metroplex said:Group IV base stocks will probably get just as hot but may or may not breakdown quicker.
AJP turbo said:You mention you have all stock fluids...i cant think of a scenario why anyone would take their car on a track unless they wanted to document at what point failures or symptoms of an abused car.
I would call amsoil and ask if the temps you are seeing is a problem...and you might want to consider using a real synthetic fluid such as amsoil signature series...group iv oils are completely different and seemingly indestructible so i would think amsoils signature series atf 220 is nothing
Maybe you should get some good oil in the trans engine and ptu and the temps may not even get that high
Makes sense. On a car with no aux cooler, it is going to be pretty close to what ever the coolant temp is, and I agree that's over 180.. Interesting...AJP turbo said:To be honest im not sure what the operating temp of the 6f55 is..but i wouldve guessed 200
I cant see it being much lower than that considering the trans fluid runs through the radiator and with a stock thermostat the coolant is is at least 190 ish
Another great point!92BlackGT said:the trans cooler is on the cool side of the radiator, so the coolant will cooler than 190
