wasinger3000
http://www.audizine.com/forum/showthread.php?t=618933
That's hot....
That's hot....
wasinger3000 said:http://www.audizine.com/forum/showthread.php?t=618933
That's hot....
That's a perfect storm for engine failure. Dyno oil on a cherry red turbo... I bet that oil lasts all of 1k miles. Do they all run that hot? I was considering an audi down the road but I don't want that kinda **** going on.PokerMunkee said:Those VW engines run so hot! I had a 02 Passat 1.8T that sludged up at 30K miles. I was the second owner, came off lease, so never had synthetic. Dealer replaced oil pump and other stuff under warranty. Then I chipped it and it still had major turbo lag. Traded it in for a new '06 GTO![]()
I'll check on Friday. I'll do a before and after temp with pictures.panther427 said:Has anyone checked to see how hot our turbos are after a run to say 140. I'm sure there is some color to them. I've never had a problem with an Audi Turbo motor using synthetic oil
With or without the engine cover?wasinger3000 said:I'll check on Friday. I'll do a before and after temp with pictures.
I'd prefer to do this once so I'll do it with the cover on for max heat.SHOdded said:With or without the engine cover?wasinger3000 said:I'll check on Friday. I'll do a before and after temp with pictures.
Wheelies....hahaSHOdded said:So now Torque can tell when you are doing a wheelie?
Hah. I was surprised how much of the power it actually puts to the rear on a lunch after watching it for awhile.SHOdded said:So now Torque can tell when you are doing a wheelie?
Yeah its just one click after the rpm gauge. I really like it. Just I wish it was like the edge where it shows each individual wheel. None the less it's cool to know what it's actually doing.PokerMunkee said:How does that work? Can you toggle it with the rpm/fuel screens?
Which dealer enabled it for you?
I'm jelly!
Here's a link to a thread of a guy who did this on his Explorer. Maybe he could give you some more insight on this if you can get in touch with himZSHO said:I apologize if this was mentioned in the past,anyone consider painting the bottom skirt the same color of the car,best of my knowledge they have to use a special flex-all paint made for plastic,rubber,plexiglass,to hold up better and give our cars a bolder and fuller appearance especially the side and rear skirt to make it look more color coordinated.
