Possible OBDLink MX Issue?
Bigjht
I have been using the Scantool OBDLink MX and Torque Pro on a Nexus 7 Tablet for a couple of months in my truck with good success and virtually no issues.  A few weeks ago though, I got in to my truck after dropping my daughter off at daycare, put it in reverse, and received a warning for Down Hill Descent Fault, which was immediately followed with the Service Advancetrac Soon message.  I wasn't immediately concerned as I have seen where many periodically get the Advancetrac message, I have seen it before as well, and it usually goes away after turning the vehicle off and back on.  The Down Hill Descent was a little weird considering my truck doesn't have that feature but I thought it was something with the Advancetrac error since it came on essentially at the same time.  My big concerns came shortly after though.  I pulled on to the street and got no more than 1/10th of a mile when I received a Low Oil Pressure alert, followed by a Service Engine Soon Message, and then the engine cut off completely.  Luckily I had enough momentum to pull in to a parking lot and I wasn't on a busy road.  I remember reading about the cheap OBD dongles possible causing issues or interference with a vehicle's computer so I immediately pulles the OBDLink MX out and proceeded to crank it back up with no issues and have seen no issues since then.  Has anyone heard of anything like this happening before or have any ideas about it?  My main question is which caused the issue; the tune, the OBDLink MX, Torque Pro sending interference via the OBDLink MX, or truly an issue with the truck?  I really don't think I truly lost oil pressure as the truck was running fine, no shudders or mis-fires and no issues since.  It seemed more like something interfered with the signal from the sensor, which caused the fail safe to kick in by turning the engine off.  I'm tempted to plug everything back in to see if it happens again but to be honest I don't want to find out the hard way while trying to pull out in traffic or any other situation that may cause an accident.  Sorry for the long post but I wanted to make sure I included everything.
I have only seen this with less expensive adapters but it does sound like it could be an issue with bad data on the CANBUS. It is certainly possible that you have a flaky MX...If you created any custom PIDs in Torque I would double check them. The good news is if this is the cause I don't believe it will hurt your vehicle...it is just very unsettling when it occurs.
I've been running my MX constantly plugged in for over a year and a half. I started with just boost and now if have dozens of gauges and several custom PID's. Never had a hiccup. I can see why you are worried. I have had the Nexus get funky and need a reboot but that has been the extent for me. Good luck finding the problem and please post what you learn.
I had a few weird events with mine. 1st was the parking lights flashed on their own. Second the car refused to start. Just cranked, both times I unplugged the MX. I no longer leave it plugged in when not in use.
It is possible one or more of the wheel speed sensors are going bad.  They feed into the transmission & brake control systems, so could have tripped the fault.
Purchased the OBD link mx a little while ago and trying to get familiar with it,looks cool on the phone with the torque app,tried it a few times very briefly and today i go in my car and plugged it in while driving i get a advance trac service soon in the dashboard,as soon as i unplug it the advance trac service soon goes away,what i hate the most is intermittent issues?? Changed wheel hubs and tsb washers a couple weeks ago,maybe thats related??
ZSHO, I've been using the MX and Torque Pro on Nexus 7 (for the Edge) for some time now, with no check lights.  I do however sometimes have missing data from the logs, such as O2 voltage data.  Don't know if it is same issue as yours.
Bluetooth is on a UHF frequency of 2.4 to 2.485 GHz, TPMS on a UHF frequency of 315 or 433 Mhz.  So doesn't seem like there would be interference there.  Maybe it draws enough power from the OBD port to interfere with the receiver, or the vehicle electronics are too sensitive?  Seems to be more of a 2013+ problem from the reports I have seen so far.
Only issue here is when having torque open on tablet when starting vehicle with obdlink hooked up...throws dash codes galore, turn off unhook, no problems.
What he said, you can leave the tablet or device on. Just close the app before you start the car. It's happened to me at the track. The whole dash lit up like a Christmas tree. Even got a low oil pressure. Gave me a freaking heart attack!
Haha...think I lost a few days of life expectancy also after this first scare
I would definitely recommend NOT plugging or unplugging the adapter when the car is on.  Communication errors may occur on the bus and the car (not to mention the owner) will probably not enjoy the experience. :)
Its not a guaranteed it will happen. Just not recommended...at least by me. I  used to have a cheap adapter and this would happen all the time to me...I would be driving around and the dash lights would literally freak out. Very disconcerting although the car performed fine the whole time. Hasn't happened since I switched to the MX but I suppose its still possible it could be causing everyone issues.
FoMoCoSHO said:
Weird, I never have any issues like that. Unplug one device, plug in another....no issues.
Me too!  I Leave mine plugged in all the time but also have had no issues unplugging the my tuner (MyCal) and plugging the MX in with the car running or not. It's never been squirrelly or fussy.
