Colorado-SHOBro said:any oil consumption issues?
-0- holds the same OIL level on the stick for the entire time in the block. it only has 51k miles on it.
stealbluesho said:Silly website but all of them(them being sites) agree when your plug is carbon fouled...
http://www.dummies.com/home-garden/car-repair/how-to-assess-trouble-by-checking-your-spark-plugs/
Carbon-fouled plug Black, dry, fluffy soot on insulator tip and electrodes. Overly rich fuel/air mixture, dirty air filter, too much
driving at low speeds, or idling for a long time. Switch to “hotter” plug. (The higher the plug number,
the hotter the plug.)
stealbluesho said:When is the last time you cleaned your air filter? Might be worth while to check if its clogged...
FYI: Once plugs are in... you should never need to adjust them.. Gap them right the first time...
Colorado-SHOBro said:so you just re-gapped your existing plugs? happen to measure them before you reduced the gap?
stealbluesho said:They look wet?
AJP turbo said:Did you take a pic how the other 3 looked?
stealbluesho said:Could it be a byproduct of spraying too much?
