Txstrmhntr said:Ok ive looked a little deeper from what ive found now the GM tran and Ford Trans are 100% identical down to the case molding, only difference is FoMoCo uses there own solenoids, and the final gear ratios are different than the GM cars, but its 100% mechanically the same. in other words you could bolt a 6T80 Gm trans straight up to a 3.5L ecoboost and only thing youd have to change are the shift solenoids.
+1....subbdCole.C said:Have been wondering if anyone has looked into this any further. Know I need a new trans shortly wondering if I bought a new 6t80 trans how difficult would the swap be. Hope to see this done eventually if the 6t80 is improved over the 6f55 in any notable way?
https://www.sourceoneautoparts.com/24265608-6t80-transmission-6-speed-automatic-2014-16-cadillac-xts-vsport.htmlAJP turbo said:Been a few months since I read it but certain GM versions of this tranny have an even more aggressive final drive. I'm thinking like 3.27 or something....I was thinking it would be a fairly easy swap and just a matter of changing the part and tune adjustments for gearing....Easy if you do tranny work but bolt in nonetheless.....I'd like to know for sure though
Umm...that’s a Cadillac (GM) trans.Cole.C said:https://www.sourceoneautoparts.com/24265608-6t80-transmission-6-speed-automatic-2014-16-cadillac-xts-vsport.htmlAJP turbo said:Been a few months since I read it but certain GM versions of this tranny have an even more aggressive final drive. I'm thinking like 3.27 or something....I was thinking it would be a fairly easy swap and just a matter of changing the part and tune adjustments for gearing....Easy if you do tranny work but bolt in nonetheless.....I'd like to know for sure though
Found these 6t80 trans at a decent price it says it's final gear drive is 3:16 which is the same as the 6f55 used in the police interceptor sedans which is what I'd be doing the swap in. If it did bolt right up with no issues and the wiring harnesses look the same but never know could be ever so slightly different but hoping not. Would the car require a custom tune to be driven or if the final gear ratio is the same and ends up being easy as a OEM install would it be safe to drive the car atleast on a trailer to get it home to be messed if even nescessary?
The cases look the same, bolt pattern looks the same as well as harness.. I'd have to order it and try to have it bolted up. set side by side you'd barely be able to tell the difference besides the 6t80's added case ribbing compared to the 6f55. but yes thanks I'm trying to buy and install a GM trans... even if I do have to have an adapter made or go through some weird pains I was quoted for the new 6f55 supposedly "at cost" for 1799 warrantied from the local stealership that loves to lie. I can get the 6t80 for 1299. Still could get an adapter made and a ever so slightly improved trans for less than the cost of the new trans Ford quoted me at..glock-coma said:Umm...that’s a Cadillac (GM) trans.Cole.C said:https://www.sourceoneautoparts.com/24265608-6t80-transmission-6-speed-automatic-2014-16-cadillac-xts-vsport.htmlAJP turbo said:Been a few months since I read it but certain GM versions of this tranny have an even more aggressive final drive. I'm thinking like 3.27 or something....I was thinking it would be a fairly easy swap and just a matter of changing the part and tune adjustments for gearing....Easy if you do tranny work but bolt in nonetheless.....I'd like to know for sure though
I HIGHLY doubt it will bolt up.
Nor will the wiring harness match.
Cole.C said:Found these 6t80 trans at a decent price it says it's final gear drive is 3:16 which is the same as the 6f55 used in the police interceptor sedans which is what I'd be doing the swap in.
My bad! I must of gotten my info from a bad source. Pdf I downloaded with various police Dept. Vehicles showed 3:16 shows the 3:39 in the 3.7l?bpd1151 said:Cole.C said:Found these 6t80 trans at a decent price it says it's final gear drive is 3:16 which is the same as the 6f55 used in the police interceptor sedans which is what I'd be doing the swap in.
PI sedans have the 3.39 axle.
PI utilities have the 3.65 axle.
You listed they have the 3.16
Just FYI.
Thanks, that I did not know. Dang so how much would it complicate things trying to swap a trans with different final gear ratio? Probably a very dumb question but Is that something that can be fixed with a tune or just completely rules out compatability >.<? Appreciate the info!bpd1151 said:The 3.5 FWD only version (earlier model years) employs the 3.16 axle.
AWD is now standard on all PI's. So the 3.16 is no longer available.
