Splash Cover Repair
If you plan on keeping it for long-term such as myself then why not IMO!
As mentioned earlier it also acts as a protective barrier from the oil pan plus elements,while keeping your engine bay cleaner.
I recall a while back while driving home from the dealer visit noticed the hood vibrating @ highway speeds due to the fact they forgot to install the under cover shield back on and luckily they replaced it with a new one. Z
Is there a part number for the fasteners if they are not there? I’ll look tomorrow when it’s supposed to be 50 or so out as opposed to today where it’s only 40
Here are the accessories needed for the (Under Cover Shield)
I will set this Topic sticky!  Z
Under Cover Screw - Ford (AG1Z-00817-A) $9.74
https://www.tascaparts.com/oem-parts/ford-under-cover-screw-ag1z00817a
Under Cover Retainer Nut - Ford (-W716006-S439) $1.56
https://www.tascaparts.com/oem-parts/ford-under-cover-retainer-nut-w716006s439/?c=bT0x&recommended=1
Bracket - Engine Support - Ford (AG1Z-6096-A)  $1.06
https://www.tascaparts.com/oem-parts/ford-bracket-engine-support-ag1z6096a
Just to be clear, unless you have some of those pieces on your car you need 4 of each for under cover screw, under cover retainer nut and bracket-engine support correct? The cover itself doesn’t come loaded with anything right?
Also kind of weird that Tasca says the screw does not fit the 2013 SHO. The parts diagram for the 2013 doesn’t show any screw.
So just got the lower cover in from Tasca. It comes loaded with screws and bushings. Need to check on the car to see if the retainers are still on for the screws to go into. I also bought a under cover retainer (AA8Z-16K262-A) in case that’s gone. Need to return the screws and the bushings. Maybe this weekend if it’s not too bad out.
