Vortech347
16MagSport said:I really need to fix my Stang. Damper broke and wallowed the keyway on the crank. Need a new crank so I might do the entire rotating assembly and step it up to 363 cubes with more compression and run NA to last longer and not generate so much heat on the road course. I don't want to go too high though so the s-trim can go back on for the strip occasionally. I can add the Snow boost cooler I never installed. I also have AFR 195's and a Systemax intake to go on when I put it back together. I think those heads with the big bore will run really well NA. My Eddy's are too small to take advantage of the 4.125" bore.
That sucks about your crank!! Get your S-trim upgraded to the Si spec's while it's apart. It's cheap and showed 1-1.5psi more average and 15* cooler IAT's on the course without a pulley change (7" lower 3" upper) I'm running ported 6037's. When I do decide to take the bite on a Dart I'll do 363 like yourself and top with 11R heads. They are magical. Box in your radiator with sheet metal, it keeps mine at 190* on a 100* August day for a 25 minute session.
