johnbowler said:I don't agree. A sub not designed to go down below 40hz isn't going to sound good no matter what kind of box it is in.
Lanson said:I would worry less about the sub, and more about the enclosure.
Completely agree with you... perhaps my sub definition is slightly different. I believe a good subwoofer can go to the edge of or below human sonic frequencies before it reaches the impedance spike which is way above the 2 Db down point... That gives us the part of the experience we can't completely hear... at or below 20Hz. (My OZ 12" superman subs with DVCs were linear to the spike at 5Hz.. with a 1.8cu ft box and polyfill... true and accurate from 5-80 Hz).....
If a speaker won't produce sounds below 40Hz at or above the impedance spike or at least above the 2 Db down point... Then I call it a woofer and not a sub...
As I said, I agree with you that pushing a speaker to do what it was not designed to do always sounds bad. But a bad enclosure can make the best sub in the world sound bad and never reach it's potential or max electrical excursion.
