PIR race day #2, trying again to get into a 12..
What was your MPH? You have a boost leak, or something else is wrong. My flex just east of you ran a 14.4, stock. I hot lap my flex in hotter weather than PIR, and I've never seen that much of a deviation in what your time should be or lack of power. Did you have your hood up in the staging lanes? I hope you did not get bad gas before going to the track.
1st run was 103mph..
After that slower and slower and slower and hotter and hotter.. it was 95f at PIR, the lanes were warmer.
it was just pure heat issues. on the way home it felt fine once the IAT2 was under 100 and the power picked right back up.
i did a test run of the current tune build the day before and it was within normal (12.98 to 105mph) with a IAT of 90..
This car just can't run hot.  :(    it dropped my 60ft to 2.1+ on a few runs, where i was getting 1.9x on the previous trip a few weeks ealier.
if it had not been for the previous trip where i ran 13.09 and 13.1 all evening (60ish-degrees out) i would agree that there might be a mechanical issue.  but i also have datalogs with 12.66,  12.7x, 12.8x and 12.9x runs to 105mph so i know the boost is fine.  knock was not bad either....  it is pure spark loss from heat.
sigh
i will do a datalog sometime later with cool IAT's .. just to check that it is still putting out in normal circumstances.
slips attached
How important is this splash shield?  are other drag-racers pulling it off on race day ??
I can now understand why these engines do not cool off at all.  that splash shield covers the full engine bay, not just part of the block.
and the rock pelted air conditioning condenser cant be helping air flow much either.
so disappointed.
OK.....
I looked at your logs... I cannot see anything wrong with your logs... they all look very clean... HOWEVER... this is what I can notice...
-Your IAT's were through the roof... 170+ which will cause the ECU to pull quite a bit of spark...
-DA for the track that day was 1600+ at 3pm but was down to 1000+ by 9:50pm.. this directly effects E/Ts... ask the guys in Arizona and Denver...
-Your "Heavy" brake boost was launching at ~1600rpms... most guys get best results at launching around ~2000rpms..
-You shouldn't need to brake boost for 25+ seconds... it appears you were holding it for a very long time.. small turbos.. spool almost instantly..
-When you switched tunes at the track, your Octane Adjust Ratio dropped went to 0... what the means, is the ECU was not adding ANY additional spark to take advantage of the 93 octane... it takes a small amount of driving around to get your OAR to -1 (or -.96 if using SCTx4) which lets the ECU add a BUNCH more spark which makes a large difference...
Between the IATs, DA, Temp, the low launch RPMS, and switching up your tune without allowing the ECU to adjust to it... I am not surprised at your times..
lamrith said:
Well log #4 just a quick skim.  I can't reall offer any solution and am new at this myself but a few things caught my attention..
Your IAT never got under 143*, so that will kill spark from what AJP has told us, end of run it was over 150.
You started getting KR at top of 2nd and carried thru rest of the run, topping out @ 3.
I did the math and you 0-60 was 6.19sec.  Were you spinning tires?  was TC off, or was it kicking in?  This is slow 0-60 given your mods and dyno results, almost a second slower than the SHO is rated at in stock trim which makes me wonder about traction or nannies being involved.
Going to skim the 1st run logs now.
There is no KR in any of his runs... the NEGATIVE NUMBERS ARE GOOD.. it means it trying to add more spark... POSITIVE NUMBERS ARE BAD... that means the knock sensor is pulling timing since its picking up knock conditions...
StealBlueSho said:
OK.....
Between the IATs, DA, the low launch RPMS, and switching up your tune without allowing the ECU to adjust to it... I am not surprised at your times..
Yeah, heat was the issue all night.  the 1st runs were all on the same tune and it was still very low.
i think though i might disagree on the hard 2k launches.  I have determined with datlogs the fastest times i make to 105mph were with 1200-1500 launches.  if i launch at 2k my times drop to 13.5... if i launch low i get much better times to 105mph.
heck my best time last night was with no launch at all winning versus a track prepped wrx (std not sti).
i think it is the inability to loose heat.
it pisses me off quite a bit that this package is so ####ing air tight bundled up.
i really think i should not have to go to spray to make good times. i have seen others make great times without it and im frustrated.
and only getting to run 7-8 times in 5+ hours really is not racing.
man im pissed at this situation.  1st world issues .. :P
yeah i saw that.. then i saw the spark advance was WAY lower than i am used to.  in my best runs on datalogs it held 15.x and 16.x AVERAGE from start to end of runs.  this is when i also found launching low was better for *this* specific car.
i clearly did not do enough research on this platform.    i am going to need spray if i ever plan on summer drag racing.
pisses me off.
ok signing off ..  going to coast.  i'm getting to worked up and need to check myself :)
i will check back and see if anyone thinks removing the splash shield is stupid ..
yeah i saw that.. then i saw the spark advance was WAY lower than i am used to.  in my best runs on datalogs it held 15.x and 16.x AVERAGE from start to ed of runs.  this is whan i also found launching low was better for *this* specific car.
Spark advance was lower due to IAT heat compensation... then you compounded the problem by reflashing...
My best 0-60s are always around 1900 rpm launches...
Ahhh  Thanks for the clarification!
Ok,  I am far from a professional drag racer but I have run a good many times in the past couple of years.  I have run in much higher DA than I am seeing here and also in hotter temps and humidity.
Other than the first time I was ever on the track, my MKS was consistently in the 12.6. - 12.8 range.  I always removed the engine cover but NEVER the bottom aero-shield.  I typically brake torqued to around 1800 and probably for no longer than around 3 seconds.  I usually pulled the hood release at the turn around and drove back to the pits with it cracked open.
I can't explain the results wildly fluctuating results Tophersho is experiencing but never found heat to make as much difference as he is seeing.
He was trying different stuff... brake boosting at different RPMs, no brake boosting, switching tunes..
Explains the wild variations..
pisses me off.
Learning curve sometimes is all.  Some compounding issues lastnight is all.  It does make for a frustrating evening.  I like your solution to hit the coast, and enjoy the weekend!!
My car did not come with the splash shield, once my car is up to temp standing or moving it is sitting in the 130*+ range whether moving or not.  So you numbers are not outside the norm.  Ford did us no favors with how they layed-out out the AC/HE/Radiator.  The HE should really be out in front of the other two not between them.
Also realize even with temp issues, we get to enjoy our cars year round.  GIven where we live, similar performing summer cars cannot do that 7-8months a year!
I only was able to skim a log last night. But Steal blue Sho has a solid grasp on reading logs and I generally agree with his assessments.
I have never seen IAT2's as hot as yours...Over 170 and even at the start of the run I think it was near 150.
I saw ambient at 104? Was it really that hot?...I don't know much about DA's but in a stock tune the IAT compensations will start to pull about 1 degree of spark for every 10 degrees over 100 for IAT2 so at 175 the ECU will pull 7.5 degrees of spark as a pre-emptive measure to prevent preignition and so the knock sensors don't have to pull the spark....Hot IAT's alone don't make KR but it will if the compensations aren't there.
My IAT comps are a little more aggressive at high temps than stock..So that's also why you saw the knock sensors adding spark...The comps pull a little more spark out then the knock sensors are happy and add it back it...I'd rather do that than the opposite..When the knock sensors pull then tend to be more forceful.
And like SBS mentioned the OAR hadn't settled so that's the other reason the knock sensors were adding but they probably weren't adding enough to get you back to normal spark levels because there are rate limits at how quickly the spark gets added in and how much so a 1/4 mile blast may only be long enough to add a few degrees during the run.
ANd the OAR value get's translated to a multiplier then that is applied to a table  which is how the spark is scaled based on fuel octane.
So the heat from IAT's and ambient not allowing the motor to cool just made for a hot motor....It's why meth and E85 are so effective...The E85 mix just will handle spark better even when hot and the meth does both, handles the spark when hot due to octane increase and cools the charge also which will command more spark from the ECU due to less IAT comps.
Jim bell from Kenne bell superchargers has some good literature on the effects of spark timing and power..I could see you easily being 50 hp or more down from the spark you were at.
Although give the power you made on a mustang dyno I still would've guessed a little better...Even when you ran in cooler temps I thought you would've been easily in the 12's.....Glockcoma's car only has a 2 bar tune from me and ran high 12's but I don't know the conditions.
There aren't really too many ways to manipulate power....Boost and spark....You are running typical boost and better than average spark so the power is there when the spark is there.
And I think it's always better to brake boost..If you can get the 60' time down then ET will come down...I know you spent some time testing but I wonder somehow if things got skewed and different conditions made it not apples to apples
You were measuring speed being lower at the 1/4 in your logs I think and your 0-60mph was faster though which I think makes sense
When you drag race often you will see when the 60' times improve and your 1/4 mile ET is better but  your trap speed is often lower than runs  than runs that had a slower ET
Basically you get down the track faster so the car doesn't have time to hit higher speeds.
Sigh..
Yeah the temp was 95+ according to the track.. but my dash showed 101 in the lanes.
With the established rev-15 tune I tried all three launches. No-boost, light boost and tried high but missed it.
No boost was best on that tune at that time.  I know that 60' is holy grail but every time I launch hard my times suffer ..
I did myself no favors switching tunes, but the night was shot :p  and I wanted to tinker since serious racing was out the window.
As too the iat2 temp.. where is the sensor?  I removed the front rubber hood  strips both upper lower and rear in a attempt to get more air flow.. am I screwing myself with air flow?  I can get 170f in my driveway on iat2
Swapping back to rev-11 the 'magic' tune e dropped 500ms off the time in the last race I forgot to log..
The 1st three were all revision 15.. so it just sucked and was hot
Thinking back to the mustang dyno, he tried 2 times in 5th to make a run.. so it may be another example of my car hating heat..
I'm not sure what to do now..  :( ....  Meth was never a consideration.  Not cash ready for it.  I had searched and read so many posts on getting high 12's on just a tune and plugs with a 3 bar for better tuning... Like a lot of people thought this was a slam dunk .. but that is 'so me' to find the exception to the rule :p.
I can't pump my own gas, so blends are a super big pain, so that leaves meth.
Sigh.  I did not want to do meth :(
TopherSho said:
Sigh..
No one WANTS to do meth...but peer pressure and all...
The IAT2 sensor is part of the 3BAR sensor on top of the intake manifold...
TopherSho said:
Sigh..
I did myself no favors switching tunes, but the night was shot   and I wanted to tinker since serious racing was out the window.
I completely understand your frustration and would probably be similar.
Your IAT seem to fall inline with what I see from my car in these warmer temps, driving around town I see 130-150*.
Honestly, with temps around 90, evening racing PIR was just about the worst place for a car like ours.  PIR is acres of black pavement with zero shade. Warm Ambient temps, nonstop all day sun, pavement temp I am betting was in excess of 140*.  For example it is only 82* in Tacoma today, but my driveway is @ 136.3*.  Hot car after driving to track means it is probably already over 100* IAT.  Then it sits over 140* pavement as well as up against 180*+ radiator so the heatsoak is in full form.  Now add WOT runs, it is just going to keep climbing.  Popped hood alone will just not help as the car has pavement radiating 140* up form underneath.  I don't even think having a fan running on it would help, given the temps involved and the lack off offset to bring them down.  Just lot of temp issues stacking up that hurt you.
Changing the tune (I understand why you did it) just compounded it.  I am betting if you had left the tune alone the times would have dropped as temps did in the evening.
I am debating the E85 vs Meth thing myself.  While I can pump my own fuel, there is no E85 available locally.  Meth I worry about running out of during a run.  That said I do not think you have to have it to run 12's, just need to have conditions better suited to our cars.
Has anyone looked at installing something like a Killer Chiller in a SHO?
Hey topher, do your stations have corn and 93 on the same pump? If so I don't see why pumping gas would be difficult for any attendant as long as you tell them how much to put in. I know there are those with serious ocd about their blend but my goal is to get close, fuel trims can handle the rest.
Hhmm i wonder who....ive never understood why addicts and people with mental conditions are unable to identify their problems lol
