802SHO said:The SHO is looking top notch my friend! The overlays look better than I imagined for a copper badge! Etsy Designs does great work!
That cooler should improve your trans temps for sure. Looking forward to your results. You're hoping for about 20-25 degree cooler temps? I think that's a reasonable expectation.
SM105K said:802SHO said:The SHO is looking top notch my friend! The overlays look better than I imagined for a copper badge! Etsy Designs does great work!
Thanks dude. I dont know what to expect with the trans cooler honestly. If I can cruise at 85 in 105 -110 heat with trans temps in the 190's I would say I am winning. Only time and money will tell.
802SHO said:SM105K said:802SHO said:The SHO is looking top notch my friend! The overlays look better than I imagined for a copper badge! Etsy Designs does great work!
True dat and it's good the cooler mods go easier on the wallet than most other upgrades we do to these beasts. A cooler is anywhere from 50-200. The Super fancy pants ones are upwards of 300. Overall not too shabby
802SHO said:The 3m tape didn't hold? Usually that stuff is found being the "only" thing holding stuff on. 3m makes an adhesive primer called 3M 94 Primer. Might want to try that as well. I have some and if need be I will use it. Try to remove the tape completely. Prep with your 50/50 water/alcohol solution. Dip a Q tip in the primer, apply a small amount to where you will stick the tape. Allow to dry 5-10 min. It goes on and dries clear. Then add your fresh piece of 3m tape, apply firm pressure and then use a hair dryer or heat gun and apply more pressure. Apply the 94 Primer to the trim piece where the tape will stick, let dry and when you go to adhere the two...do the same thing, apply pressure without heat then with heat. Let cool. It shouldn't fricken move!
Forgive me if such thoughts and procedures are already in place or known just figured to walk through how I get things to stay in place. Btw that 8oz container will last your lifetime. So about $25 dollars for a lifetime supply lol
https://www.amazon.com/3M-Tape-Primer-94-Vinyl/dp/B005LDG7HQ
802SHO said:150+ mph passes that's legit. I've burried the needle once ....over 140 on a 65mph interstate is good enough for me lol I didn't try to tach it out as I had no idea how fast it was after 140. I just kept going a few more seconds after 140 and let off
SM105K said:802SHO said:150+ mph passes that's legit. I've burried the needle once ....over 140 on a 65mph interstate is good enough for me lol I didn't try to tach it out as I had no idea how fast it was after 140. I just kept going a few more seconds after 140 and let off
I had my SHO on GPS at 157 mph. That is all she would do in the current configuration. That was with a full tank, and my luggage. I was in a hurry to get home from CA at 2 am in the morning. I think with all the mods now, (including the DPs & tune revision) wheels, and quarter tank she will do 160+ mph. Not bad for a heavy pig. On a side note, the ST does 151 mph and actually runs out of gear in 6th. Lol.
802SHO said:SM105K said:802SHO said:150+ mph passes that's legit. I've burried the needle once ....over 140 on a 65mph interstate is good enough for me lol I didn't try to tach it out as I had no idea how fast it was after 140. I just kept going a few more seconds after 140 and let off
You're ripping! 2 am in the morning here going that fast you'd probably plaster a deer and that would suck. Gotta watch out for them over yonder lol
802SHO said:I would do the same thing then...see what my top speed is! I can't wait for you to do the cooler. I want to see an improvement there.
802SHO said:Come to the dark side young Skywalker .....endulge in METH! You too shall suffer from the unquenchable thirst for methonal
SM105K said:802SHO said:Come to the dark side young Skywalker .....endulge in METH! You too shall suffer from the unquenchable thirst for methonal
You are completely ridiculous. LOL. Meth will only be used to clean the valves.
