SCT x4 Use and troubleshooting
FoMoCoSHO said:
So my device needs updated apparently but it told me I need to return to stock first?
Is that true?
Do I need to put the 2 bar back in or can I do this process without starting the car?
U don't have to put the 2 bar back in but don't start it...it's not essential to return to stock but highly recommended per sct ....if ur update fails there is potential u will not be able to recover the exact stock calibration that was programmed to ur car...u can always get a stock equivalent calibration but technically that's not the same as what ur stock tune was...I've updated mine without returning to stock because I figure I'll never need it..just a risk I guess
Hi Torrie, couple questions...
On the x4 knock pid is a negative number adding timing and positive pulling?
Also for us E guys, what is the minimum rail pressure you are comfortable with?
