Seeking opinions
Look at how many foreign car manufacture company like the flower look, that they have a simulator look. I'm looking to get a close matching look for our Fusion, to match our SHO.
AJP turbo said:
255 40 20 and 255 45 20 are the same width....what are you talking about?
I'm sure you find it hard to believe, but I doubt you know everything.
according to 1010tires a 255 45 r20 can safely handle a max wheel width of 9.5 inches, while a 255 40r20 has a maximum of 10 inches.
a tech told me that aspect ratio becomes a concern with certain tire sizes, the taller the tire the narrower the effective 'safe' width.
Simply was asking what you were referring to when stating that 2 tires with the same section width of 255 millimeters were a different width. No biggie
Yes I'm aware that when a tire of the same width is mounted on a different width wheel then actual tire width will change after being mounted.
But...The tire's nominal width is the same....That's what the 255 is
I have the stock PP  flowers  with stock 255-45-20 tires. I want to run either 275-50-20 or 275-45-20 or 275-40-20 are any one combo possible on stock rim, same size front and back?
