Re: Cold start rattle!
Do you have the part numbers for those? If you need them let me know. Both of mine broke when I took off the bumper for the Alky install.
Total cost was $19 both both sides, and its one bolt holding them in. Super easy to replace.
My guess is they snapped when the LMS guys removed your front bumper and they didn’t notice. Although if they don’t clip in correct it doesn’t sit right... so not sure how they didn’t notice. And my guess is that is the only time your front clip has ever been removed.
Ok... like $16 a side... still not terrible.
Thanks there SBS! That's what i had.!!!
Its members like you and others who don't hesitate in lending a helping hand and contributing,its something i have been accustomed to throughout the years here @ E.B.P.F.  Z  :)
https://parts.levittownfordparts.com/oem-parts/ford-side-support-ag1z17c947b/?c=Zz1ib2R5JnM9YnVtcGVyLWFuZC1jb21wb25lbnRzLWZyb250Jmk9Sk4xMDAwNjUmcj1sYXllcl80JmE9Zm9yZCZvPXRhdXJ1cyZ5PTIwMTMmdD1zaG8mZT0zLTVsLXY2LWdhcw%3D%3D
Just banking my brownie point for when I really piss everyone off one day..
Are you planning on swapping them yourself? If so, I did it by poping out the plastic screws in wheel well and the bottom 8mm bolt.. it gave me enough room to pull the front clip away to swap out that part...
The single bolt is a 13mm IIRC which was odd as almost everything is 8 or 10 for mouldings...
If you run into issue please feel free to reach out! If you were closer I could just swing by and knock it out in 15min...
MANU your much to kind sir!  :)    I have an appt @ the Ford Dealer this week for re-alignment and will have them check it out, thanks. Z
Update I found the engine cover loose since having my DPM installed.
The engine cover does not sit flush on the engine due to the DPM being slightly higher on TOP of the manifold which makes it difficult to fully secure the cover and only the front two fastner's,insulators can be fully secured which IMO is causing the brief plastic rattle sound upon cold start up. Z
The bumper issue is my fault due to the lower skirt getting stuck on the curb . :banghead:
Such a purveyor of RED!  Even hitting a RED brick wall, LOL!  Yeah, the cover makes sense, I guess at least you can still have the cover kinda on, unlike with the hiflow HPFP.
MANU do you recall when i was able to remove the engine cover with EASE .Lol.  Z
Engine covers are way overrated for cosmetic beauty or was that noise abatement?  Wait is was heat retention wasn't it?
Sent from my SM-G950U using Tapatalk
Huh!!  ???  Due forgive my old age. Z
Never mind just my old age flareing up..
I guess it might be time for me to Hang it Up.  Z  :(
I guess it might be time to Hang it Up.  Z  :(
Lmao c'mon cut an old guy some slack
