It is 6700Auggie said:OK, my second question was "What is the max RPM of these engine"?
Auggie
FoMoCoSHO said:It is 6700Auggie said:OK, my second question was "What is the max RPM of these engine"?
Auggie
My SHO continued making power to about 6750... Goes a bit higher... The dynos are somewhere here in the thread about dyno for drown pipe install.... And that was before I tuned.AJP turbo said:FoMoCoSHO said:It is 6700Auggie said:OK, my second question was "What is the max RPM of these engine"?
Auggie
You mean they are capable or stock?..auggie you can make it what you want
It's not just power though, its power plus gear multiplication. PP has a deep 1st and second so even might be making less power, its still making more due to gearing than if you shifted.AJP turbo said:Bigmac im skeptical on the car still making power at that rpm...any chance there was a bad pickup on the rpm lead to the computer from the dyno?
And auggie the back pressure get so bad at high rpm i cant see much over 6200 being beneficial...watch wastegate duty cycle skyrocket to maintain boost at redline
Sport shouldnt be different...there is basically a pedal multiplier when in sport..thats alot of the reason shifts are held longer and downshifts sooner because you are actually deeper into the pedal...i leave it in S when i race...i think the paddles are stupid
FoMoCoSHO said:Yeah, I just looked at my last log for reference, a multi gear pull and I'm pretty sure you have it.
