.AJP turbo said:Targeting .90 may be worse...its already trying to pull as much fuel as the ecu allows..the fuel model is wrong. Trying to make it leaner becuase its too rich is a bad bandaid in tuning
JCam550 said:Is it me or does it seem that each one of these engines seem to react to tuning very differently?
Sounds perfectly reasonable to me.Sinister-CO said:Wow, maybe I'm just being too simple about this but it seems to me you guys are just running way too much meth. Meth shouldn't be your primary fuel, it's meant for detonation suppression and a little extra octane. You shouldn't be pulling fuel to compensate for too much meth, that's not how it's supposed to be used.
Put in the smaller nozzles and see where you are at then. If these are snow kits, isn't there a screw on the top of the pump to adjust the pressure down? That's how mine is on my GN. I run the smaller nozzle and I have the pressure turned down. Why?...because it was injecting too much meth, the engine was way rich and I was getting knock. I know that sounds backwards but meth should complement your primary fuel, not replace it.
But then again, what do I know.
FoMoCoSHO said:.AJP turbo said:Targeting .90 may be worse...its already trying to pull as much fuel as the ecu allows..the fuel model is wrong. Trying to make it leaner becuase its too rich is a bad bandaid in tuning
Well, yeah and if you have a meth failure engine is surely doomed.
So how do you adjust for it in the tune then?
Wouldn't smaller nozzles be the first step?
It actually is being used for the extra fuel. Not saying a smaller nozzle is not the answer but Torrie has tuned plenty of these engines on meth, I'm sure he would have already came to the same conclusion. This is the first meth log I have seen with knock so it's not the norm.Sinister-CO said:I'm with you AJP, but I think we all agree they're spraying too much meth. They should either try the smaller nozzles, turn down the pressure or a combination of the two.
Just because everyone else is using the bigger nozzle doesn't mean you have to. We've already seen another person that is running rich as well.
AJP turbo said:may have tuned many but having stft's pegged and in the .70's and afr's in the .70's also is less than ideal
Mif i had meth i would want afr in the low .80's and i would attempt to adjust the fuel curves so that stft's got lot closer to 1.0
Sabtaj1 said:Maybe try a diff brand nozzle. I never used my snow ones cause the threads were s--t. I run an alchohol injections nozzle 10gph as torrie recommended. No problems here. Maybe ur nozzle isn't making a good mist. Just a thought
