So...is there any way to use the SHO badges to create an intake....exhaust
I'm not sure what this is asking. Are you inquiring if you can affix a SHO badge to an intake or exhaust tip?
I almost feel like this was some attempt at making a break duct or otherwise from the two side SHO badge areas...but I feel the plumbing to do so would be a pain in the ass...
Yeah, I realized last night that I was wondering if you could use those let heat out of the engine compartment...basically... make them functional.
You could, would help if air flows in from the front and then exits our the badge area.  Not sure that happens though, and due to aerodynamics pulling air around the car rather than through it, the exiting air flow would be relatively weak.  Besides, heat rises, so the most effective way is to put hood vents in place, I think.
