Check the front wheels for any play while moving it side to side and check for any signs of leaks under the vehicle...
Did you happen to check for any Codes!
BTW It could be the Spline axle shaft your hearing! If that's the case need to make sure you get a set of updated (metal) thrust Washers. Z
