension 2" dropped spindles and Billet Pro Shop coilover mounts! Here's to a lowered truck that rides as good as it looks. #supersuspension
OK did some more testing today 3 C and 6 R on the rears are awesome, I do need to have new shock mounts made as the shocks bottom out right now, easy fix just some new tabs. Also going to order a bar for a custom sway bar this week so I can get that installed at the same time. Might even look into a panhard bar to help keep the rear located under cornering. I'm looking forward to the new front suspension, no more steering rack bind on LCA would be nice!
Had to get a little more aggressive with cutting and rolling so I can stop cutting the sidewalls. Bats, bars, saws and bags, every mm needed. I even had the wheels shaved 5mm in the pad for +35 offset.
