TopherSho said:stealbluesho said:Could it be a byproduct of spraying too much?
**If** my test drive goes well today, and i feel it is fixed I will tell you in another 3 months after hooking the meth back up and enabling it.
EDIT:: Luckily it seems the front three plugs are better indicators. So that's an easy 10 minutes to peep and look.
What is really busting my balls is **IF** this fixes the last issue, is that resetting the ECU temporally fixes the spark issue.
It must be a learning thing AFTER the fact because i made damn sure OAR was .96 yet for the 1st couple power cycles it felt almost normal with only a 20% flutter at the end of 3rd.
but we are still on a hopefull **IF** .. so, t-minus 2 hours to test drive where i can run into 4th under load.
