Is any of that needed? LOL. 526 WTQ on good ole pump 93, zero knock, adding timing.J-Will said:They deny warranty because you didn't pay MSRP, but offer you a replacement... below MSRP!?!?!
Glad to be on the fence about meth. AJs recent tune results, ACES, and these threads have me very concerned. Ill just wait for a direct port injection, with a second stage just after the turbos for cooling.
Probably not...LOL... But from all I've seen I can take my 3.9-4 sec 0-60 down another second with meth.... The cooling has a really dramatic effect in PHX temps.... No body needs this on a DD, but it's fun stuff to pin people in their seats and stop at the next red light while the cars you were with are still in th intersection you just left... Hehe.FoMoCoSHO said:Is any of that needed? LOL. 526 WTQ on good ole pump 93, zero knock, adding timing.J-Will said:They deny warranty because you didn't pay MSRP, but offer you a replacement... below MSRP!?!?!
Scott4957 said:
SHOdded said:BTW, the video is titled ... Disassemble AEM 30-3015 / Snow Performance / Aquamist Water/Methanol Injection Pump
This makes it seem that Snow, AEM, and Aquamist all use the same (very similar) pumps, so you may still have problems with the brushes. If a pump fails during a WOT pull, no matter how good their warranty is, its not going to replace your engine,
I wouldn't rely on that to be my guide. Things are moving real fast when those pumps fail and its just a matter of time before a pump failure takes out a motor. Between the speed of events and a feed forward system where you are always milliseconds behind whats actually going on I would saysholxgt said:Rockstar04 said:Scott4957 said:
All/Any pump can fail. Users on here report no catastrophic failure from the pump stopping. The car just pulls a ton of timing to protect itself.
The real issue is finding a company that supports their product and honors the warranty.
Sabtaj1 said:My snow pump is a pile. Just ordered a Devils own pump to run. If that shits out too I will try the Alky Controls pump if it will work with my stage 3 controller... Just hope devils own warranty is better than snow cause they suck
hawkeye93 said:Sabtaj1 said:My snow pump is a pile. Just ordered a Devils own pump to run. If that shits out too I will try the Alky Controls pump if it will work with my stage 3 controller... Just hope devils own warranty is better than snow cause they suck
They are the same pump. Both companies use an Aquatec 5800 series pump.
