So I know that + KR means ECU is pulling timing and - KR means the ECU is adding timing... BUT does that mean if there is negative KR (say it keeps dropping from -1 to -2 to -3 as you do a 0-100 run) that there is more timing that can be added if the tune is adjusted?
I see all these threads about how the ECU will add timing but if you run -3 KR doesn't that mean you can adjust the base tables to add even more timing?
P.S. - AJP is AWESOME
