Gofspar said:welp I think my RDU or my PTU is starting to give up, if I bake boost once I hit around peak power at 4000rpm I get a violent shake from either behind me or right under me.
Does anyone have documentation on swapping out a PTU?
SM105K said:Gofspar said:welp I think my RDU or my PTU is starting to give up, if I bake boost once I hit around peak power at 4000rpm I get a violent shake from either behind me or right under me.
Is your PTU whining?
Also, it could be transmission shudder or even wheel hop since you say it happens around peak power. If you want, I can give you a second opinion because I am local.
The stock trans mounts are garbage as well.
Gofspar said:Also it's extra bad if I go around a corner and apply some heavy throttle. All symptoms began after that hard launch on that cold night.
TopherSho said:Gofspar said:Also it's extra bad if I go around a corner and apply some heavy throttle. All symptoms began after that hard launch on that cold night.
Ouchie, unless you have changed the TQ converter 4000rpm is too high of a launch rpm on OEM converter\tranny. Mine wont even launch @ 3000 rpm, it disengages, slips, feels like it looses power, hits the rev limiter ... re-engages with a loud BAM! and then the tranny goes into some weird mode where the RDU is the only drive pushing the car and the tranny wont select a gear until it reboots.
Also check your tranny fluid level .. many stronger builds here on the forums wont hook up in 1st or on downshift until you add extra fluid above the hash.
