You may want to try pulling the brake booster vacuum line off the manifold and then starting the car (keep emergency/parking brake on). If the pedal feel is the same as while the line is connected, then it's likely not the booster.
Installation of stainless braided brake lines can also increase pedal stiffness since it takes away the flex the rubber hose would normally have.
This is the diagnostic from a 2007 Edge FSM:
Brake Booster
[list type=decimal]
[*]Inspect all vacuum hoses and connections. All unused vacuum connections must be capped. Hoses and their connections must be correctly secured and in good condition with no holes, cracks or collapsed areas.
[*]Check the brake hydraulic system for leaks or insufficient brake fluid. Repair as necessary.
[*]With the engine OFF, place the transaxle in PARK (A/T) or NEUTRAL (M/T) and apply the parking brake.
[*]NOTE: If the power brake booster is noisy when the brakes are applied, a new component must be installed.
Apply and hold the brake pedal several times to exhaust all of the vacuum reserve from the system.
[*]Apply and hold the brake pedal.
[*]Start the engine. If the vacuum system is operating, the brake pedal will move downward slightly under constant foot pressure. If no movement occurs, the power brake booster system is not functioning. Turn the engine OFF.
[*]Remove the vacuum hose from the power brake booster.
[*]Place the transaxle in PARK (A/T) or NEUTRAL (M/T) and apply the parking brake. Start the engine. Manifold vacuum should be available from the vacuum booster hose. If manifold vacuum is not available, inspect all of the hoses and hose connections. Repair as necessary.
[*]Connect the vacuum booster hose and run the engine at fast idle for 10 seconds.
[*]Turn OFF the engine and let the vehicle stand for 10 minutes.
[*]Apply the brake pedal with approximately 89 Nm (66 lb-ft) of force. The brake pedal feel should be the same as normal power-assisted brake operation for at least one brake pedal application. If the brake pedal feel is normal, the power brake booster is OK. If the brake pedal feels hard, continue with the test.
[*]Remove the vacuum booster hose from the power brake booster. Apply 57.3 kPa (17 in-Hg) of vacuum to the vacuum booster hose. If the vacuum does not leak off after 10 minutes, install a new power brake booster. If the vacuum does leak off, install a new check valve and/or new vacuum booster hoses.
[/list]
Check Valve
[list type=decimal]
[*]Apply 57.3 kPa (17 in-Hg) of vacuum to the vacuum booster hose. If the vacuum does not leak off after 10 minutes, the check valve is OK. Otherwise, install a new check valve.
[/list]
