IIRC my 160 has been hitting 205 where it used to hit 230.AJP turbo said:That single scalar you are seeing and using I think for the fan on/off point isn't the only thing that controls the fans....There are tables for TOT(trans oil) and A/C head pressure
I've seen some KR reduction with people with stats but sometimes it's hard to isolate because of fuel quality or pressure drops or spikes or afr changes.
Having the cylinder heads a little cooler will not hurt nor will having cooler plugs which extract more heat from the chamber and head
Chevy gaybalt is irrelevant in this piece
The coolant drops as you stated at just after your run not because the cooling system doing it's job but because you aren't feeding the engine gasoline and creating violent explosions.
I see SHO's in 10f degree ambient temps with a 170 stat go over 200 on wot runs.
I had this stat in for 2 weeks on the stock calibration with no cel and multiple dealer trips...no issues.
It may take a little warmer to warm up but but the difference is so small, its really hard to tell. Nothing a little boost, heated seats, and steering wheel can't compensate for.
