Tranny Blues
Dave... Sorry to hear that saga. I feel your frustration. Regardless of what you do with the car, be sure you direct it at the actual cause, the warranty company... They owe you. There are real damages here.
It's why I went with Ford for the extended warranty.... BTW, who is the company. Folks should know so they can avoid that one
I typically don't like lawsuits for every little thing....But 3 wrong transmissions and no rental car? Someone is incompetent and deserves to be sued....I'd sue for all that's legit and pain and suffering and punitive damages to make it worth the time and trouble and lost work time
You guys are right about the directing my frustrations where they should be. But it has been an exhausting effort. I buy warranty to avoid these issues and this is what I get. I feel violated with this car. And a used transmission installed, after the transmission has already had issues last year doesn't give me the warm and fuzzy about this car. Had it not got out in years past I may say ok and just suck it up. But transmissions in 2 years? Likely to fail again next year. So not willing to pay for a $6000 repair on my own.
Oh and latest is replacement part won't arrive at dealership until 5/4/16!
One last thought I had.... Could faulty installation causing something to be off center in the rotating parts of the driveline or tranny have caused the failure? I have to wonder myself with 2 tranny failures in as many years.
I don't think the installation was bad. I think the mind set of only repair what is bad is why I am having issues now. If Ford had rebuilt whole transmission when it failed before, there would be no worn torque converter or valve body to go bad. It would have been serviced or replaced then. And now it turns out my warranty company is the true problem here. And I have no recourse at this time.
So they are giving you $800 for the tranny plus labor?
If I've read this right, I would consider ponying up the extra 2 grand to get a reman with a nice warranty with it. Remans typically have a better warranty than a new part anyway and sometimes design defects are corrected during the process.
In the long run, it's far cheaper than a new car and you will have some peace of mind going forward.
I know this is a bitter pill since you already paid for the "warranty" but in the long run it may end up saving you money/stress/hassle down the road.
2 months and 3 days, I finally have my car back from dealer. What a nightmare.
As of now car appears to drive fine as I have only driven it to work since it was last minute pickup. PTU fluid was replaced and unit inspected as a leak developed while car was being serviced.
I feel violated with this ordeal. I am sadistically hoping the trans breaks again. Will be another nail in the coffin of my ownership of this car. So in all fairness will drive it for a bit and see.
Not sure what to root for here, but as a SHO guy, I would hope the repair holds.  But I see your point.
To resurrect an old thread, my (used) new trans has leaked pretty much since it was installed. Dealer never able to pinpoint exact location of leak.
Since my warranty coming to an end I take car back to dealer to check again. Found leaks trans halfs come together AND on control module. Roughly $2000 to split case and reseal. Nope, not my warranty. They sending another used tranny. While I was hopeful trans would last mostly because I talked myself out of buying the CTS for financial reasons, I really think it's time for this car to go. No love or luck with trans. Car runs GREAT but the trans.......
Wouldnt it be better to buy a Ford remanned trans rather than a whole new car? Or take it to a trans shop for a professional rebuild?  Just thinking out loud ...
If that has leaked since day one of the new install and ford  couldn't figure out where it was coming from I would've been looking for a new dealer LOL.
it's pretty damn obvious it's leaking from the casing WHERE THE GASKET IS SQUEEZED OUT.
You're supposed to wait a specific amount of time to let the gasket material setup before you bring the halves together
