Random Pics o' The Day
nice pup & looks well behaved. changed the insulation on my airaid. never did like the rubber tubing that came with it. used split color water pipe insulation, sits up higher & actually looks better.
Nice job Mike...looks a little familiar
Rich
rich:
I knew somebody had done it before i just couldn't remember who. i'm not mechanical but good at stealing an idea & trying to work on it some. i didn't use your backing although i now remember why you did it. but did push the insulation as far as i could around the box, so everything but front opening has insulation on top of it. bet you can't wait to use your christmas present. expect some good vid coming from you!!!!
Had our minor snowfall today,as SHOnUup mentioned a while back regarding that our engines generate more heat twards the rear of the engine,it was putting that theory into perspective with snow.
Engine cover off also ?
Rich
Rich
That was actually with the cover on,and ten minutes of the car beung warmed up only,go figure!!!!
ZSHO said:
Rich
Pretty consistent heat dispersion then. Mine was off at the time I snapped a pic.
Rich
SHOnUup said:
ZSHO said:
Rich
Rich
Rich did you have your 160stat installed at the time?
ZSHO said:
SHOnUup said:
ZSHO said:
Rich
Rich
160* wasn't in at the time. It is now!
Rich
