SM105K's Ownership/Performance/Maintenance Thread
Couple of things.
I took the ST to CA this weekend.  I have the AJPTurbo Flex Fuel Tune and well......  This is the first time I have actually got to put E85 in it.  Holy crap what a difference.  Ford really did it right with the ST and its ability for the tuners to be able to do things like this.  However they really dropped the ball on the SHO.
Couple of takeaways.
When I run 87 octane it gets the best mileage by far.  I use 87 on the long drives.  I cruise at 91 mph in AZ, and 81 mph in Ca.  Car gets roughly 25 mpg at that speed and really never see much boost unless I am passing.  Even when I the car sees boost there is no knock.  I have seen as high at 29 mpg at the proper speed limit.  I don't want nor do I have the time to drive the proper speed limit, and either does anyone around me either.
I run 91 octane during the non summer months with a lot of freeway driving 70/30 split with in town driving.  The ST is my daily.  I am averaging just at 24 mpg with my peppy driving.  The best I have netted is 27 mpg with non boost boring driving.  Since the air is colder now I lean towards 91 because it makes great power and for my driving on the freeway it gets the mileage for my boost happy right foot.
I run E54 during the summer.  I don't want to change my driving fun because of knock so she gets the corn during the summer heat.  The mileage suffers, but the performance and my happiness remains.  Best I can scrape with my normal peppy driving is 20 mpg.  Mileage really suffers if I use my right foot heavy.  I have seen it as slow as 18.5 mpg.
I ran a tank of E85 in Ca this past weekend. In CA E85 is readily available, in AZ only E54 is.  Holy crap what a difference.  The car was pretty stupid.  Way noticeable power and a riot to drive.  However, on long stretches of sustained 82 mph, she could only muster 19 mpg.  However...the smiles per gallon were worth it.  E85 was $2.89 a gallon, and 87 was $3.89.  I probably broke even in price point per mpg but to see what the car can do on all fuels is pretty damn cool.  Also I had ZERO cold start issues on E85 in low 30 degree weather as well.  So that is always a plus!
Hats off Brad...once again you killed it.
For the SHO:
The splitter arrived and I will be working with Andrew (802SHO) on a couple of things with it.  Should be fun.  Looking to do a couple of things to the SHO in the upcoming weeks.
Splitter install on the stock chin spoiler coupled with a paint polish and another ceramic coating.
SM105K said:
Couple of things.
For the SHO:
Man I bet that E85 power left a nice impression on the butt dyno!  Everyone that can safely run E85 ... Usually does.  Would if I could.  But maybe with upgraded fuel pumps I can do a tune revision with Brad for E60.  I can buy a barrel of E100 and mix it half and half with 93 E10.  Make a nice race tune with it.
SM105K said:
That is exactly what I am thinking as well, but just with pump E54.  YES! More money to spend!
This was your idea...just like the No2.  Going to have to start charging me for your advise.  Especially if you don't do it but I do.
Oh yeah huh......
We are square brother.
Installed my new trans cooler over the weekend. I made it way harder than it should have been. Grr....However, trans temps dropped at a sustained 90 mph in 107 degree heat to 200 degrees. I am happy. Also it appears my trans was overfilled almost by 2.5 quarts.......I have a theory on this.
When my trans was replaced at 3k miles of break in I did the 5 out and 5 in. My trans dropped 7 quarts....I should have know. I put 7 back and and checked the level. At that point it was high, but not crazy.
Working on it this weekend I wanted see exactly where it was at. Ended up dropping 2.5 quarts before it was happy. Geez. So yeah.
I also in a hast to get to breakfast closed the hood on a quart of trans fluid that I had placed in the engine bay.......that caused a mess and a mini panic attack....I am an idiot.
Macgyver said:
Oh No. That quart must have made a mess. Glad nothing broke.
Where did you hook the cooler up to ?
It was interesting to say the least.  I just used my stock PP lines and used the AN fittings to adapt the smaller line for the trans cooler.
Clean install...well it was clean until you dumped a quart of trans fluid over all of it!  Lol!  This is coming from me, who pumped my brakes and forgot my driver side caliper wasn't attached and pushed the pistons out!  Lol!
A good self chuckle is all you can do!  I took some extensions for a ride on my wiper cowl also.  Heard a clunk hard turn ...then found those extensions...sigh of relief.
Hahah it happens.  What can you do?
I have some data from my last road trip with the new trans cooler.
I drove from Phoenix to Costa Mesa.  Roughly 360 miles.
Okay! Hottest the ambient temp got was 109. Fastest I got up to 105 mph. I averaged 88 through AZ, and roughly 83 through CA. Hottest the trans got was 199.23 degrees. I would say that is a win for the upgraded cooler.
On my return trip I averaged 88 mph through CA and 95 mph through AZ. Through Coachella (big long hill sections) in 113 degree weather my trans got to roughly 205 degrees. Ambient air temps never got below 109 degrees from Palm Springs all the way to Phoenix. After getting through the hills, it leveled off at 201 degrees. I will take those numbers all day.
All in all, good upgrade and I am happy with the results.  I can't wait to see what the temps look like in cooler weather.
Funny to read the above, as I was just watching the morning news, concerned about the mid to upper 90's forecast here in CHI-raq, coupled with excessive humidity (dew points in the mid to upper 70's) and I noticed that Phoenix is set to have a high temp of 110.
Holy hell that's blistering!
Glad to hear your new and recently upgraded trans cooler is keeping those hot AF temps easily at bay.
Keep staying chill!
Keep staying chill!
But it is a dry heat!  LOL. 110 is warm but not too bad.  116+ is just straight annoying.
Incoming Upgrade:
I have needed a HPFP for awhile now.  I have tried every way to justify spending the money for a XDi.  I have come close to purchasing one more times than I want to admit.  However, I couldn't pull the trigger.
That being said.  I know I will catch some crap for my next statement.
I recently purchased a slightly used FS pump.  I weighed the pros and cons (they can attest to that) and for the price I couldn't pass on the opportunity presented to me.
What I took into account:
Yearly mileage of my SHO: Less then 4k a year (if that).  I don't daily my SHO.
Mods:  I have all of the supporting mods (minus turbos).
Single Fuel Source: I should be able to run straight E54 out of the pump.  No more mixing, just testing.
Fuel Pressure:  I won't have to worry about FP drops anymore (my stock HPFP recovers well).  I still have boost issues, but this should basically allow me to pin the gates closed and let them eat.
I have only seen one documented FS HPFP failure (not all facts have been presented yet) and one with XDI.  I know there are a couple of 11 second SHO's on the FS HPFP as well.
I will be removing my stock HPFP and vacuum sealing it.  It will make its new home in the trunk with the exact tools needed to change it out.  When I go on long road trips I will swap back in the stock HPFP and change tunes.  When I get to my destination, the FS HPFP will go back and I will reflash the tune. Then the GAP band tour will begin.
I will modify the foam and engine cover as well.  If I cant see it, then it isn't there?  Correct?
I ventured into Intercooler cooling lol.  Bought this off Amazon.
https://www.amazon.com/Front-Windsh...sher+nozzle+3w7z17603aa&qid=1600441530&sr=8-4I disconnected the washer line at the junction near the shock tower. I ran the new line in the same path as my UPR CC line. Routed it to the front and used the motor to drain all of the wind shield washer fluid out of it. This is where I ran into my first issue. When you depress the fluid button the damn windshield wipers start moving. That is no good. So I pulled the relay for the wipers hoping it wouldn't kill the pump too....it did. Damn it.
So I made the executive decision. Who needs wipers if you just keep going fast? Haha! Wiper removal was easy. Take off the 15 mm nut holding them them on. I used PB blaster first so it helped getting the wipers off the splined mounting rod. I threw the wipers in the trunk and I have a small tool kit in there as well in case I have to throw them on quickly. I rarely drive my SHO in crappy weather so I am not worried.
I mounted the fan pattern sprayers onto my trans cooler mounts. They spray directly down between the condenser and the IC. Both of them almost spray the whole intercooler. When deployed the water gets pulled into the IC and then has to pass through the radiator before getting to the fans. I had my GF hold the button and I watched and made adjustments. Hardly any water except a very fine mist made it past the fans.
I loaded the windshield washer with a bunch of ice water and proceeded to do some basic testing. It was 93 degrees ambient and I got the car good and heat soaked. First pull IAT's started at 145 and dropped to 132 without using the sprayer. Next pass I pre-sprayed and soaked the IC with ice water at a stand still. Then I lauched. I wanted to see if any water would effect any aspect of the launch. IAT's started at 145 but quickly dropped to 118. So the ice water netted me a drop in 14 degrees. For reference on a stock tune every 10 degrees over 100 degrees the computer pulls 1 degree of timing. So I feel this could be a quick mod for the stock IC guys wanting a bit more cooling.
I will still need to datalog the runs. I left my computer at home. I will check to see the difference in temp after IC and temp at the top map sensor with and with out spraying the IC. I know we get hot in the intake because of the coolant pipe and engine. So I may have to yank the intake and heat wrap that pipe. I since the intake will be off, I might as well inspect the valves and walnut blast them it I have too.14 dollars for 14 degrees? Worth it in my book.I still have that CO2 chiller bar to install as well. Hopefully I can water log the IC and use the CO2 to freeze the cooler.
