BiGMaC said:Cool! Way to go. :thumb:
Does the hood shut without touching heat blanket?... & no vibration when the engine's running?
68_GT said:I noticed the oil blow by I'm getting in my upper intake when I put in my 3bar MAP.
I'd be in for one of these kits if there is a complete kit. I don't need anything show car worthy, just a plain jane one that works. Is that an option ?
Absolutely it's on the site just click the link in my sig68_GT said:I noticed the oil blow by I'm getting in my upper intake when I put in my 3bar MAP.
thatsmrgimp2u said:I either have a different bracket, or a different mounting point on the can itself. I for the life of me cannot get the can as low as yours. Ill be emailing RX soon to find a solution.
SwampRat said:
ShoBoat said:I wonder if there is a way to mount this in a cooler location? Like down low below the headlight or in front of the rad? Maybe with a remote release for the drain? I honestly believe that this is one of the reasons this unit (or any can) pulls so much gunk on the f150. But I guess we should wait for the results from you guys.
dalum said:ShoBoat said:I wonder if there is a way to mount this in a cooler location? Like down low below the headlight or in front of the rad? Maybe with a remote release for the drain? I honestly believe that this is one of the reasons this unit (or any can) pulls so much gunk on the f150. But I guess we should wait for the results from you guys.
I'm with you on this. On shop air compressor setups there is a minimum distance from the compressor to the drier so the air can cool back down and the water falls back out of the air. Putting this can in the coolest location possible should greatly increase its effectiveness.
