YesSHOnUup said:Did you get revised tune for downpipes?
Rich
Lol, I just don't understand how I'm running the same with lower DA and temps 40 degrees less .SHOnUup said:That looks like a new PB by a touch too...
Rich
I'm launching at 2000 rpm, I'm spinning a very little .SHOnUup said:Winter fuel?
You spinning more now? If so, maybe a lower rpm launch in the cold.
Rich
From what I can see its sealing good .SHOdded said:60' times are working against you.Are you sure the weatherstrip on the CAI is sealing against the hood? Tracking IAT/IAT2 to see heat soak? What tires are you running?
I currently have 72k on the clock. Using 93 octane tune . Already using 4x tune . Will be changing PTU fluid soonSHOdded said:Proves that the stock intake is strongHow many miles on your SHO? Octane? May be time to try the 4X tune, and change the PTU fluid if not already done.
What octane are you running? Do you have winter gas down in TX? Launching at 2,000 rpm? Does your SHO feel sluggish at any point?FastSHO23 said:I'm in Texas as well, seems it sucks our cars slower down here?
