ecoboost_xsport Consolidated Build/Maintenance Thread
Oh Sh!t Moment - Incident 01
Ummm, so yeah....this happened today:
y4mdTgPghMHvOMDcNXnLrQML5NRJMm6Jfmdp1ZnbNT5bNSDWKZbkj-YGdqYPfOtkXoua7DGjiLsldEt8wgaqoE1Nkej2DHQUsaWbUbtmKqjxIzaln4gHAYSDEq8nkk0lKMOpI1F_hJVyq9_sPw_Kq6LEIVQlCbe01XTS8IF0oDFodKM9v_Oki_JsW8lJaUNyM61
Was out around doing some "spirited" driving as I was trying to get some miles on the e85 in order to stabilize the OAR before I get heavy into some datalogging.  I floored it and heard a loud 'POP'.  and lost all power.  Scared the crap outta me as I thought I really broke something, but when I slowly eased into the throttle I saw I wasn't building any boost at all.  Figured I blew a hose or cracked a pipe or something.  Luckily I was about 2 miles from the house.  Limped it home to find that hose had popped off.  It was on there tight, too, so I must've hit a boost spike (currently mildly set to 15psi for initial tuning).
Anyway, easy fix and I'm back on the road...I'm seeing Wiggins Clamps in my future...
y4mfW0yqUnpOXwODIKxOHbxGIhExhrvYKgKBPIOwB0CmXZZH-I2jm29WyI7fzS-ScXgsMk0lzu6q4vKc6dRBCR-ILwOF-4zcQ2z-_CDQgiw77-oTxOSc3UE6C51TIGy1ksem5-hmoiqfvpKsAmMZDiUT23T0sBWB3at_Gx9YMH39ToGJ5XTzFg8EyI9DDUz3j_3
I have to say.. out of all the issues this one is probably the safest! LOL..  The clamps in the picture have worked well for me, maybe tighten them a bit more? dunno
Yeah definitely glad it wasn't more serious or in a more crappy location. I was pretty sure it was on there tight, but idk...maybe I didn't crank on it. It's tight now for sure though, lol.
I don't see a lip on the flange, likely the unit has 'enough' lateral movement to allow it to slide off.  common issue really.  look into getting a stiff small crease outward on each side .. or have someone GOOD,  tac on a 2 or 3 inch bead on each side and file it down a bit..  give it some 'bite' to press into the connection hose/silicon.
Yeah, I guess it was bound to happen.  I seen folks weld a bead on the TB and weld on v-band flanges, etc.  My current setup is all temporary anyway until I get my IC and plumbing redone.  I'll be welding on a Wiggins-style clamp flange.  That'll solve that issue 100%.
Since that pipe is pretty short to the IC, it needs a bit play so when the engine moves.  Wiggins-style clamps for the win!
y4mjNwzrxW9vfi96NuaJWDDDPA5lmQRDovR_RXcGPu4EPEq-FvnTsRXZtf1ggJnjQ9ibXJ__A04bWwCEUlbOqA4unuNBJLz4OVD_fGKyg1MSZXzmx2KdqEUXJNtC1alunJlNBfsIodDhHjS6hGUNfJskawyUSuSt_PvOtLAirL3YLt94ZFzpS7Uy9YIK18vQOKQ
Wonder if we can get any of these throttle body adapters to work with the BBK 70mm TB:
https://plazmaman.com/product-category/plazmaclamps/
Would make it easy to use a Wiggins-style clamp without have to weld onto the TB...
HVAC Directional Door Actuator Replacement
So this was one of those things to fail that you just KNOW is going to be a pain in the ass.  Guess what? It is!
The actuator was stuck on defrost and I could never get it out of that position.  Did some research and found that they fail often.  Ford uses these in various places as well as in many of their platforms.  It's the newest version of the actuator and you can see in this video why it may not be the best improvement.  Yes, it's smaller...but made cheaper:
https://youtu.be/sQ2afrTj1xY
There are a number of actuators in the HVAC system in this vehicle.  One is located on the passenger side and it controls the blend of hot/cold temperature.  So if you're having that issue, it's likely you'll want to check out these videos for some help:
https://youtu.be/yYacz5dZgyc
https://youtu.be/Dl1O34pVE3Y
https://youtu.be/UqL1C4Lw8aM
The one that failed in my case was one of the worst ones to go as far as labor.  If you are having issues with the HVAC sticking between DEFROST, DASH or FLOOR setting, this is the one you need to replace.  This is something that, if taken to Ford will cost you $$$$.  Apparently, Ford needs to remove the ENTIRE dash to get to it...so yeah, lotta dough.
Anyway, did some research and found this:
https://youtu.be/LIDLq4jLZXE
I won't re-hash what I found in this video except give you a parts list and some tips I found to make it easier, but I will say this video saved me A TON of time and work.  Thank you so much to the creator!
This is one of those jobs where having the right tools will make or break your sanity.  As with all things mechanical, there is more than one way to skin the cat, but man, if you have the tools below, you will thank me later.
Anyway, some of the parts and tools needed for this job:
  • Actuator: Ford PN AA5Z-19E616-A
  • DeWalt Right Angle Attachment, Flex Shaft, 12-Inch (DWARAFS)
  • Magnetic Nut Driver Socket Set
  • 1/4" Cordless Impact Wrench
  • Long-reach upholstery removal tool
As for removing that red tab on the connector, it DOES NOT need to come all the way out as mentioned in the video, just pull it back a bit and it'll click out into place.  Then remove it as you would any connector by depressing the lock tab:
y4mPJwHzf0IqxJ9O2-VTBFcbm-1KaquGS0-lRkwtQ1gGubkt0WZGAMMB10oOVANxzSuA9UL52LVGJqxuMN1g0898jUy0v9QVwfpL0Rl2Nh9Nf-MtoDEmP9TnqGSjAhmEWay38RmrSpvlvn4lgpbpTB0pEfJ3rk79qyMKDGh_conFrUpDefWHUOEF0zSacUKQciZ
In the video, he removes the top 2 screws with that 90deg flex shaft and the bottom screw with a 3" extension on a ratchet.  I found that you can reach that bottom screw with the flex shaft very easy:
y4m5kJxRLmDN3R-yFERaEmpwQoKAjj_Uqze6fHnDE3cKp6_oWJyhH3jfFu4dUj9rYPPQQ-0OP5YQ5s_giIHXnrKWn9q-AX2aJgtZ-JJnlrDeHCpNP1PWa9FeP8KIkgQTribcZNE6NDtXPuXLmG2x5hE7LaLSvhZUW8wfvkncVQcdYlGRRwhHHpRa3oJuLZCAzA5
You want to use those nut driver sockets because they are slightly shorter than a socket adapter and socket.  There isn't much room and you need all the space you can.  It's great to have the magnetic ones as the screws just stick to it and you don't need tape or gum like the video posted suggested:
y4mbUeh11uzj5kYZ-WABD9pOW4cdTgzCx21jeamfY7SzvlDOYy3cY9yi7GiRl2VuYaNtcXzNhTKsNEbqsTQZn23vm5txP-OJT68ANA7vn3Km7oI0S5R0lwewi_Mx1-PUMcsm8ULVJSHU6vFC-DzuuW_fhc29QAGLqiYGPiG095PqSoP9sXR1jbSBtYbXwCkdBcb
y4my1qiMG0sFYeyjZvWaodeUuTBuqeKn0JWPBmKN6rnjr6tiyADU_NQ6ZqXP24apsRCeo_raFNzkEu_Hw86B1hi-4ZWzzjoQhd0i9Bn8vY7G8qyMgk8LfcWDLhnRM4yzWORX1XBGqLNj1KhehYoK-1yd4aQ4ElC21dZ2L6Nyn_TP6koEXtrA8kIYsn8p5cgRhrE
This pic is difficult to see what I'm talking about, but if you have everything removed as required, from underneath, look up toward the actuator and it's a straight shot with the flex 90.  In this pic it's about center in the photo:
y4mVnkzXgJb9xXDxua72vZ7_mJIMiJjM9fm2JHwDInT1rvD9GxnmGL6CEQwdx5i_Bu7AVdKNAcsFPrpEtnA4jNoJM9Ixd1gMBWpcUmqZATKctc2v-z0CNbE6jFFmRYMTO0nIhNYyGMVQOZ3cURKelYWuAm8szqSJG6r65KGdJ5KFbcSF-rTua3VLpqRkr2eEX0d
Now, with everything removed, it'll still be kind of stuck in there. There is hardly NO room to get that thing out as there is a large wire harness right up against it.  That's where the long-reach upholstery removal tool came in handy:
y4mkgmrhM9R4iGs5qAdYc2txcgrZmLBOyyEqHfaSY_j0f6MHYKmjiaOoFQVPHZH8fgh-tR_SVi17c5DSYNN-BPZUYGyoqpossR7EgDplmfdQXxPFzOLpBKQcZ71JJYPw-GCsA8n59HryluPuewKRSGAk6MVkPHuvy9khtng9ZyJ6n6hkuqaxdKII1FQtWFjCELA
I wedged it between and basically twisted the tool 90 degrees and it popped right out and fell straight to the floorboard:
y4mOt_3jVikM9u1EcdWZfLQ9TGIEUCeOZ2OGZfA25DxJvba5rkfwnwtB4NqSO6Pt0QqIKax1axCT15BdFOk4AD41RDKrHgUGdjG3u6W3iGT9Ib5jBTNz_f4ymREQl4wAw8stZ89Dq-43Zi0Go4WtpetQ6fc5frhwZBujDHSH3E9gb_Lv40FzVuwfzcus9vJHDyf
In this pic, you see the end of the tool and the white slot the actuator inserts into.  The actuator had already popped off in this photo, but you can get an idea of where to insert it:
y4mAK1gVW_32EfnrmZ1wnvC5nVxucOUkiCiEZHW_7Xnr0SgDOcWkCPcVMCcmvI1vxRMNl_f_qcBqrKQZ4sx315CPJX85g2odUmPD5iJqFVKgWXTtKA5_bCnb0QC23d3_-m9bYHVvcHzx0O_7Ktw0Yugy3qYNcN1r8av7Cx1Md3xa59rFeJKUMJlt7bucm1F7ggh
Here's the bad actuator and the arrows are not matching up:
y4mJjIuzFJeuWt62K6IUOhWxr2ZFGnf9GntNIsHXn_vIsqKyW7iooe0OOGtGEg8jdyKGABcShwbNkxRkWBbVrmlH7A8cNHlp-PU_kjDrarCv96V-_g3pOuiXo5EKded6BYhRuCljMl7mKT6XySQq8Zx3qJfjsODudgtdhtXAIDFtnXmyoaVd5i5Ppu1k3YRHNK6
Here's the new one with the arrows lined up:
y4mJQYYrnkt7sYpHj9hqWRzqB7wBNCbmysaDD3NR-ZHnEKaRRAI9_dwKj3qIlW40UFckZ3xyinESuj7wh_kEhs_zb1qLsfL4YsGYbGpMhoQnbN26zVt37xvibpXqn_abEUMm-9B6smWMzwLA3d5XhcQSH5ErbgQqrdDWlmnlaF1tFllgI-5XE2vkvu938vR6c-I
The video creator had a great idea taking the old one apart and using the plastic gear to get the slot to line up before inserting the new actuator. Just break the tabs off the outer shell it will come right out:
y4mEWE6k6xR4f0u_LBNJOdoOpkqR-0pXvYlfspurGLXbmKs_ZU6LI-oEodRQCwsUMU_mmMhCQ6QVRfge9-anjzrcfeTN6BQ74WdFLDeS4CfizE4p1DgYGFuthgehvLLn7xMeHDkbsXmaa3w9RXexJaZr0XoyWZz2xgb0oNc1fbo2E6mKhrWjY0yVTapIrrhFTwX
I found an easier solution than marking and finding where it needs to be clocked.  Just insert that gear back into the slot and turn it all the way clockwise (if you were to be looking at the gear from the exposed end and not the end inserted into the slot)gently until it stops.  It can't go further than the position it needs to be at.  I did that, inserted the actuator and the bolt holes lined up perfectly.
It will require finger acrobatics to get that thing up in there, so don't think this will be super easy.  You will likely scream at the wiring harness that's in the way a few times.  Stick with it, you'll get it.
As for putting the screws back in, this is where the magnetic sockets really shone.  For tightening though, I didn't use an impact wrench, I used a 1/4" hex socket handle and tightened it by hand:
y4mZR1KFdYk327jIHDr0Xjg-JhoSekX5ZKd0aHgULrwbf7daeIsQBqbqNXPV9Y_KS2glb0tujt0nrkpagXYUfG_Hm3S0szFC5xGCEXlFAFJPr9_erwyJ0v8gznCiE6YENnl0RK0sauJdsxJyedgDODrZQ1XF8zIYAqU67YBN80uW05_y5s_IWXeTloky-M5iNyg
y4mV-a-pop8Pvbih_hC2PfWIvBLZlpJv0KD8rFI_Bj6_t0aA0atvjfg75GA4-BGBOvo8pCtTaa1-ZYza93mduzaZiXdTjFEpYCflfFH6r6NTGpWLwAbSQKaB8z4Xp3TWvb8k63w5d9BZ293zc7H3qyacgxQIsM9efJm9yIto_xi0bu9aUfcfYzuyfhinVP4WSsW
Finally, getting that connector back into the socket.  That was, for some reason, the most difficult part of this job (it was ALL difficult, btw).  You can only fit one hand up there, so it all has to be done single handed.  AND you can't see what you're doing.  It's all done blind, LOL.
Anyway, got it connected, put everything back together and tested it.  Worked perfectly!
Whew!  The job took about 1.5hours start to finish, but it was a stressful 1.5 hours, LOL.  Had I not watched that video, nor had the right tools, it could easily have been a 6 hour job trying to figure this out.
Some extra photos for you.
The opened actuator if you're interested:
y4mCE6e1QrDRVGNZKMZ5jyZDWFuUv7B6_fIEaT-61rAwZ3q095pYHz-hodb_1iZGHk_nw6CXZq5IPf7MiCP3JOxDvJo_kHoxrjykiv33WB-bi9RqPKXq-oDnXfAy5HZ42VbHalqi2WNdREB-bEgbDEZeZyeRlbo1Ep3zAn5r2FBPIJrGN0EdCiWvJ4RXd3Bydg_
The new actuator, I can't believe this $25 part costs so much to get changed.  I think it's upward of $1000 because Ford will remove the dash:
y4mjg0RaONAcROzz61CN7ukjhFQs-u0LTru5XH5C5F-Fde3tHRO9rcy_lMC51mdm1mE_h5OvmwHM9hVyFEIcwFqZa2BHoCscG2s_kUmXC_--SaoEARZvbKS-5cUahB3KoVYCGe31JtckyMAFKL4ffJeIQLFsu2bYcM29M3qzHc0z2_CD727ZrUayAI-twxTLAow
Built Long Block
So this has been a long time in the making and I finally received it the other day.  Although I have brought it up in passing and sometimes eluded to it, this project I've generally held close to the chest...for a number of reasons.  Some of you may already know as I've shared this on other platforms so it isn't the biggest surprise, but it's for sure the biggest step for this journey I on right now.
Although I'm totally capable of building an engine myself, I decided to go with an outside builder for a number of reasons.  The main one is time...it's just a premium for me and a project like this would've taken me quite a while. Likely even longer than the 6 months it took to get it to this point.
I started talking with Ryan over at RMB Motorworks about a year ago.  Trust me, I've read all the stuff on the internet about some people's experiences, both good and bad. Most of what I got was pretty positive and I always take negative press with a grain of salt.  Got to know him pretty well before I decided to pull the trigger on this and I'm glad I went with his him on this.  Anyway, here's some photo's of the build process as it progressed:
Heads off a 2016 SHO that had virtually no miles on it.  As you can see, they were in great shape before they were even touched with any head work:
y4m62fiNZBYUd484Zdbz79ftYoin0rsDHcOH2Fgbsd-2Nr8NLV3BEiTVf2D92sSXdb55BAodIYEoZWKVuAFI3nqukF5GNedkCB0gHnJmo-FP8hHaIy6l9vFFoiCUPF_QxFPoTikJGdRVjustSL473DCQKwnHAnvgp5y_OiffIZFQb7YVIC5BIYo9HqAx8T-o_Sz
They were sent off to Headgames Motorworks to get some love.  Namely their Pocket Port-R.  What is that you ask?  Well, here's a quick blurb on it:
Should be able to get a bit more timing out of this thing now:
y4m8asNVzl4yzi28By66pQ0mZb4N5e7-e2FLqaGIKzbozyeyXBfdw0TILRnQdtWqI5Jw_19vz8IyVMLI2BRdb5jvIYba2tXke72ZBYFC73Jjdr38IK7Q1euUQV7GWp1oj0iOGQTPzhaxuR6SPeKutxPi72YvWLy2Q0Mzzknv-I_ujP_btCADpQC3RV2X1atbLsv
y4mhpdQOWm9vV-a8l93uqGA_4RgSxaB2NR6t7QBb-2yZcvNJ27q5A4XNtVMka-rvx9RutRx9MQjY5jzhOIkI0qsWkEf9HWvTDzuLiJ6WL2S8ongYzxOhOV2kbB0JrR0cX6zGn28fKGgryNAucqmJbMju8OlY67-eJ4bvjmZ2SvyezvanTTaM7AGBarJWPQRT1XQ
y4mzERgnzZu07kZBox5ZBDso8R5bKDOZ5pC3fa8kCqb9NuyVqcY-2Nr1RzRP0M4TQ9ZtTXIw6HvlrnvMO0hGgs5xSdPSrd1XMb6wq25EYfrq3SSMSghKLoS-GjdYI83aVKkRVdsOaHgz099sOocoJglHaZFdA3yu3u1P25pop5dBcPabIC90yIIcGAfpxEuJv-a
Stock cams.  Didn't have anything done to them.  A custom grind was outta my budget, lol:
y4mmwa3NMegPYlZaf7fW9q7i_thqWaZT4PPJIFZYdlez1YWW9hLr2aKolzyYU3jyPdFJhdtt8jf73R2BStvHwcbKAXfYt_Q7OZnIJQkdAOm5Yp8eP2wxJfUqSK19X5xpiM2qSxCKWb1JUBrVATwuACFuTy45uT9vxMt8GkkU8qI6rehMjkYFVQElCTpMgB17atN
Brand new block, before it got sent out for the closed deck process:
y4mWs8LG9YVz_q3ISfPlc5X7ABNwcOUomvtc7-nokeVI0uZvrNglXFvdaZ6rqGDsVgQh8LTOrY8U8hp2hJbOgM-Ava7p2Hnox5RS91QniWfRvh8Yh1p2cP_AW8_V_b1YTy-ynRMEl4lpeV_xpqNr83lhLkgysXafZeSNcblQ4hJCSo04hoUfkNhp_JXKJe_yByN
Back from CSS with  the deck closed off:
y4mfz_mRQmNLlQ9cyUw78Y_Oi-V5z_dlnOEEmg2DmtaA0HvPuWpz7o1hhUCcmqIHq7zGIU03McaZSQxpnBGz_9-qLAhnnV717MKlg4VS14DmKLRSYLQ-r--ZeVe0lcJGkNg0PLcUnuWYZ2DAIyNR8-Yl9FGJPBkDAvZ05f36j_yye2EWsIJUQJFV1l0roFqodJn
y4mn45fjx4mcOKITsXzwC7lTlqnKWG6a4Dd53NNWJKi8j9N78oTjD-ib6QJZVDEspATqsqAMLimFK8S6BOGS3bwKaatJ4ph_g1OwQnf4thCxQ2idkzL5OF7rFtzqaj85YeYY1mGV3WEn5ohvrgmIb_z6T3_Wk98K-gn4FnRV6FeBaN_RZ-OC517R3enQdwJ2SCk
Just some nice hone work:
y4mfDpVGMxtUvLFGkOPPQqEMQDiaedgqFXA1IlO2BvObAHnzVLZFc12cA3GaBCgvoombq-i5-MrNK05XjLgiRy7JW_OyodGRyQnJGqPRwpcBrh-HMvFMdcHyOsbKKqEBGJkz9RWy4zH8U3oUPTcrUTx5Wq_qpmR20onaaBdEFxPQ-9cJkBnrML32YaOqnDD2h8v
JE pistons before getting some Calico Coating love:
y4mcW-YrZYsOzLooTh7hGDnxEP7SLyZWZp6MOFgXDhCSvmw9JoH-ScVsRmU5azgYQLpQ0tmYgDNmqgCqiGgTkIjTT_bYzK18yX0YhABlZkQPoC8fmmf8s8pfrKEcppHcx001G8ntwMhDe0erjiDq3u7qHmy1XLG-gg-yLRQ-0a7mugfjP0gulIP3Cd9TCafyhJ4
Skirt coating:
y4mVnh_pCwHE2e-K0vLEjCNhlYInOvK5KdOiXAHH9iVT0afx3fbNEkuws_-UmvHaGescpCcXO1_Ap2BgzDu293gmo2E_Pf-ryT2uaNkk4jNL8aT_WlfJfxcDulkq1Mkn5N1ThlGYNwuK5YIcdlW94nj2fOBF0MksBk9o9I-H1TYPSFDqij5A5893GAefvtY2xIW
Thermal top coating:
y4mW7hWXeU63hDORGI8fpJD1Gr82IAeiCJdHUN3602VjOxghG7PfCX6mqlAGUP3J6dqja0OP1cbM3sZZmanyBx_DzDMVc-12fYJS0Oaldg8SNSMnErAcmgX7apnEQtVm-C2lNTr98XJuf_DGjTRqAk4eACxwAUDkCavD_bptgwJZnrh7bTt1Dh4l3j0BMUuxO-M
y4mB-GxriOcZm3DgTum1i71n3aqXTIbWW846WbYHWNJKWXlsKKc7BtNRDs3_7g-rZbWmJMpmeMvEgkMkLHan40wjp6YJzLMWyEsHSS5v20TcpXMDLOHUo9ovu6n2psEh7Fest3Yb3s2FwtMkwy6kswYyaKfXj4YB1oDftHsHk9O8WIogEboH4uX0Arc1uBmF5OK
These conrods are sexy AF! A set of Boostline conrods to push those pistons around:
y4mDQWWikgxlxo-hiH7FLuIQjBFk5tzhsFeHg6EsPeFtAB8Fpo5w66hbCvNMKFdtnsAM8mghnfWwSJ4CHNhvWng8w1NoJop-jYJV1rFvr4ZWRhj9iHD0Ai1TnReJ5Pg8zgily_39JC_vDPPmYgAJ3iZ2Hz7WV8MiwlV39K5eLok6WX6goM_V6Mp8dKyh0OGUqsy
y4mBUI7MISQmNKS8EgitljPWSV2OZ2TInjuYVZEBTRpA_hk26LNfeutan_npQlnD2YEsOh36vzNjQtXlGjwmUL8-ZosZy0oNmkfT6cMD06gFyrQlgeh6IjWsnflogs4JhlrbMmMn9qYTZMnfxtXA-FJLyZ6vDH961UHUHboj7FVgekKbTC3xAyAjPSkLSWiSD7I
y4mz37d9TMShuq_tO6p5njiG2EoxPDfarMkVl2ceiIDT1wK3SDGjkPgec22n9mfC17OF9zK32ENsNhf2JvEGzl41giSV1KCF2fwWXaEENYOT2B2zXHNqN5iDYE2toUTd5C1UR-KOcFbfbqvujr99pXS9TzmWP8HW8Y4_Lsc8Q2B2QnK_QengkhbZA9Wk2lVoUD1
Some ring gap measuring:
y4mtpXhomhMvLDm1Ettu-PX7j15RQrTjzPbcIJ3LePIPvjjaRRKKhepC4diu6bZTmPkB6CHco7KGMSP8rppk-PP36eAIUkfGMDcYnKiqC-ODrLx0fjkJ7JRWrm_4LktoJ9jUzh66_d8-6P2GgOhvdN_AJ1WmpqMpi6TmKUaAO8XrKdL-B2XIY2JNgBIdEUkJbS0
The centerpiece of all this...a Ford F-150 Raptor crankshaft:
y4mRh0DpbqAKDB6INjajj8xSymPT_N_l_yp6GwOcI1of9vCKDomM53OaOHL4ND0UUKFOMs1e-79KdWPTyxkCI7KkGz-p5V3EKtIfm5kNOPgu84WM5YuynuEtgoD-Bso-VcR7zcODtJp0t7h_FG5pR8G9mEVDl7GiSBQxIdPL32ntOwXYyELGY7ttz1Rhptvw_-m
Main bearings:
y4mQ3l16DCVqLGF6xzGdRadnkVgYUIL15wJBXKiVns_O8vnqs3BGx0HnPSz3wvo8wHRdVBS_3EAvqc-MBQkLVGIaJgcAjbWubecXnmZgVKQqHHbK1zDZLlW078zcL9Tv4I5oTQPRF71YhRhNuq_A-Amx2O3GqlLubN_fzKHa3wVXCmJ53daYUuJ00CY-tneyed2
And some more lovely cross-hatch machining:
y4m7ptI_qegLwTahQ1lyGCrinIjYgQo1cfbsXEJVKjrLD6oknHvpfi7nUFJl_A4G9PsjxXfmb0U_z9eHQ6YaZH-tslK2HFDYj3u8bp1dO4hoJ_P3b0Nc5EIQ7rrAaYuRz2x3p_-WOQ84OECRkwQPChRedfwwcIIN5MaW229IkjgOCx2m8g90aE5uF1qyAy7sy1l
The King main bearings installed:
y4miXOaJBfeda8vHFb0F7rg-7-hUU7vd-RGJoMZKpNHJgoFILryE6zVH2XZKs8RtVdqekC2TxZ4e00985i_s15ONMB1_eoK6a75XM8Kp0T4KhtENMMvur_3sFAu6GwKXS1deMjGm4yfAsOZr-H03AS03o_65ymgl4suRZumtlRfbN10Oh4SmKyfEaHoj4T3U9dR
Checking end play:
y4mRST1UGS7iONj-zPe3Csff16LQaSOnKO_wgcBA1ty0s8GoRXdQ_u9rd3gtfGWJFfXzFngJe62E9cGHjLhVnofFyItFfA_kJsfkSx_hxUhNswR2uIszwn35KrYQmCao0g_hTEE_iOZIDmvqnVTYgoUZbZQJBepIfqPQ921g6YLTOdfbLr5y6l7RoC-5RmTWBko
And more clearance checking:
y4mMiVgJxaEKHVuTI0wy-PjnzZpgu59Q-5uuHnMWPWjv9hI9VIVzaABWEGcedp16X8hKpian72FWCnPU4nH5ksGpvjFwMLEGxDQIu04zTXg5GjIG4p21pYcVKvMhv6gcgvAmUt2mVpc24HwXJd4wjFj9DNPj0ud8wAhfTpHTtSqwOw_mtqwqZqzCJjZY9ADcccZ
Completed short block:
y4mWjKtBO_6GYsu275qVQlDZqsTN5Z7vaHanR4DfB5ka2Aw4d1pjDECvJNAX4kk9tF1Ntr4NweC6ey0zUegbH_qRl9IAm7AkvhBHT7kz-MMFe-FUcO4M_qxOX5uzjXA_EZ5YqcZhUWfum7n4L1UXFQqoIupdEUf8OWJSzYAwn6Evkhro1e283xMoTj0b_yeGBP4
Oil Pan, pickup tube and oil pump housing installed.  Can't forget the WPC treated Boundary oil pump gear installed inside that housing:
y4mMdtyyqvfCFEgI7iEZf6GQZcknwdyHhnf7LqCi4j9A6gcWcGbnCv8LHSRs7ZcLai5VO5ruz304nuoXLFl0sTn_L3QWlfjK2wmdNXWCyNwd04yiPFXwIo6Caw96oeDVr5cJe4_YnOQ5YfBoAEnjHubu8iKdVitSy50fY8v30wk2ekPKKBFtya-bzNXGke4Ss0x
y4mBsxsjWwIzEubq-oj5--p2feZ7yXFz34jF4hxywwhEXmPf7j8NP2aA6TOqAv6wCHQNzA3ZojMq5WpbNYwYatH_c7crw26x1WBpskZPlHjziUA-IP236nRqKpd7SjxiW-f91jCnJebmdY2pwOpQb5TnBT_7rAS4JD6dwr7ifkbIHL_FkneqVQ5xS5_HaiXoZVT
And some relentless engine assembly porn:
y4mIa7fqiYteUTNxBiSt7HnZ03NM_O4oNZhhpzjwj1Jx_2p8I--isdBGe9t63HJfO52EU-zsiEh_xOfPW54_yEgQV3k1wtP_EHn9RqInlzgaY42P1w3xwQIco6Wci7om8k0AiU8nfyPbKiPK_yv_N9vTHR88tIXQj4PcZ5nIyLVs98tYgza17SPrsZTOD1fmkxK
y4m5hu30vNsMtxMYICGOE6MDA53tWhWdg3PbaOLxVfAHMj5Im73aSd3yCCp2BK-8fiDBnuq-MF_--06XFj2VKUc0BPZuQuQcOg21aZYpvDjUsv1btOBb9amDw3brFHoTPUUpqQMvdSQcpdpvkUTm5UD55geUSs73V8ZiqumxmKiyceTSWz8HieSE0gQEO1HBpOQ
y4mAz4COLsoL_pzLgL4yqB5IvcE4mijHGOsIIEuV331ZFPcZQHG_MvB6FBYbfAGwx0WbugVoCrltOuQwj75HWK8xuElO31ayWzbD_ALOza1Z1g4UHjMoWBD1FOFs77FEblRiYdPcy23E3X9ok5jI7Ur3UUa6O7tHQt0KLA7ZyCjhwO0GqzWQsWivkNZ-UKTgk3T
y4mzKueVn1k2TnfOZmLVKFfmP7i0-x5ozet2mc22SUQhzg6uMR9srawipG_n6TztnJCq22x9jcfbCKZ-XbyGG8PJyzMOZG0Ld0JmkAKW-wxS2biOF4j7p913FRIVgjsGl-qzAWtGQp9KKddwbbCp8f2ceUbOE_qDcXREL_HHIjpWPSd1Wnnd6ZgBiDhRF53b08i
y4mFUPlivBqsgPNKO12Rs-4xdNTMolJ_t4MPa6DHVzeaXFSeX5RDPtC9k3ynIJXjeatnK83nRtEH5iFm9tBjLoateq4UZgmdDCRACN8a2ab7AhMoCcWqUXRgwFlXJIZqMFjD78A48WFqt7U28BUq1VdbEiU3Qk4p1sjDF97yCJVQS-jURTk1ffGdGYtcKxoZ7XU
y4mVCiasaFH_8YN7iQyNG2MA-YKoCD7WAbtRt7SPFjLSZtaoUYbEpKOfTRSHdq08hnx7Q71oe4gUarC5YF6M_XyNMCnO_sZhyPe3wMNk-Sk29yXfgGpu_AIEbKQpPdJYdAA3vubV4zqDMTMLTgA_cWo_slcPCATkotENoPDFPANg4pWll09ywVNreSfq21-gFQj
y4mSbwjg-F-wfF2MUF22jpHeeIZO7U5a7kgDWKSLmhgDBG86_hHbMV-5p3pJCQaEP718V02wRZ0pyYDjWJo9YA53fxahEsDAG1Au2mcjjhqZ7eg75vO6FAR22cBWkQ9oN3YQUFpGyzSU7oTjZvbmDIKlR9UxC7cEbVrlJZacKO8HC_IOfYh_Ru5ztj8VckegEIt
y4mo5ZOwRkOf1ieEUDxrEOrimc0ybQaNPfA2cSEZ5COClYTCB83uYuf-XBMR0ePeGSYOMaPRYHDGxKAVziOez-wICGtzMpByWcq3CtCD25KMC68bjHJ-JyW2EWf9ZPaNxnRGySd1nwnLigBnuBsCdGwTFJn96xjbjvkqrqriwvIpR-hu-16DztrE79bC_ux33sT
y4mXnkn0OhavoncoQGl9u9Cv-mOAF9UW7c6jpjiHItjwMA61LS5kMZOlMODPFB2Zxl6Bc80Mbq0FFcJ1djcBHn_I1Tt7MEoZ1rOQ3cj-M0ombCDixj3PGtSbYi7g1eNX4W3rOmLHknqUsArU1fp7p0Of0qlFuC84b1G7RIdh0cTWciCit8IkgWLUwS03rAwio4Y
y4mB7f0_41AXtBZncjcXiGje3e82Uy5yq10GvfVAJxuCIcgEp8mXRrsJS8bbbVsVkclkZf1dYLeK7KO1OyQhK7RE0JogQcoFRkwRjKQ18iSugRCgdCf5PFDaP95gZlTo0lxE_4YBuCHuVv4KqnUTmZxlrYAsj91B2RpYTq7aUzVS64muIf0sqZXTnqzu8wKlhEY
And finally, arrival day!:
y4m0xd7AEM9TUAAAcz_9kKB9jrdrTkRoNLjg1yDrZ_jk6S-6A33x5pwiVJUmUpgpFVkIu5lpfGjK56OSdKWHQVaGMIOA3if3je5ebkkN-AcqLpEQ3GOAkBeQlhaKLV362bBU4RQ041EPqHAW6S2gzOV7TLpoGBgsXK_W3IE_cDJrii3ctD_ZJ0DwEDZ5yGsriXH
y4m8xoPbB-VrbGptQGUEwp5CecZfW-h4TJ5rl4DZAHLt_tPWo7yV57suCjlIMA8mzip3aplh_DAQc2AMpbceWhYwujIkGbacivTfohaQlho8isk8QsVzkgnkjngaygFL6DNAKN_FiL4uYwj7gjIflXzC_dcjNL1CLsU5f14_ODlsAvFRtNCjJKyMyx1Xm7BNRSf
y4mRMG6ZuSUvGvwHz2aRjdPKGBF5siNNHm_LUozT0osQmQWioRe4mu2xMppjRcHeJjbOu4oFeVgXcmtUCZEGiJcSfjbPat43YLnGvnS3b4ERt20Hu3JDDkRa1Vh5-DHmnA-7mBYJfZbwVqJr5exm7P_dls4FliefFurGqY6J4a_Se1Yqy_uznV3_vahg4-tl00V
So, next step will be an engine stand sometime this week.  Then it will sit for a bit until I tackle the intercooler dilemma on the current engine.  I want to work all the bugs out on the engine I have sitting in the car now, so I'll be mostly dialed in when the new motor goes in!
Stay tuned...
Build Sheet (not all inclusive):
New OEM Short Block
  - CSS Closed Deck
  - Boostline Connecting Rods
  - ARP2000 Connecting Rod Bolts
  - JE FS3 10:1 CR Pistons (CT3 sideskirt coating, Calico ceramic top coating)
  - King XP Main Bearings
  - King XPValves Connecting Rod Bearings
  - OEM Ford Raptor Gen2 Crankshaft
New OEM Cylinder Heads
  - Headgames Motorsports Pocket Port-R
  - New OEM Valves (back-cut)
  - ARP2000 Head Studs
  - MLS Head Gaskets w/Integrated Fire Ring
And all the latest Ford iterations of accessory parts (chains, sprockets, guides, etc).
19 December, 2020:
Small update.  Things have been slow going, but I finally got the engine onto an engine stand...you might find it interesting, LOL.
Well here's the fancy engine stand I ended up getting.  Sunex 8300GB, 1/2 ton stand with oil drip pan.  I wanted one with an actual gear-reduced crank handle because, well...I'm lazy, LOL:
y4mGHl4KHjODfyFv58Ec0zNm3-EynoBGmtPIh8TIAldQMxmIurPd3_S-TLqix6zWhm4059NWpWQtvW8pox_31Qq48zV8L5_WRdmh45tGi-KmOI4Arar30IOyofis8gwmyWS9yqsBeZXvDVhyl-pl7g4dGr9nQ2ZITOPrV2xnUFIxxqGF6veAhlOHdzxEIsOYdOh
y4mPUtmoC2xI2gvkjIhFuBW0qSLHxXRlpVLFnNhtupgVZ_HNCyRewsvP2pUCZtfPXZ5PiVhtxbgfU0A22tEOdiw4NYX12weqAl1L_OiXLP9DYsDqxAmovxzfYB2ib7Orqi8tNKlxMV0Aaddhx-WgDc-QdmNZCrYtoVrthrA-818GKszR2wFJ9J3QlAiQCAO7idK
https://youtu.be/MPq-bLKLJAo
And even more entertaining is my engine hoist:
y4mhehHr1cHZpn27sMqOTZ5KTgsCLv8lciCAGXn3acoR_Sc6N5KUIegPnDi6131OHTPuNjtnmDCV-0Sib6LDwKCKiHbUEJuAWkKozNybSEfe7xBdGZGgprhfAYEnMtylEKRkxT5pDCY7bwML8YG0eKPkl3F6IVnj46hExDz5neJ-efMSpwwkUUA19sRP0PdTm2r
My Kubota BX25...how you like THEM apples? LOL
y4mARa65kz2vrX3zELmVzq3bW_ErvExQ6CFOlAR3IrHpdt_Ys-MJDU-vhLs8glswQHUphbfLxXomHGqiG7CAEIWoZ69_K1NppXLe-Dz-ciIQYEmnYV4AB25zteVR44AUuupi-Kjvpfza0jN_OHPgfD4q7n0mmsFPrHpmRmVx2bJ28-qNJfN-TnLX25zmC5foXbF
y4ml3RzG2A-VwuVhKMV2kFN2-Eco_uBAdjXIiIXl5xF4-K1C4qlAtWvspYEDoAf07IV6mjUO7xmeIPNWDTLL9WKEa90PKOPrT3B8gcMwSg2H84cV5nXoj7DC-4KPTMbNXAieBHkDI69v-eoJesUMFbPV-_zqeJmXyjRyvtk7OauY_LIF-qIUD46KycQIiKw5Q0P
Got a hold of some metric Grade 12.9 (yes, it's a thing) hardware.  I made some stainless sleeves to take up the slack in the larger diameter engine stand brackets.  Makes for a super tight fit and no "slop".
y4mvCUdWiljSZCT_xFW64-OuiqyXCxq46cbX-h1cnwTehrSXa3ezast_3taxaMq5mhJ9ViyU-oAJO-2ZdwAdzOJcQX4yOCvRolSNNY6Lc32oi4pXlp7XVA9rw8BIhpgEflPOy2C2MU8kmpdq6J0zaiYxcsS_jhI6jdEUBL0BlWbqKh_UMW-OzhCO2gU8JqfHgul
y4mwNBD40x8a3ttX6j_2tmBhPqjFooOijAJBLpMN7ACkq56rCPEK-hrOKDvtXUdYbkPBZ8oyqg3TjF06KzqdMMO-T3JHMgVXIzCcC5HHsk4SL7ipj9Q60Iqn4_qhrRTk7J5-ze4o7sq0379kr2oPn6iLfMVOd7bkLqyiFMkqK_FYSbz2i_flAMMpcZeK3fUFvxe
Everything has anti seize on it! Sleeves and all...
y4mTpY7mP5MOE2PCL7ao2KBNWmRZsH58KN2qP5_EjUV5rXIhAfjY6a473FPahNKj5KJ3YuO8W21Kb8rDb3oGBD3f2gDcY1QwyndBbFZKbrJ3HDWuKRO_am7PgAQ_ha9iJ9QvNBR5rMGozQxsRsURb2E_HDHVVpVBaqKroT_5PQMpOXGvcDyE94TFVySxkK_HbE1
Getting it loosely mounted:
y4mdK3rTnyouEbqQcsptB1Tf5_R2sSRAMI4Ufb6ZXxsNghlFriqF8HWM9KE2Okc6p4-ufPvFlnE9yji_D67n3Mf8v5M816D3N9H5QSiAC4TV1LCobNIJ92fF4lMkbzfXi1NgQBYSIoC6GTNY88BG8qnY6Nlg4MKfI56syBZrH8o3XQu_IOK0__vH49mpmCvWjaS
y4mBvb-O-JcooZ8LalmXSELeKgHmq4fRfOcM-euILVOzqImZCSrOoTO97VMJWHqiULEldqHdJd4jX-unJtmsVISVqwPdkDoq0hnITu0pxTC1Q9FgaI70XzbcVYv9NQv8MduXnlIjL7vgJPbT10SnBd8u8cnL27-Flh4CNsxojSshbfJBIeQDIf0v0PCKS7p0r4c
I like to get the center line of the crankshaft lined up with the center rotation point of the engine stand.
And mounted!
y4mjhqgnKG4aHYcefyjlIks5THbi1yjpujij1GVMtSmvzar89c1yU4lHuqAKbYsymFvAO4YWNAmL-4mAM5mcsEe0HM8ojic-mjUnbcCHNmd1dOMIWtkr1ISmw9m-eCnajlERpAM9J2SC83I8nfsqX6VNCl8rDQJh6cKWsG9Ua4m0p_DF8AkxQB-C4y8mgCBCTd2
y4mFn_IWzcMja67vFwGKQPkERxnC_d-yG8JoXJu-7BwvV72-kNqxW_sPD6PC2LwmdrLCJMSLm0Ptod-VxrkZJmwU4PIh3FwQKK_7ofDhgQ19Eyyxl8jRyXD7p8CsrrMeyf4O1Qn8uCqZD9-jhSIq8djjv2KJuYmT8VP8BKsCSb9tMGWDXBd4oJM3iJkPz5JKCjH
y4myRPu7KJi0RNz2zUeURxQqB85nxZFOokIVVzwOmQvkhjcSRrk-rdZdbfCNnBhzwzGufCjijXLbBJChngbXzNmNiEDKx9l31dEwG0GCQV13B5ttXMAf0_Str7EL9uPtloF57bg6gBXLZcwj9CtSuZ5s1hEcG_mEs4qtI2tm--5tEXwsR7dob4VOQZWvkHn9hOs
Rotated...just because I can...
y4m8Y5ZW1RnvqGmaHZlHceJWeYAlnPBxU7CJZX9Hsln2huK4hAfHCKZxJptlWy5onNTNyiJmmqwOpauICKwT9JzxH6viGXP-efTWYVlO_vTnGVTfsL_6vTvTm9-TjtzCKxABi24u2EStRWvWaiNMI-tBH2Dn1jjxzheAa5XM9QtLD64ctiTlZsfb5lr5oUdB6DR
And finally, all tucked away for the time being:
y4mSYMsduUePQS1vm3BF-1SsII5WiEKdzFtWNJQD0iH_5UHE_X5T0M-Vw7Joj6TUsnBQhxU3qVRpba5egALB2DeOnpZU5-MvFRI_FueNEEO0SrZuUhtCGmnV2rBIYQPg1rA0Ff2kKwpFtOI1_fCLZIasKeNox1DnYaybBgAqIs9HtKr1ZSZkx6J617FeJAgjbtn
And for those wondering what that shiny orange flexplate is all about...I'll let @bpd1511 elaborate.  All the credit goes to him for getting that brought to market!
Badass!!!  Love it man!!  No seriously the crocs are cool too!  Explorer is going to rip!!!  Not like it doesn’t now!!
Weight Reduction: Roof Rack Delete
I wanted to get rid of the roof rack for awhile now as I never use it and feel like it might be another few pounds that can be shaved.  I was thinking it would look a bit more clean and give it an even lower visual appearance by bringing the overall height down a bit.
The majority of Explorers come with the roof rack rails as a standard option with "slick top" variants normally being the PIU versions.  I used a lot of the information contained within this post:
https://www.explorerforum.com/forums/threads/roof-rack-rail-removal.383226/
...and it was an awesome resource.  Thank you to those that posted information on ways to make this happen.  I won't rehash much of what was covered in it except for some things I may have done a bit differently.
Here's the before photo (it was dirty, don't judge me! LOL):
y4mB7aHIx-9tVMPNXs7wAKDTRFOwjQtwwxYIKuXYW1oK0bqMg2WIMdgqPrZ5RwZaffKEXnuY17FEFlCkZLJ9KGRMBtAWiIXHuYjM1gzsXSwT00DbykrTUQQofaW-5CY97g7VyI0Gkuu9TWRfxIfJJr2XazFvpCKw2tzu9spvXEWcoGQ3erjlLJsj4b8mTijJZj_
First step is popping off the end covers to access the bolts that hold down the rails.
Front/Rear:
y4mqqJiN8ioLfwI_-PboYdiojc_oW3CLhFF-NU1VlSkWFdVdEOvfJa4KlyCAHrHNVPQJmJvvfCAzIZT0Csvmfwqk8fuqgVPGFtH7aUMwY_nfk-DueB0m4n3I1pA81JRQbM7W8lprHFAaCGL4OHCgU_6HKDzdCMJJOVRdTKjqiJIkdyysMxCbH1vdQZ9yueVJ00L
And once those are off, it's pretty much self-explanatory from that point.  Here's the entire roof rack system removed from the vehicle and weighed it on the scale:
y4mRUHKrYZysUzAA00h3nGiX7pcSegquCiI2QeOuXRmRw9UZo0mUrww94-a1r8JhHWEsghp51jCoE_AAvkDSZRmUt4vtdrCYsOStLADXFz2zDt-IybYYMa1kMsTkEzhk7LyKuqCA9aUvm2W9Y-v2KHtlAi2J4wRGHjTe3yAODEFmzQp-hKhWvONXXR3X2EGG64C
I saved a whopping additional ~19lbs!
Starting with the rear portion, here's the bolt holes with all the dirt and grime cleaned up and ready for some new hardware to block the water:
y4m9Kk5ZeJgvHfDWY1ZSI8JqaESUm0i9Lj8jIK9Nx_oZzyvi6VY38_GCI5FwQfcCmTMycVc8tDHqR8xYuSwCkg7ISlFAcSMMDoKTVvxphCqm2ekmiT2ROhwuvZQ_yeYV4pq06wku4XQ6wCJZXZt3XVCMEdUY2gky6OrqSEmDemcKDjIeAhBvzp_A3T4S0NdPmPi
I made a personal decision that I didn't really care to add the length of channel stripping as I wasn't really that concerned about it.  I did want it to look good, but wasn't too worried about the top portion, so I decided just to block of the holes with straight hardware.  What I did decide to do was go with some pretty good quality (translation: expensive) 316 stainless steel hardware and some weather-resistant rubber sealing washers, along with RTV for good measure.  Here's a parts list that I ordered from McMaster-Carr:
y4mjxA__gJnMpiwx2FQ-UamyuBeZq0DxLcCh-VUc7ld0Q1WmDkzwcq5RtCEDCByl8YPOzEAV5-PwuBWPDwi8-ClnAFnd_GHsJhu9vJTeZUo_VKo__CFedMH2m5sD6YngVv3OER1qPv1CuqTcYq0qPXeazTIMT6MZN-K_YekOsakHU0VXGv-KAyJWCjNetLu2ZYw
Yes, those low profile bolts are pricey, but they will work great.  The OEM ones will work fine as well, this is just a bit extra.  Here's the hardware in action:
y4mBGXEv1qWw3N7bG7KVf3an-ZEMTeaaLTy2mSpt4xIBiL0kr-a3WUV7gKLbsGPXFsBu7uWkiy1B1lUKRIIviBlOla17udLUdNoqHNDIKHxyvNUs645Uzgxwmf5PVhhmTpGR9ROXN0HNkA70xvJDNlD7WxXE95ArRmYLVUW1twVh9XH3U1G2H9bs4Kd1JmyFqqu
I doubled-up on the rubber washers to ensure it sealed against the contours of the bolt hole area.  And also used some of this RTV for the extra measure:
y4mEJyXhmVMA-2eATkwQa-urVut7ekbowUf2c-bxzAUUBHFZbkwc8jDSYuwKgccdiVPngFpoS03gYi7LLfRyGc8qLQHydtSrjNVJZ7GJ5pPuus8b_m_uGg6U_GqQt1zVyZMlzqUNr3593muhyvlxJtshdS1pcLsvazEhVHHJi8f19Hag8lSh0N6UQFEGeA94PVY
And the RTV applied:
y4m0iA1QEfwGJb1kne_V5VH4Gv1Dp9Dsjs0JmBO0PbcCKX_f4txzK-MAH2OuQeY8zxDxJttfs5W4Sps30E2oJf5sUu5SpQUEYjqp0i1u5a9VcltRV4QFFcz-2u82_yIce55gOxLDnJmTblSa0A9fniVnr0yVpcPv-MtE-Llxd4ivfrUokwNFI79oqBz2qCoA6_v
And the final installation for the rear area:
y4mUiDlnoJtp9k-8PfMU2azzh1GuKNkwR90qww1zFuIQyCulvSLqDVKjnM2cJq6g82xE3YFIdu9PTNVBuAs6n_NG4QEVXaHe-8GGQIUPEJoGEiQkH3YQRLfXYl5m-DZZAzbHl73FEtnStmgX3fYKLs6KqZfxe4qnAJ79s8qyvFDfIMsSfVvN3dCJnFzDaS4NiNe
I will concede that it looks much better with the weather stripping that is used to install in that channel.  I just opted not for simplicity's sake.  It's not all that noticeable and I still used the front short rail sections anyway.
Now, onto the front area.  Here's the parts needed:
y4m2pSnYR1VsweQQEnwifMbSlKFuMyOvnIPjqO1H7v-SqIAyOG3dhqsLFWu2wwFZ3HHGejevmzti1u2ENhRliIP9tDbKfH5OBsd3YUPhl84r1eTG02R11bSM5R0-xVxUayC52Uv-qFxb3LjrlXnsPSzeVQnZ8rg0HpJR0usxTbFRQSYsJBfL2BjAcy7x_IAYvGt
I got everything from Sewell Ford as pricing (to include shipping) was the best I could find:
  • DB5Z-7851728-AA Molding, Roof Side Trim $47.77 Qty: 1
  • DB5Z-7851729-AA Molding, Roof Side Trim $47.51 Qty: 1
  • FB5Z-7850002-A Retainer $6.80 Qty: 1
  • FB5Z-7850002-B Retainer $6.80 Qty: 1
I made some changes with the sealing foam that came on all the pieces.  I decided I didn't like it so I removed it all as I was going to use RTV and those rubber sealing washers for a more positive seal.  I've seen that foam stuff go bad over time, so felt my option would last longer.  Only time will tell...
y4muLypIzaRLn7SMPWRR3ZcZAKhZP8vCs84yPDFqwHrxjYMPLGEKXwxc8oAkaqRKFjMKD-eMbsgadPtZ-_TKNqX-myqZss14GPiS0TzGzDPaQfYyzxR-zynr16HZ9DjD_kMvWvnOTZSFngXAprCNP2WYxXRaS_JAvQkhBZ7m8AZH2Yruufb3TGZoMgZuD5LwVRj
Foam removed.  Side note: For those that don't know, WD-40 is the most perfect chemical to get rid of adhesive "boogers" and residue...it practically wipes off.  It's great when removing decals and weather-stripping as well.
y4mAZkJX5xpFRYQc5xb4PT0JdrIMKquWSEtRk0OKYciYJgwU4ErV-dMWVTxkTKR_8knph-OxiU0y8L6QzmpwV2kpW0RZ58RnnbhJUK6Y6nZ40xL09hcHF0Gju29C6pZZZlxdv69MTt0HELxp8b0OWKN16ZWRgzvUm1U26ExCEMCJlLXCKljC5_uLQz6ZgSNsHaw
Also removed the foam from the retaining clip:
y4meugyWvGfFcmt80qT4FCgqFnm8JJghAOv8D2d9P6z-Y-AI9HWwI0_pBO9CSLx9vXTsA2QRHjIbOsi38FacenZNCoOh0Nj7Xy9czeu3MwqUE76qlAxRuqJugkSp0_Q4qOhVhwOli9R5BuYBn5ZSgV2DeQ9PVCds9oiRkXzpepfvobe7mFCWs7pibDzXyqejKTH
Difference between a standard socket cap screw and the low profile ones I went with:
y4mhU6_ak-O9nkd6IjI2ql_F10utl61xAd4h-6P2qOlXvjSMW49ndsamZA5oQg7FExnoalIpYzDEW4ohhpsU_Njl3jnT5sf0GKr8IxwFNU_JfZklsqrwIrwJcyX5yur16Ja5EBUJZKV4Qu_0Gkodzt2eo7346KXMRFL4iVUf-dNAQujpb8jFsIuFcJVYZGib-TY
Here's why:
y4mPzzCSaINmxRiwE6Luei5t_EZwI46AAYKfXNqzq_TL0XUk4zsGaW7ZvLEQg4CBnVa-ShKB1cvJimDTbz317cZO8zKhFCB0jrimshN_M8CMpjgI5-QGgLEtdedYvR_GoC2ZFpNNoo8806GCViwn2V-35XTIAYOPV2CN52eUSMc8ujZsSjS8E1LJk4VzoZZlFrm
y4mF4EQIHP9mnXHnqts4wuhVljqDyLwU-1R3PK5Hvaz7FVA1-ug92D6b93H1s3D_6SeSW-Kz0fxKGgtcBjlA95haDPIpKMHm9WFnOcwfR7MGFgyj9aZiMnAaMowAhqUE1SRNjNo-CqQMNGpFRvWt-I-8fVrcIXWn2R17sZeGqzXUpzxAstCuenxxxEaK_omD8nU
Bolts, washers and RTV on the cover:
y4mtSt-i9BiBGCiyHmH46RvI8zUc1OdoF3pZ1jYPI2_1yMtrfHMz_TQ7dF6P3KmW6-lwhUaswFzeDRrE5GeQZ-9ApRkPvqgxfVxV2WrZm_sLY7JSzEHrsvndHD58bJ6cCZwuMiMbvkO_taLkzXH0MYFgAk2AxDrN1RyWZGGvDzo1WTEMHWNKXPb660_t5BdZuIF
Installed:
y4m_QM5-bwOcNzcbvdpD5fjsOUJHe2joFbl4DSGXQiu6vvb90842PP2FutbwNHsAJ_SD0ZInBxiQV1_Jpz5VuX9X4rc7_iqQ7YvJr8DjC4qPydeiR9GTCkmdqnwjjJw-xwlTIv_ihsYoPUS3-Nso3KELHgJAn9jegmLMeoNnNHroTJpFlEB4B3XP8mxvcrUM6ol
After look:
y4mqyKoThvSOc6oWKjeGnaN3CyHQ27xk7kU-W6bRqMlAxCsUZMfspBFZujVO8atYUOXNsArPjP_7T4j5j_yT9PrEoONIW5IU5yWTaLRECK4PhS6cgj7f2W9A2Jnl4M1QsEnm_TqRu-nIpg1w5yJXjqZgkwSPwJkrlbAilvIkgbBBTa_1Ni2v-o9SgU0yrG8qk1H
Comparison shot:
y4mUd7lF13ebhVrpMaL2LjMLvZIdLp58J-WNsq2n-ySrefLZh8qy5htGngeA9dY5eOKHrWWTx27J_f6ODt5aUEVc9mxVERXl0nYlu2s8pREcwPeD5joDMBrux9pIAlfO9KxFNWtkDd1qJoBhROENkCDL7uoU1UqHtfv4V5FfVZPfWtkYRa2PzxoGF0qagmldjk_
And there ya go.  What you guys think?
Weight Reduction Running Tally: ~280.0 lbs
Looks good John, now when are you going to install that 2nd engine in the back of your explorer???
Sent from my SM-G986U using Tapatalk
LOL...yeah, it's gonna be a minute.  I gotta get the rear end tubbed first, so I know where to place that engine in the back...LOL
Real talk though, it's likely going to be a minute before I get to it, I am doing a few things to the current setup so I can work out the bugs before the new one goes in.
Fuel Pump Voltage Booster (aka Boost-A-Pump)
I've always felt the weak link in the fueling system of our platform is the in-tank (or low pressure fuel pump - LPFP).  This isn't normally an issue with mild to semi-aggressive builds as the addition of a higher output HPFP and injectors along with an ethanol blend and maybe even some methanol injection have been able to keep up with the majority of the demands of the platform.
However, the reality of it is that no one has really taken this platform to extremes quite yet.  Those extremes include running straight e85 and/or wheel horsepower levels exceeding the 650-700 mark.  It's those areas were serious fuel demands come into play and simply installing larger injectors and HPFP just won't do the trick.  In order to address this high fuel demand issue, we need to look at the very first step of the fuel system, the in-tank pump.  My breakdown of it is that, with those other components, you've basically got yourself a firehose nozzle attached to standard garden hose bib.  At the extreme ends of the spectrum, you'll just never be able to feed that nozzle what it needs to truly shine.
I've recently began running straight e85, and already the cracks are starting to show in the armor.  According to my tuner, we'd like to see a low pressure side reading of at least 80psi.  Well, at WOT, we were seeing dips down into the 60psi range, and the HPFP would follow with a dip in output and/or increase in duty cycle.
Now, I have been preaching that the low-pressure pump is the weak link and to that end, I have explored many, many different options (surge tanks, larger in-tank pumps, etc.).  None quite off the table, but most of them are very complex problems to solve and, frankly, exceed my limits of advanced fuel system knowledge. So, to that end, after speaking with Uwe over at XDI who was attempting to install a larger Bosch 400 into a stock fuel bucket I had sent him and found that it just wasn't quite possible reminded me of an old trick that may be able to be revived and used in our platform.
Enter the fuel pump voltage booster, known to many as a Boost-A-Pump, or BAP (although that title is usually in reference to the Kenne Bell version of the device).  The theory here is, the more voltage to the pump, the more work it can do.  Pretty simple, right?  Well, it's a bit more involved than that...so here goes.
The OEM fuel system in our platform is a returnless, pulse-width modulated, direct injection system.  What that basically means is, there is a fuel pump driver module (FPDM) that is sending PWM signals to maintain a system pressure that the HPFP can use to push the rail pressures to above the 2000psi mark.  It isn't like the old school pumps that just ramp up and down in speed to maintain that pressure, but rather, turn off and on at an incredibly fast rate.  This means, you can't simply interrupt the voltage signal going directly to the pump, you need to interrupt the signal pre-FPDM.
So, on the advice of Carl over at Vapor Worx, I decided to go with the JMS version instead of the Kenne Bell or MSD.  The JMS version has a reputation for having the cleanest output signal and has some pretty cool ramp in/out features that I found I'd like to use as well as being able utilize a 0-5vdc trigger if required.
It all began with the arrival of the pump:
y4m8rUvDA2AFrI-KptY90mkTWLo2I1nD7JRL75ATcPds8DV33ttjP9WZmOLzh-TtHb8bA9D7tBSVeFt-zafyehAvYAl6VmGVux1ytzhY8kBkeCDwzCXmNThMNJw_swhR3UOy3C7YhtJK070g899NUgVBVU0GxGygdV3rSh8geue5crKHYmPkmnTd3hNT8zu59-M
It comes with everything you need to get this thing up and running.  That includes a Hobbs switch for using boost as a reference if you are so inclined...
However, I really wanted to utilize the 0-5vdc trigger feature of this device as it allows you to fine tune a ramp in/out rate if you desire (and I do).  So where do I get a 0-5vdc reference? Hmmmmm...well, you really DON'T want to tap into the MAP sensor signal as the act of tapping it can sometimes introduce noise into the system and have weird effects on the vehicle.  You also don't want to tap into the Throttle Position Sensor (TPS) as that can open and close at various positions not equating to actual fuel demand.  I guess I could install a second, dedicated MAP sensor, but that would be over-engineering the solution.  Why not just go with a solution that JMS already had in-place.  Use of the accelerator pedal position (APP) sensor.  Because I like plug-n-play, along with the ability to "EDIT/UNDO", I opted for an off-the-shelf solution from JMS.  They had a Ford wire harness for purchase:
y4mzVmkZ64gs2w5DeU4kpA3qQsFDcOCGxwFYdVtwOZhUJqbSIPd5rsofpHYyrRnn_i2NRaOeLORCONtXiJQNpQqtfTBD0snNfGDwkeX5oa8xq25wEyxN_RYlv55q3pr9nXIrgKqjc7OHha5MtRJGAY0brRxbrA_FGj9FYWrX_-KYvi_PhD98ttnEIneLtB43hGB
But if you want to keep it on a budget and not purchase the adapter harness, simply splice into wire #2...
y4mOX1452ZGMczPH66ot4pbWCIlsznza3jX4BvL-qel8Le4-dh34HcJ5o9lCi7Rlv0kDiQ6OZ-jC36qiLkRjEMz0FwNWxzEseUuI5IxfVdfK5DKnrO8gnanX1GBdAITjnwXdTmEtN1hV4oPFZnZFz0g6G9WInDCupKuINQToy8RzG7m6kyN3sye0s4rUm0HPBmM
...of the connector C2040:
y4m5iZocQvsr8CIPSv9bPoNPvqo1PfOmSflFa_d5qk-DHbhdv9LvQB97ZtbRuU2zFG5SjQwF7RTPlV9hLF8D8RQ9jVkCoIYsgOG0qRvZb8nRVNtQOrlsllqSBdX5LAyRQ36TJ-pRoA3pRtpaTSGrme5qJ7AQBSbN3_g_b8HcUOgN-UVn2UnTML3paDFWBokaJLi
The accelerator pedal connection before installation:
y4mk9rm9JX5XJHrTjisDQ9JarX9KURtBNPBezWKAsjZrYk9FBF2IRo6SPiL89UC8fI_Obp8cRXN19S3CWbYs4tl7UGXHUGyJRHeTgWNGkD2boFnP385tNm0KC8bee9QfC8OUPSYcSiP-UIuY01SNHKqBQIy37g_sw9dnVoURfmxLjnsLXrbPAdXKLQMDfHnx4Wx
After installation:
y4mFuPT7P4_nbdfC6AEU-ZOm_Zbah6wUYouqUkJDX2Y1gKj-wEBLp8otbKMtwNg-_AVgfI8QeJ4Hut3-DGse4o6l2xaiRQnGJbqope0dwWT0WY9Yc841pPLb7R2dHiDb8dFwwqkCSZTUEnRm5vudltuP8o35TOWLIdNsvuPq-1BVl9Uxu9F_Ovuz-PURZbs3m38
Since I was going to use the pedal position as my 0-5vdc reference, I had to see what the actual range of output was.  Just because it is a 0-5vdc output doesn't mean it's at that exact range.  Below is a photo of the voltage at rest (left) and the voltage value when the pedal is floored, simulating WOT (right):
y4mQYZS7IugpQgGzoDd-tffHlmfk_9uJAOGPUVJ6v8KIyt67QSAr2bRSu6JOhOfLPQni_qfE5b7i2ZETVSnOvr_ubasGbDeiK0g9T9yDivurt8Rc6_BOxSVFEppaWFhWnX1a7SDW8eHZ3pbI2p3X1oQaW-ISctBEMnQojftNM2RFRdjLAcCSf8VYlStNWQYIT42
This test was done key-on, engine-off.
Next was accessing the FPDM.  Even though it is underneath the c-pillar cover, because of the way Ford decided to assemble this car, you have to remove almost the entire rear interior, lol....ugh.....
Here is everything off but placed loosely back into position, other than the c-pillar cover:
y4m1wj5HBljd3pwA0QvrIOephvb12EEnEy8vhWbnXAT7tsEr37mZBUmMKxheLAnNjFo-8RWZtPBgFXhYO9qWRCqdTQD_K-E0aVDjJwSsp-_5kstLI_plOh3jcnOzfvfADFm2bw8yvHuDsJzbKNLa7wnPU83mr_0-eJc1aUZgZFeYY_ect4PelqdDFUb91S5jcYc
y4mMwhYf1rHlTPHz7rw1YT1liXGe3Xi8LbPpXSk3OclZSSUg5iJpHsU0Alg2jBYxe2gW7OTpU2FTozl7h7mzrh4pjynviT0DSMNNMAgZ7qFyUnTGiX0SXrThuQo-B-QE13TYmW_PdfRH4TQixWdwfdBjtxL7EfzgF8dlFNirQgCnyEg5qDHzxsy3tFj7CV90k-D
It was at this point that I did some data collection on what the FPDM is seeing.  I have two Fluke meters so I decided to also see how that voltage compares to what the pedal sensor is putting out.
Here's a video compilation:
https://youtu.be/sowgmHvzBUg
I have plans to wire this in such a way that I can remove the BAP and put it back to stock relatively easily.  This requires the use of my extensive Deutsch connector set:
y4mw8F9igN-aHk7rUCYMTmo84vcJac0uYcg06sF4mz9COkFV8Ib0xKCcRM4Htw80zhn6br6-Jt6jNQKaABLvQgo3Se3GQndiR7kt5To6b6rXS-z3IKwL6tH2QvUubjbrH3-O9ToQZx3aeuHgdKdB1Zwv2kMEQvqMMbP0JDeaYjdtAi3RGvLEG9tMzLL6evvnr87
Here is the JMS "wiring" guide and which wire is needed to be intercepted:
y4mJYN4zBipq1YV0VgZCsa8kRGfuNIUKjBYmSoI99aGOqgQTnabfAdF8C89wdDuAKZr3nrDBqMb640p2fHIHdVj2lelG3BOZDqHhhEznbhecqU1MnpIHniAf14dbQMG64zyIVj13Zj_8ftpMmBicQwzenp__tkH4X6MQaocxiAXHDElOfOF0LFcZT7LG2W7ruPM
And here is the OEM wiring schematic along with connector C3239 pinout, the wire of concern here is wire #1:
y4mERjsoNDfwbSasC5jr7gn17sa7JtHGaxZeTbcsriQq0M5rRqwCs7v4p7lWI7xmuAKHEehI6aX-CXjXOOgeZbOagFr63aUuc9uFhtO0A3IT9WEhfrhC_HmbYEXLcu5LFXVWSJN8ZpjIy5YuWzSqxKDmAAyn4ag3JnF0rQVYk7X291m0kYUsAgcY_cI1TzNCYVV
y4mhfg8cval1oQPo_wgFxDwGfjTjBQArIrEiUgkBI4pgoMti2IE4lXpBqHJLYAsFoy_uKEACzWe4yrJUC_nq5rn779aPYb3V1CgiOrClQ9kV_jfj7T2tYFdT2514WAOaqSUGpm11OvGdefWGPorNhboCQx5Zi9yd05FgfVmTH9KPG9yAajJxsz0HSbdTog5YV1t
Tape peeled back and power wire exposed (Purple/Green Stripe...Incredible Hulk colors, how appropriate for the POWAH wire, LOL):
y4mYELg21tlUlivmpVOnGJJ7oUze0xj9NHWrBvRNiB_ZEgygUk-2OfN7suMYwObNGDHySlJaQ8-zjiHW807EqdTEy17XTVYtM2sBEVNDPsRJFq8mtPYLUG4K3JgYoKPc7ejPwo95NcGVhNaCJnLaV2fw224YOdJzDfKQdumTEVNTIdtPt5J47CRUPSGCJIKL43j
Using a specific Deutsch crimper...
y4mGlGuZF6RODLuuVV3H3A5v_qm_EYv7aHWjyHMhBX46Q8DNsZcF3GFYgcG8S9HLN87i8Jgt1GoqNANRqrR3Au-eVfsuCp0XHBc7DMPf-ictTr2pFh3PkoWydgz-KqGU1sP9PUZEq3MpjAfFY6oLKynPLCO_SGkNEE4aHuOUUldB4G4cFYrjzER_GnwjEZCcDqc
...you can make these male/female ferrule crimps:
y4mhew0k7duTmQULtI9bQRL22TiJjqhLzM4lcERYXjphhTEbiXvflp-zXeCe9Tp8g9BbAo1BgiVGpeTtTkCaAtW-jU5IcIYFIlO0yhPrVFA8m-IPhP-W088pKa9wxFDjAeB_GfxS0uOldWtfJmhswM7JEgXGO3tw01_LYL4X4eqD8o-jThzDF16Gb0ZRtcuZpyf
One side done.  Just one wire from the FPDM to this connector:
y4mxKg7oMcbNFe0LrVBLr7kF6BooyLeatYQFcVXmaJmsdUeWCO6SayxUs_6DWGmjTpus1ZeSoOKaAzLCLiagi-iNgygdnaC3bQNfb29ZUsJi6XsLeQmEP6Y7wRB0-cW6SVggwnQyeywsnTyR8lX04NwPur-ngzUmRU6Y1VybTtL0-UeZo3fGYzup7kvR_KVXNyf
Other side done.  As you can see it has 2 wires, one going to an existing ground.  When it's connected in OEM configuration, it goes nowhere, but when it is connected in BAP configuration, it will be the ground for the BAP wire.
y4mDDMVFYPpfVQYqP3YFcGJi9imC1ygrl1T5h0_UnKRaRyqvF7z3VG-opQ60Z--BZVjGvpeb1FYsaavR2G3jSN77ifyjBTZj2VySrwEVfCA_lQvhgSasoodJyPygOSBdLZJEx7kRqMLBu5UEcV8FzyADu9K3oPjX1nzsLEYrKnUUxoSYGxEI8N_nxwBoOL2rK7q
And here it is in full OEM configuration.  I can easily connect/disconnect as needed:
y4mrd3zoQP0zsygkNBmE4dU2p0n9iL_Osqoa-hTo3aPVGgwnEiKdAacvXoBZsTu2fYfOtuGjs-xkw3uQ1lrrC_ScrBMkjq6hKmTXx0PZw5gALf3p_FWPACWFQPf83sX5k1hwkTSW9hg-BLxfHOOKS6sKQXcK9ejan-PyTYned4aiBTernYiGccPXc3xvbNUvzp1
Now onto the BAP connector itself.  The wires are just cut wild when you get it from JMS, but I took a page out of the MSD book and used a DTP Deutsch connector end here as well:
y4mDYq8IO7kMkqibRbBnSNW4pLcasiFt77bDPBNj0E-00Rg5Vqjc_B8cild5qFEUlrILNdpeDZCoCKAlNbKpMwmEWYu3vI7Gjb8IREcNsNmUGxwKPmYWUCtyQKGZF-BdrD0ExGTd1nugmowBvcVZNEdJkPGsoiBUOkH3aQmcW-LLj8OIlGoXd0QREuz24N8OztP
y4mCuxrYBHIGhmPSMmu_FVWyKGisy0MrtKDnp2d5Q6tWKjpAd6rpUoTwh_1yatXF_tCkls_Cz650bXYkCCjtO5o0KMFwX6TaqtpSWkdybFWLZkNk2rITxE8QywrAG4XI9nK82mFnzyJUY5tOl0wzJu_JL9vAv_rAhp2xxzbslGP119dYzShsUaymrt2VGMt44GL
y4mhYPEjVRRg_lYdmXNubwPcKAgsLAsXCmyfesTjKBvULOJqHaStGiMmx3slwJyJg0uvnlYxQ06QYuTL0pKH4hHLu5ZUz_TDmNm6iSJxA5_t_uIaifz204xLFpO4VwU8UKymvJ6Gmbj9xR0aPmn7OJQxh2hzjxE2WgB6ojdWvErOhMgiyo5AdBppdcS7P__jZSD
Now to make the harness that connects the BAP to the FPDM using more DTP Deutsch connectors:
y4mOlsKnwEFUk7yMVd730kOT09sVMYrZVrkey0ZQ5t2c72ktLgJ1DlRVCGhvOgZgFJZmYNJ6567tfs7y1G_udFmjF3lNh521542POLX79k9ltn81Vm63EKEZoMvgors3pyCDAH3vFdFJvZeHCZJKwS_IbOB1LbPxEIHZhGb0viaoOJiwFdG_s29lt-Hs8rq3qZR
y4mc-YQJ617WBQHms-LUPSuTqP6_1GUjES4xx2rgjdYIiV_EpN8c3L5VgvNm2m0Jjl3JQbvA8a3DHEd5Fl_HxuvkKv_qrKT55wLwjBcVfnNxkKW-eAYSCVxzGcDRdLdKgPMN2CEQu1CAOWzayqgmELIfVVK4nHarDKptjHqoJq2D5E1Wx53nOT0KVpSO1lQVi-3
Going to leave one end wild for the time being until I identify where the BAP will be physically mounted so I can figure how long the other end needs to be.
For the time being, onto the mounting location and brackets.  I decided I would secure the device to the roll bar that is in the cargo area.  Thought it would look pretty trick and also be close to the FPDM.
For the base brackets, I used some 1" by 0.25" aluminum bar stock I had laying around.  I cut two pieces 4.125" long and started measuring them up for some mounting holes:
y4m6L_dcQAzVQOa4dsYba2U9p-4IXd8a3beEBYTqudd6zeoRX2OGDvVmUOWf8AVYqqhybkz4658X8tuAA5WMzy-ExDc_pFr25mCA076DyWN687UxiVqbb-f5bEdiV7lUqx7QOkbZ1VRHRHL99hzuu-Lvaw45wuIgKE_Jg8O5dm1dd6etp97_pRL01WdiZ6vPf0M
y4mkA-4SST9elYZQ9WN7er9RKHcqv2VynAm_iEWMaqR_ofn04Ild5jLqvgSJC5D9Js8BMzsYlP8tVq5D5cPFWv7e-vuJNXcj-DH1oACeHISdP49PS_ZXvU3S-QB48CHibqESs7BWZKGBTt3awuZLDQYDh3oTNYM4M1jEa-7ennc9FpOoEzZQygrYV6iVfZcG72v
y4mJMNjBL3f2Y4Qpv95edznFwJmwTcZw-bH9NKD6LNBr0YLxFCv4FjlEpsKUO853Zd2rFpu2VO3v7ujmAskXImfF5N3xsvI8QVwVSYb8gUeP8nR5HGApLkKajTNueNc6ElKn9QeK8hh9_Ti4FSLjh3dwiS-IOQQ3-MZeJ1gFYCp08X9DLz4xl29FPGsxScnGFVQ
I'll round the edges and make it look nice and likely powdercoat these as well.
For the roll bar attachment, I got 2 of the 1.50" Longacre mounts:
y4m8v4rPfOXWspYPpWEvE-lFhghfN3gICEmoIcrmkfou1334XYVB4j1p3rkeYmTLAvHsoKhFq2h_wijN0xorO8lvP0Vn8xHDEPA7z0eM-GsYbFIPcDCWyVJbrXAcL5Mocjfv8JiQTMx9eb_zBuO_aAO_ludR7T69Tc0K7JWUfSN3zqQukT9d8kbB2C5VYuRhgf5
There was one small issue.  The roll bar wasn't an exact 1.50", it was more like 1.55".  Not much, but enough for it to not fit properly.  I was going to have to do a little bit of grinding on it...so I conveniently had a spacer laying around that was 1.50" with a shoulder of 1.60".  It worked out pretty nicely to give me an edge to go off of:
y4mhpFzSXEKV-y8CI3bLfDdz_KngPRJFtvg8G7RLg_rP8EpD9ryQRSE3V5DmXTCF3juolKtchf_uzy9Sh_6isKiiDWP0kSSULM-YqqeN8LHAi0k8iyH2v1TeUUGGX_YX-Ka2nmMV9Rp-9eUcIXjXwud-bEu-ZekKDTRJu7DMUl7GpubHY57byZIRGtQWmLrfSLQ
y4m1wIc7MoiUNLw9pXJrf5mB2Rftq087K2qEzqwpQWNwBSirFhbCGkyR_3ShFnaWoT7OUuCvoglbRoe0uFnMGW35zBcfppT9wAkxihzPh3MunCtCa8RRipGypChvKRkWUzrEJQbw6aXoQ97tNwRcN06xKdnY7zeOkVDlb8CzFNC5dwHf5rhdYuqSu5atns_ct4K
y4mSv1G-6DohJwoac99jurw4w7IXYN-vevJPVUiUzsDMXZzaLD2YYVC0sqqzcyzLdRvNV2cqUeIOe6_W3SzznkD_t18SygwH96XMudWtbQSJz07Nz35oZo3uTI2f4A3Agi-HfW1rXt5G_sUNoUiQmppFyK_d3CHDQMU5M3JTY3FGgFpCG4kiqK4qPDk524ZZ4M1
I'll likely powdercoat these along with the above brackets. In addition to the brackets, I used some of these rubber isolators to give it some vibration dampening:
y4mCF9DBmtRRx3sBBBhyTe3EtGZs9IYhJXqSYAId-xXXKZRWmlJSogB_Jr3X_N8cNNq75acdGNuWrFyTozLAq7RuJJK7o95IAC3wi5Q4MkTtTWb7BQLxS-CXQIw1ChPGq61xqSQNVst1-b4p4gLbJyjZBJ3bKOVI-bdMHu-t6zh8bm2FJRxSxP-VvJS3IOPi62O
Here's the device mocked up:
y4m4XH48Dm8hau-ZkMg1xshX83XvfQviwP9AE-wR0xZDYDlYpu_XsCVQjbB1J-kINfuCWaxtSqrRUY_BHQ8Y4t8BVNdoAEahFht9RYjATqBRDoFFe21xbJs6Y91CC3bdgNg5bqY1M9TdvqIvrpIdnU6Csl_zHHoYS7XS0Lu89VpEcV93-5bU9-1NufCKOvRpVmx
Now I can start making the connecting wire harness.  It's running behind the wheel well panel cover and up to the c-pillar:
y4myRhDUxkcY6cMaeJ1a2leEA1CqyZOQp2pwdGfNkjvncotPFv6tc3Lja-vP9T_JyQwg6FxEtDGWWqscfp9etB0ZhJerA0tVOzHbeLNo3DgZ3ZTGVjfNEr1OHRUhfowLpVxW4OrHjU3g5QNxafLYosjSvS_Xvc06hnq91vJ3cF3fHvTbvNx5vhe2jhKxvzyS9tj
After marking where I need to trim and where the terminal ends need to go, here's the final piece to the puzzle:
y4miMAwuxbksOgvU0IQETZE9WpVWjHWDwgHrN8kolmrTZdt-lbJ2n_5m9-96I7VpZyj8nZzHMM9MT30XLIu7QgRcGs6UFQA4d5uFxaQQRd8aT3GBAIsSEpIVnTMkOB2QOtxlLEjdSiY7mEdWHXdryxT_bgZnXMKryKFCp3N9jeU5FvaMPYYH-jCz2pXIkj9S3pH
So, JMS calls for replacement of the FPDM fuse and upgrade it to a 30A fuse.  Well, it just so happens, the fuse for our platform's FPDM is already 30A (the only green fuse in the photo).  It's found in the Battery Junction Box under the hood, position F65:
y4mTmh2dT0ppZgxDrxGFt-g2wBAaCyXTkypnxqPulvRLvCHiTQs3pzIRMFpbCA3EpG7DuDjhc7WxnuOwiHjzkrM4H5owYfVE2ee1Wg-m-HX-jNJzD5ZlIxwrBmqZaIwdjGJyTmIW22rqXn3Fd9XyDNKxtk5aofOGmPLqIzKUykVEGM1Omcztkil7oKZzMn8SyLX
Once that is done, now it's time to crank it up, do some testing setup and test this puppy out!  This is a hot mess as I'm simply doing setup/testing to make sure everything works:
y4m3v7LMhtplH1BjL5hXp8n6aF_1g3i64eT0udzyrfYhIaeTvw8xTdw7HEISDkhG-Ow249cf56haaKC1KwMWsPDzbKu2DvGS3c8UH7MZduRaAXh4eMZmgtEeHWDo65M4dtOtyARdBC0mNW_7PTeeW1updmSgqC2-8dM6YlSneOy9iBLBoAHRnEtgrR-1XNBnHvZ
So, what settings am I using, you ask?  Well, According to Deatschwerks, the pump is good for spurts of 18.0vdc.  The highest I saw this at WOT was about 14.8vdc.  I want to ease into it for now, so I'm not going to go over 17.0vdc.
So, I got it setup for maximum voltage boost of 17.0vdc. Using the pedal position sensor, I want to ramp it in using the largest ramp the unit allows for, a 1.2vdc sensor ramp.  I have it set to begin boosting at a sensor reading of ~1.40vdc (~20% "throttle"), which means it is at full 17.0vdc at ~2.60vdc (~55% "throttle").
During testing at idle, it sees standard vehicle voltage, but as soon as the pedal is depressed, once it gets to the 1.4vdc value, you can see the FPDM voltage increasing.  Now to take it on the road and see how it responds...
...road testing turned out interesting and I'm actually very pleased at the improved pressure readings.  I did a log both before and after.  Here are the results, all else was equal including the tune.  This was a 3rd gear run from 2k RPM all the way to 6k RPM.
Before BAP:
Brown = Low Pressure Desired
Green = Low Pressure Actual
y4molpTESeUejMqPJEciOfkFFRAOSk4e8BUItiQM8uj6n8EpKUh16PhliMQK3QmUM_1Wsyunoxs_CoyC8AgR-UF3ZWqotA5-9rtQhnAY7gfgQ8rN13j2zdXPeBpsTCGE3WH-pFe6Yc0GFuGJbBLxdllrAmGtiJbPN_zb2YaWMoMz_B3T6M0icLS2McgANeQf0FL
Before BAP:
Blue = High Pressure Actual
y4muzEU7GsaWKKmev-xkN7WJ7_EZbVdKX7u_8g_bewjuI93cmquo6AsKIzh82UlwSvIEmDOq6_RYBGf7nFN2BzIDHu3sVXHaPcc3R7vC2GSgkqHSo2EqU7rE0z_OdrMEBBCLvGcZi0TkHXb0kd3xUtjTr9-QIdWV7PNlDvU7UJGTNE2GOvx3Im9sVfBDejercwJ
Before BAP:
Yellow = High Pressure Desired
y4mw1tu3WTxh4vYaaQO7LD5MOAbDZlYZ9sNlZiCYUnj0HepqHioupT44H6BMfidQHx1msy-Df62-llR3pZ-iTb8yiM-LRU9nJ9B1yag9daxr2OPqnq1Nr1P2t0xttTIhEP9vI7r8acKEIRYA8Iu6PzuJ-vGvfgyyYHVh7XH-AU-RMQ9yFDxggABR4IaBeVuEQ4V
With BAP (no tune revision):
y4m9P-xqGPNps7PYtdAJZvwT08F1yTkt47K6I4uv8DB8tJuO8GFH2vmmMynvVcsBZ41AH7NrFtf7Hzul2MzPy7NJwJiWSsJVFVVFOll_kD8m_z-6Q5o9ZybIL7DaOSYqwxKX4n3nXzm_D9tJaanfA6EwmakAKd4y1XPsBS-w63ucEMtqKNrfLKmjgfmVexmKHJA
y4mFDKS0u4D1cCAllUdGug6mMkMOl193J5lJ6KDw2QqCuXQUVFPpY0LYx2qRCMdIGf5OZahzhQukL-Xbf1zPmndHNjieQVOpvh_fvXVhsD3qXah_aDcwFWW0fLFHFShnxGTAJuWIeIN6PplieiAvoVI57q44KcP1VPxC_uAThSissmwThFCmdkyAEwj3G9zC0UB
y4mvu0yt1PoL_MmuHW70pxMsyrtgrG9QRX886z4kXSEwvUmDluhajH_2cjteGcYCNyZ2phwQoZvgGavF8Tdq0ceVGXsA20221MX2iiDnR3HDQqKR7TR4Octaq2G6jWocQROwazghLM87owqHVBc3-kv5I3QPH502595lzPCEdzpu4egp3jyn_9wwysvJBEEG1mt
As you can see, the low-side actual pressure was quite a bit better than the run without the BAP.  This tells me there is a bit more flow.  It could still use some help at the end, but it's markedly better.
So, now that testing is done, onto final assembly...
Here are those brackets rounded out:
y4mWgHSN_mfBK45mTYfZQP2nPleyzyfxH85fZTYZju9oN2NrDXG8l3nIfvl1Dlz_nnPkXfMdlOixcNeqt8_2mhop9K-rlxKoVddwk3jjJzsgZMFP96F7NohoexoipFRgYrsAR7Qn31wUTe4dBo31eGU1Ha8yOzQHEt0riADl3C2CBMEU7r0wZceifvWgiDtKUg-
And all the small pieces soda-blasted.  I'm leaving it raw aluminum but may end up powder coating them once I get enough other stuff to make a decent size run:
y4mZWqjNuiEqW2MAUqPyoMH4f1bJGLPBgY694m14Gg_M4PHfxtxug198w6IWzTwxWVSz5RWIgwPJmwdeSE45cFDUZ6RseeWpgGFJecfz5CCvXYcqt9IUaTMclcYrp83am2jmt88Ad6u8f_tV4pQ0YPznWnFdfqwTgeJyHnhTRBOD1m96BY3HyfOEOKjllsZJ-Lm
Secured the wire harness behind the interior panel:
y4midnQz7kOpcOuWaHbGyASUxpvLl9KSwWdr9wzeznplmoScEor4xzKiGW0AQ3HZSu9CUyjNLY1JBF64YI9YclqBqnyTAoOKOK0b1Q6tBOeeHcLld-uh52VChFkZVGy9hn0f5BndMLfAMEGaC9YuilpGz6F3YvylEGhmg-5ikrrrvjCAD5oew7qWC1l-LmxlvQk
Final position of the BAP:
y4mgjj1XjcZfteMWODTyKYtVSG4kQzWGUadB9cFi-TKnQxGt_K0KafxZ0x9TKYBS8n4pMB67W7zUip9TJJ6GKj3kZvaAAzlgEfHMTEVn6bAAICtIyFYMhta9UTNOs4ZC89ibt1FW3YKk0ZYsnzMzUeBk7mLBVfjB6a1bIDwcv8oV6YrkyLmDbJ0EoO6JRol5JJ4
And I decided to leave that small c-pillar panel off permanently for weight savings! No, seriously, I'm going to leave it off as I may need to access this area from time to time.  One issue is the seatbelt goes through it.  I've got the airbag seatbelts so it took a few steps trying to figure out how to get that big click connector through the hole without cutting the panel.
y4m5J2U_aAtUH6sCb6nSRrsA6rpzKBhaOKd8G_REBKRvvKFEb7RPIrqL03kurSvzexl9INH2qPvRrqNi5-deAxA-UqpWLkdmyAIm0NO651X825cQeyAxSkUa-FxwInu7BDaOxFBteZnSy8Hmv5HozdDB3JFT4KjnbKmxR0S1negZxxEVyAqzCKPY7DT2vX3YAL3
Separate the plastic halves.  They just pry apart:
y4m1n1bderlI0lbxVP6DeX7BlSnlraZbz9WbPuBvGbe382Pf77Gl2Qy9JUb_OSXUXX5GkUVoVvrwPEnIT4Rtx42K7hX7VJHiu_fjYaMS4zSD7bfhysZTn41HhNSIlYPnn3Gdj79bOUtMr7bH218hETwBJV9CCpHSa69wYszIbN0DOsE6U1mUl9sESceEKZxz7QZ
You'll have to push down on the spring metal tab under this side of the pin and pull the pin out.  The tab holds the pin in place:
y4mKRFgkuIiqVkUKsUqY8fRvWm8uOpZLnjCiN0Zvn89m2fGKwfyMwBe6rGIoBb9_FXwrjv8DSr5itnoqUDmKVeOiQxF_C6h3xeo_tWCIAp7fin7UtIPLXpAxgrcvSU340CgdLC2msoxCRC0Hu8PwZAVXQYIuSs4zPeWzQ8wYerTmu3srxxApSYxRIWnjt3U38k3
Here is the pin removed, and you can see how it holds everything together:
y4mEppGZ3xzHeTcCP7TdLkF2Bs_GKhFrvgfLES6S6py8B5V62fb1yn0ldDw8cIhqL3EmE4aLaLPsF8gDhr9tFOZ-WroEoWYdZnJBKmPgEeWr7QxtkZQc9E9qwU5eb-c3n2IipUrM1GsNXHH3S-MeF_IPp2Vf6Y2Y8oQKDf0qpdRyJqoPieVX0W5jlaiJk2dfuNg
And here you see everything separated.  Just pull the belt through the hole of the c-pillar cover and re-assemble the seatbelt...too easy:
y4mKqC65hHlrspTWYKxOS7KImv7xh_axxYbREVOrhJMjPjm0zOgo-KFunHhTlR0NhHf7UXARe3gmKwNs81QXBLQkHcFCyMzgjnspDT8qNGT5MzVa0X78q1Njs7IxGMwxJoA4tuPcjBMCd7GPYDiv4LW4kE1ANTk14jxe0FAea47GDoBip9I8kH3UGG2NoJZwIQd
The trigger wire that goes to the pedal position sensor I am running down the other side of the vehicle.  Here's the other interior panel off:
y4mwhTz2jqXevj9KGcG4sxZ_PkuJCuQ-PSW8Ykx3chdTiSLOaFkquibcrm_S7RCkp8wiIDUQHA1g9xubvINu1TMS6Ddr9azvAnQ8ID8Q1HOUwXgZztochQMqQY1oYu2p8i6S820KIRlAtw_o1x5wQK0zHm4Jdl3avbI4XZV_5P0FBEqsPqztQxsZkjXJt4jyzjX
Running it down the rear passenger door sill:
y4my_dQIn3K0AfyIHjfITen8bFRv4G2UiAS2j3XO_D8sN9TEvetzlo4po--NV_Y6bcEWRIgdED_Aep9wKKOyGHPZu3MQKWKXahXlNhQnNHvrxeHLRBEJPlFfP9uEVW46zEEdwVpkW-OyLvFFOtCoZ6jKSmKZb4Zz92tSlh3BCOnzCYHwaNkbERkTrgGgqW6mzVs
Front driver doorsill:
y4mCrSe8WTvB9P8YDiH0bhSOdIW0Z0gihG7cK-asxDg-YZHySexGYje9XQjpvSoE0bGuwuR-inu-3JHJ4a9W5yLTXuGBNQM9fcQ1UTvUgBdVYeEIt546y3fxMhfNCkQ9VHAsuFrMvZS0CDB5mPorlBqW3z2wrSjkN4yH-ZrsVrKqXprrsljNuz4B1PpxKQKfFz0
And up into the foot pedal area:
y4m0KDe--xu92wF0gIqPu8hG0XZJ0Rg4jB6EDuGWwq5WkGo6G4bKF1WqGZdPj2-XmIYE5sQckcbGV54iTSXtkcFhKViufXwSU_4IgK03CnOPo3OJ8QvQc5ZNNcz1RZ2Pn9K0MeCzMER_gHyvoRlxypTI_HVopulRhvGdU_kPXP8mDYVs3VYa-YLRwb0sHysWpoV
Cool little cheap tool I learned to use when I worked at a car stereo install shop...a very large HVAC zip-tie (36" long or so) with the head cut off.  This is an AWESOME tool for feeding wires through places...get em from your big box hardware store. It's definitely one of my "must-have" tools as it's been indispensable throughout the years.
Anyway, once the wires were run up into that area, everything was reconnected and tested.  All the interior panels where put back together and all is done!  Now to go get some datalogs!
y4m2iCVw_-BXVEFCvRhSYUF3DwZ72Mm3JHqG0jI7vaA-_E1bH9YcmnNj50_0oa39Rcm5L-cHVaFaLNpwk2DAq8SD14vMX6MsPeIbN8N2UV3_2lo9gpL5rpJ2DEgBRVomMog5KOfq7aeuASJd1QT5shu6YPtSMscE2fcOVv4ChKLbP_tqUGxl-upRsyXY6RFn3KP
So, some results after a tune revision (btw, I'm still dialing this tune in with Brad, so this isn't the final tune).
With BAP (with tune revision):
y4mLV0stZSPN83KBKqlVtsEgbQ9fSZO7kMaKC5jTnhK9Jrxsp9a7Vb0QloYTHkr0-X2ydnBeBgJhN5LJStzbmC7a_w0g8qS-UUlBxkxfGAaojzBH1wL5M5cTElwt2Lw6GLmfSUMJctgngxal6Ypqf5qq7XG9xE69oXPuezhHlWeAsa9_QG2vo4vzjlSBAkfu--0
y4mnN25oNiCAwGiNRyi4waSziKFutg2c2x44m1fC1xLxu7rgB0YMCmdBsEQLY2nbpING-On5d6IitDUBc90CQeRNfmmTQjNzTKx9CC4b-Yz1PwdYeaVogNVbmVxQlE4Paf2E2dvthIincWRqw7xVBOfYthWsFZExbDjM6205otGHftfP9F-cKeg4gyNdwZOuJEw
y4m18JTwK8OwHngTHAiLgasPsvZ0HbfHYbPVTCkGqsvtS86rIxjL_wAOaDEg3Obe3OKxVFI_m1f9wYo6CMmuq3ia-hjrJ85Ya2ilo6dxiQ2Wv0ez_l5pqgSa-unDskLYI6n-Ex0sJ4qliVa9BI6nK0UBfT8vptWhL2YPvAOz3sUXFq2NBY8HCUb55LxK-Qq8EtJ
Wow!!! That is quite the documentation and build for the fueling! This is awesome. Thank you for sharing!
The improvements are clearly visible in the data logging.
Is this running E85?
Yes, full e85, but the tune is set for e75 due to quality of pump ethanol not always at 85%
What load are you sustaining during those logs? Curious how much air you are needing to fuel.
Apologies, just getting to this.  So here's the logs from the same runs.
Gray = RPM
Purple = Load
Without BAP:
y4mhNTBOBSzLX5onkUawoX-5JqYVq5quCiD8COltXnlccK6fCwIGuYuQF0dffpDJ6trCtCchQlF37kK86C-V7iLWnmq7zMJf1INf93S2w_bX74yr7NWdXV7xwxI008aBqO87OIkwnOLkfhxop7I_0RXdlCT3v8is9KnHzQ04PMlr3tvpmb8hBIJM4nnz3dMPRTM
y4mIwjKE2AEUdm9SJRO7e_LlRwejR-bw4aIGIJ7JulcE4_-XHm4pJBCPqgO_M_hwb530N8fr-nmtPndxuMHRdOTdQay6rqOFdTlmhT4Q0l0JthQ4owIup3fmBToKrb-Y_p11Pkrn3zOQ9o7svaIQ-j8684GORQiKnC80CEu6wspPjLyF7Yb1QRbmGT7zblnPjqQ
y4mXBFO4jstbcgNzBNWUhH_XDkrgysv5GjDccWB1mj3uS2U8CJp8THoNthgjABxbFg38GKCff2QhWKOkC0ZOqrp4gtsdWrX_23CvDUXV3G9dAYyn2ZdqYQSVR3HojRp6Q-rh9YrTxR23EF9bp41Ai8qUhWTyz3iTgkwBoGK0jhPEORBwwBmXJ1dh1yXgVJnqJna
I don't like the last datalog I did as I was fighting wheel spin and you can see it with he way the RPM jumps a bit.  I can honestly tell it's got more power, I am having some traction problems now.  I really need better tires....
Access The PCM And/Or Wiper Motor
In case anybody wants to access the PCM and/or the wiper motor.  It's actually pretty easy and accessible.
First thing to do is remove the wiper blades.  At the base of the blades are bolt covers.  They just snap onto 3 sides of the six-sided nut.  Just get a flat-tip screwdriver and pop them straight up:
y4mhXgYXalT4A3dKzz22BRcZfYOFwSLVdDRbGoeQ7lW_wl9SNx1hbFM-p-b-dTjqWYR5XTreYhQxj_ZiAbBxI2My9E5K_0L18wyMz8Wj7qRm7ASDvo8vjbxY9HvF7nuiWcXw4C2-QeH_MlLHzVJYN4pU3GzYJ_qQGlHtNQBaonqlCCcpSnfrk04sSCESF9CG9fi
Once those are off, you'll have to remove the nuts off the wiper arm studs.  Once those are removed...
y4muE9_jmPt3Y8fSEauNI6WXS2b830Xh6g2KI2N6grN2O-LBqQ8Dji2_zaHHDQQ3WLa3yhak8uWEjDWoBgHZqH6zg3-Vjj-hzAPH8qptFvv_OSCi9ORHRI3VJcZDLkVgBxGHPW3FOIm6QW3RHngkK3N8RM-vu4MCwHJSETVCq5JSeq_qwL_wFrSHhtgRInN7Bre
They likely will be pressed on there pretty good.  Flip the wipers up to give you some ability to wiggle the base.  It's possible to remove them by hand, but easier if you use a tool to pull them off, usually comes in a nice puller set like this::
y4mN4chbn5QS95eKrhsA4kxmZ56NlYBLwIn7LG2gHvSdmvP-ELFRF7ws8o_Wwz1GstO5YvQqDTdsMdpNDR14YNGjA-G6WYhS-ptv8kVxxBJwiFUBS1tSjkCbcnDXS2BlAgGT_tMVAWl6lJYEg5m1SUVwHexRAykDNFdMGZ8SLuRX664trY0k4zV5W-DCDmcr1yP
Here it is, ready to pull:
y4mUAFuWeaDogQNIarJMU_Qzzwi9XvBMxbVr1KklhGxaRxvJvC2wEQiKPHfFFx8oqThRGiwlHiWE_xbMCLmpcNGDfih3SfsgJvW5I0ky-7BO5t2crdeRHaOJIHvUlsN8AUWpEzHXaOEZfGWahemBhFbHWv2Y9cfZMesI7yX4x467i1sB-L8-RfTewO_qnw2Pqcv
They pop off easily, usually with a loud "pop" sound, so just be ready for it.  Once those are off it's time to remove the upper cowl piece.  There are 6 plastic clips that need to be removed:
y4m2fAVeZwrp0zYL3O_h_mpQ7auqpC04CVLydizj2iirgvQVKWsJHqp-PF3OPzY5FCpoUNPCW8AkdG2POCmptysj2YqKBn1E-CmSn5q9K3GgXywfGqc_kOnf9DxzwoaEw5GPwd2fbAxwo5M6FRp03EXD8qjcysKGYB5ESAh6CCD8LANI3EG488vouLgfzGBF0pr
Just use a Phillips head screwdriver to remove the center section of the clips.  Sometimes they just spin without coming up.  Just use your other hand to pinch the outer portion from underneath.  It's also clipped into slots on the bottom of the windshield.  Just pull the cowl directly up with some force and they pop out.
Here it is removed and showing the lower cowl:
y4m9-eAiR-Uib4Rlq-Q8m9_zNwh940qT4sXY0fsUzyc0rGuAaRxO1DWlNlqDxlvvQy8uwu3ep80g7gQpV0muGlbk_J0NBdPX9AM5gQc2HnCzsU7Of4gar24sgYCQHK0ikK8PjBq5WqBKHMoxZf-XRBcn6bXMPUye7IIxI6NVVGDr60P6qYEYZdThuJ1GCJm6p38
To remove the lower cowl, you'll need to slide out to metal clips on either end of it, where it sits on the metal frame:
y4mXWm-jyz5aYuSNxGWa3H062I8pgThP0F7oSmbcl-v8E9KeKskQ1GLDhD6saR1Bg09KAR_oo92LJsLYqiQHS31PH6eZ2BPHMxotnzfsR-7u9r6Xv_E-AQ8CUVi6TP_1kBXAM4xXN9LQ1tnKkv_-ZDqR_0PY1snvJaeHCsPfyj0FjnbWqmkul4zaGCBlNihSFj_
They are in there with some "bite".  I used this tool to pull them straight back towards you::
y4mOJ2_1O8jHkUR3SZrLQGX1wSicaUyDojftZ3vB3R_VeDVnm6_vNa-jNSxE48O5kx86MEr9LR6iSm9fK49aAs4gQZPjJVRW1Z5a6OPFP04_hohE9jOEF6YWU3Wj6_s7tfv8HcwxsXPYzAk4jl-N5aJ3JlbyNtXFrI_kOKz7SSghvXIK9MWvvOdicbtQB2A8E1C
Then there are 2 white clips more toward the center of the cowl, same place where the cowl meets the frame:
y4mJiQbYd2oE9RzKusANMp2OI8tK2J4icCrs0Hmj41FCz6XfSC9FSswrZHJ2u9_zhIjmNPY-GONsHXdA_wAcepsaOTjiGk98uQMj6IniJpQkWLhPVI7FH1LpnFt3XL3FuQEt8zrPh3ne_WZclAZifOjUgB24G42gTLseRT4egMI4nVgw-3HxNjNMxQ2CkLyKkDp
These just need to be popped up.  It may tend to fall back into the hole, so you can remove them if you'd like by pulling it straight out.  Don't loose them, LOL.  Here is what it looks like when it's off the car:
y4mgXLJYn0LabRoUz8mDwxO3gWanxBp5CYf9SGsTcIpNzqIiYj8S2AM-8ryF10JXC3RD8Vvls73cQ6TRN424g1fXyxkpmWsmjQf8EsVyJTMypwCQXJjSWdGkz25X62L3jzpTj-jxZcE9Iyd5wysd3n3I6_sMWflnDnU2z7FiH6xaH5EiuKlMeRcqcMxt0ZSdvPr
Last thing to do before it will freely come out is, open the clips that hold the washer fluid line and pull the hose out.  A small flat-tip screwdriver will open the clips, no need to remove them from the cowl:
y4m8z9525su6DXKdB4_b3KF6v1QX61oT-pSAC8H_4QCMUDEsrywhD3szsvw8Q39EgP8Q_vai8ARzyZEMOlHlKC4XU7SXatziyfjKv9yzuk_z0wrIPdW3tKdqqzs-zjyy7tKZWPXuikSSVRzwATF0aYRn9JwWe5fe-yuM-ryJ_O-Cf4OA4rcuXYOZRA_ZyqgjorM
And now you have access to both the PCM and the wiper motor, whichever component you are working on.
WIPER MOTOR
y4mfSnzDMksFgfOFmwpokse_sCSZ7pKx_Aejj-cFJIKoTiYUDpiP-DZii7PufZ4JZVCVs6P-RAUHyLmFsQuN-8ZdLZJl2oMGzg_xM07-bTQjD3Natrefz1G9jRq1g_HAA1nLG6WDTXp1gbdd04wxkKppmFXK4C9WMxzGrbhtii8Ibz7gpJxV2PXwXpk64siIY7g
Pretty easy,actually.  Just disconnect the connector for the motor:
y4mFwsPgCMkRQDSEUjGeapqb6NoUUApFtyT4t8YYlg6CIIzftby6Ws1LWNnC3qwZwMSMMvKlo6P2bt-Y7O0UK4ezaX8jt76kGr1s6H53UANgRpNd0ItuJ6f0UP2e6DmyasW2itjlZq5rs0ftBq2kkzpwgfsZ9js0TGZcGKaWo1z8-_-BZvoi65cvqR9jBZArOae
Then remove these two bolts:
y4mkKwPqS-lIFy2N-DfEox5NzyHFwDjjhnDBPZUxNaLon_dMLETjkrnTIezEEpX7k1ctoSt4CEKZHMqOp9wNMoXPIM384Dj-vErv8f8Ay6peE-38y_C_e3HH36LIaLlAFxg54o__g7mJIqIM96C797RytA0bf5DUhDlGvjShpI_t9kq6j17kuHtiOoAX_-Kq8CL
And here it is out of the car:
y4mMITIACewMR6DEsijxsrlTzoM47_c4A45alvgIMmPl1obwjUwUMgCG9uLZW3l98Ay9W5MOrLMsvxC41gufzI44aGhlQlH0bMplocr1MFE5p9j9JPe__GKH6OMtiiymkugqVPjcqkgPNi_PlRmrTAHr99IvJg2S0GAWXA9q1eABqZ9LW_QLi0kQ25cyUGHYt3s
y4m7sjQwEjoHMwxn93uu9ZrS5WmpwRpEsHf5ZBHFAu0D0ccN3_m4IJJDhfXRLfqY4xa9Y8aUdKjool_MV8j9PukbrkdXfxOxM7nwhDKGrRhvz9zkqMpssIlZFemroN4eVbE_j86eX4Ez4yNVmanJpC6aG-V0zVFCwOL-hsx98Z_A85NLoDnjjIIAIw3o1HNVfy-
PCM
y4mZBHDs04B6BENfLaTfBpG6TNXLMJhjbSK_35EKFYaOqr1fOa971Oy1MHCcDxj0n12WxgDoLP1qgd7ZdSn3XYLwWImqaBiFkLdVmr-vKN1R8kSR2OPeOhoCCvj4VQDH3ZB0yXcLbnWKsA5NEOiA-03yvRs78ODlSaJQkIvElxfGQI9A8lf-EH5HEsQp4n66Yw4
Also very easy,  just undo both the main connectors.  Do this carefully by lifting the hold-down/lock handle:
y4mzP6o_CYx-mLU1lMHz_auW7YT8PN-V3Tl-DGuND6rPar5AMeoDLKsL689z29gxcWwcfXVqgu4rn14fJ2f-0ssj8oUe9Mty81Dl6lvoJ2RnqEvmxtgRQXNefnYlF9nYMhBTzoQqwWK_OJLAm17eoQQf0ms7V1SJUGxXOqxViA4KsgHwMc-K3L59cMM2FcPiJHB
Then remove these two nuts:
y4m6LdoBGf9USDu6Veeu468ogTwrkxJ1daDoWl6fQqyInW_ZfLEfcxIx26yxFWb5U9koGGVG81yJjrm1P-4Vt0Itf0w4c9m6YjyRblOIb79xEHGgMZrRUglP_TaCW61OdxSoqDN3URjQ-D0xZiniCQqf4lUNIUwty7c_-kEkOKKlJsjkFY1nhhfU9KG3U8SXdog
And pull the assembly out.  Here it is free of the car:
y4my6-qQpsUDmRSJjj5mV46o5lwKT9yt6QLn7GLURtjihTYekSXxNgB4vQbb0JhLaUPOpFF20K5ANrDKDBZhr80_jLMEWvdbKoQL-hnioqHPWD0W16lfTRzhuJspQVzORpvZ9QUP5VVebEzB4zneqJIW7ZHJpQcP4zQc1Gk4JEK0J01kjPPN_y4uPuT4yFhCKOp
And that's it!  Assembly is reverse.
