I'll be in Seattle in December for the 49ers Seahawks gameJosephm said:Your cheaoer than us, but your gas sucks. I'm a neighbor in WA
Is your 91 straight gas or 10% ethanol?Airbornemaikai said:Wish I knew anywhere around me that had something higher than 91
FoMoCoSHO said:Is your 91 straight gas or 10% ethanol?Airbornemaikai said:Wish I knew anywhere around me that had something higher than 91
FoMoCoSHO said:3 gallons of E-85 would get you to...
19.00 gallons
93.2 octane
13.4% ethanol (or E13)
Under 15% which ford has OK'd for 2013+
http://www.intercepteft.com/calc.html
I have access to both, with ethanol down the street, non ethanol only a couple miles away thoughFoMoCoSHO said:Is your 91 straight gas or 10% ethanol?Airbornemaikai said:Wish I knew anywhere around me that had something higher than 91
Yes. If you have torque you can use the fuel level function to calculate.Airbornemaikai said:The most I've ever squeezed in my tank after running it as empty as I can (without going to 0 miles to empty) is 18gallons. It's actually a 18.6 gallon tank.
If I go off that calculator to accomplish 93 octane on a 18Gallon tank by mixing e85 I would put 15.43 of 91 non ethanol and 2.57 of e85 for a total ethanol of 12.1% or E12. Sound right to you? If this is correct I will try it sometime in the morning
Have you thought about running methanol injection? You won't have to worry about your fuel octane as much as the meth injected is a 116 octane.Airbornemaikai said:The most I've ever squeezed in my tank after running it as empty as I can (without going to 0 miles to empty) is 18gallons. It's actually a 18.6 gallon tank.
wasinger3000 said:Just don't buy anything from Devils own injection.
Call them right now and see if anyone is working other than the secretary. I bet you there isn't cause I've called every hour today to try and talk to some one. I've been waiting for an RMA for my controller that doesn't work.... that I waited 12 days for the first time.scap99 said:wasinger3000 said:Just don't buy anything from Devils own injection.
How come?
And who do you recommend?
wasinger3000 said:Call them right now and see if anyone is working other than the secretary. I bet you there isn't cause I've called every hour today to try and talk to some one. I've been waiting for an RMA for my controller that doesn't work.... that I waited 12 days for the first time.scap99 said:wasinger3000 said:Just don't buy anything from Devils own injection.
How come?
They might get more controllers in on Wednesday but they have no way of telling when or if that might happen. Yeah that's real reassuring.
They just don't care. I talked to the owner to try and trouble shoot the problem. All I get is "yeah that might be it..." So far i have found zero technical competence from this company. Let alone customer service.
Pretty bad bussiness if you aren't even there DURING BUSINESS HOURS to answer questions. If they do not get this resolved by Friday I'm taking my money elsewhere. Like Snow Performance. A company that actually has bussiness hours...
I only bought the controller. Cause I had a pump already.FoMoCoSHO said:wasinger3000 said:Call them right now and see if anyone is working other than the secretary. I bet you there isn't cause I've called every hour today to try and talk to some one. I've been waiting for an RMA for my controller that doesn't work.... that I waited 12 days for the first time.scap99 said:wasinger3000 said:Just don't buy anything from Devils own injection.
How come?
This above is the best reason to MAKE YOU ORDER FROM ONE OF THE FORUM VENDORS!
Sometimes spending a little more upfront will save money on the back end.
Not to mention awesome service is worth a premium IMHO.
Lol yeah I know. I really didn't see any benifits of snow vs dipshits own at the time. It sure is clear now though...FoMoCoSHO said:Sorry....
I mean I had to bust your balls a little.
Hope you get everything worked out.
