Sealing Airaid Intake
It sounds like its behaving like OEM now which is awesome. After reading that intake test the only other thing you might want to consider is an extra source of fresh air from the wheel well.
And maybe a cone with an open end....
The cone with the open end sounds interesting, I would have to source the filter. The Airaid has an offset to the mount, unless someone else makes a replacement for it with a power stack opening like the S&B filters it may prove difficult.
FoMoCoSHO said:
Must...convert.....to fahrenheit....argh!
Is that graph in Torque?
You know.... pretty much the rest of the civilized world is metric right? :P
https://www.google.com/search?q=F+to+c+calculator
f-d%3Acde4f9bf6a0e0809d1f71535c31ac5aebc4e7898ea69b3d555c15f65%2BIMAGE%2BIMAGE.1
You asked for it! here is the Airaid with the stock weatherstripping, from the graph notice when I step on it IAT goes up, not down as the 1st graph. Just for clarification, note the labels for the graph from top to bottom.
Between 204 and 223 you can see a wot run from a stop. Look at what happens to the intake temp, it soars.
IAT2 by sho.boat, on Flickr
IAT1 Temp (At the air cleaner)
CAC Temp After the CAC before the TB
IAT2 in the intake manifold.
TP throttle position
VSS Speed in KM/H
Boost in kPa
From this graph pay notice to when I open the throttle, temp actually goes up. This is even when the car is at speed, so the majority of the air being drawn is from the engine bay. So there you have it, I would say that this is definitive that the Airaid is capable of drawing in cold air.  What a concept a CAI that draws in cooler air.
One last thing, you can see the exact opposite right around 283 in the first screen shot. The ambient today is less at 19C it had just rained.
SHOnUup said:
Cool stuff...you gonna test stock box also ?
Not any time soon, but when I head to the track I plan to run both intakes Stock vs Airaid) on the same night. Same process as the K&N vs the stock. I was looking at the logs from that night and it looks to me like the stock box takes a little longer than the Airaid to drop temp. Something that the guys at Airaid said. The Airaid filter enclosures are intentionally as large as possible. This could aid in this effect, but this is just speculation. I won't know for sure until I head to the track. But what I can say is I don't believe that the Airaid hurts performance. The same can't be said for the K&N typhoon. I don't want to come across hating on K&N here. I have had their products in many of my cars and trucks in the past, this one just doesn't work as advertised.
ShoBoat said:
Some great ideas! Short term I took the weather stripping off my K&N and put it on the Airaid . The K&N uses a flatter top design to it's weather stripping. Which allowed easier placement of the foam that I placed on top of that. I have to admit in person it doesn't look all that bad. I wish it was black however it was the only one I could find that expanded to 1 inch. This stuff is more like memory foam and is designed for high heat applications. One step at a time eh?
You care if I share this with some Facebook SHO owners as its looking like it helps. ..alot of people have these CAI with no idea
I will be happy to hate for you!
Well, the testing is complete. And there is a clear winner! I will be posting the detailed results on Saturday.
Oh what the heck I can't seem to get to sleep right now.
Gentlemen, the results are in! DA tonight was 1750. Not the best but just perfect for what I needed to do. So up till now the stock box was the best option for our cars. Well it is no more! Ran 3 runs with the Stock box and 4 with the modded Airaid. I made another improvement on the Airaid, but more on that later. Runs with the Stock box all 12.95 or Slower. Runs with the Modded Airaid, wait for it..... 12.70 to 12.83 baby! a good 2 tenths faster. for comparisons sake I took the 2 times with similar 60 foot times to prove the point.
Stock Airbox
60' 1.882
330 5.396
1/8 8.339
MPH 84.20
1000 10.860
1/4 12.990
MPH 107.62
Modded Airaid
60' 1.873
330 5.327
1/8 8.221
MPH 85.37
1000 10.732
1/4 12.803
MPH 110.48
And a personal best tonight of 12.703 @ 111 mph. with a 60 of 1.8 flat. At 0 or better DA it should go into the 12.5 with this setup.
With the butt dyno I was expecting it to be quicker, but not 2 tenths quicker. Data logging confirmed that the Airaid was able to recover quicker and had a lower IAT throughout the runs (almost ambient after 3 seconds). I also assume that there was less resistance and the cooler IAT resulted in boost being slightly lower with the Airaid then the stock box.
This is interesting as it is the complete opposite result to the K&N typhoon to the stock box test I did a few weeks ago. I now know what needs to be done to the Airaid and will post a how to in a separate thread. Ok now I am going to bed lol.
Stock Airbox
60' 1.882
330 5.396
1/8 8.339
MPH 84.20
1000 10.860
1/4 12.990
MPH 107.62
Modded Airaid
60' 1.873
330 5.327
1/8 8.221
MPH 85.37
1000 10.732
1/4 12.803
MPH 110.48
You are my hero!  DON'T LET AIRAID STEAL YOUR IDEA!
DIY + persistence = solid gold when it pays off, and it did in spades!  Nice work, ShoBoat!  You've earned your rest :thumb:
BTW, AutoAnything has a WTF coupon on again ...
