TIAL BOV ISSUE
FWIW noticed a couple of things.
1)3-Bar map sensor on Top of the manifold is installed in the wrong direction.
2)Check MDesign intake to make sure the IAT sensor is installed properly.
3)Low on brake fluid.
Oh. Ok thanks. I will correct those. I appreciate your attention to detail I  respects to your last question, those hoses were left open but I just plugged them both with the chair leg protectors that have been suggested to use when using the VTA mod.
Sent from my SM-G930W8 using Tapatalk
Its hard to tell but do you have a Boost Gauge setup? Z
If so where did you connect it?
I'm just trying to figure out which line is what!!.
Do you have any pics by the firewall? Rear back of engine?
How's your brakes?
CHeck your brake booster line by firewall!!
It seems based on the pic that it collapsed. Z
Is there a "right" direction? I should go check mine.
I don't think it matters which direction but never seen one installed like the OP.  Z
Brake booster line/master cylinder.
I don't have a boost gauge set up yet. I have the center dash 3 gauge speaker pod and sending units I need to install still. I also don't have pics of the firewall and other things you are asking about, but I can get some taken later today.
