Unleashed 3 bar 93 octane tune
No, I'm not confused. I totally understand what a datalog is and why it's useful. People on here were saying drive it for a couple of days before you log. I see not reason for this, because you want to see wot, not drive ability.
Sent from my iPhone
The datalog you send in for tweaking by Torrie shouldn't be one right after you load the tune. The car needs time to learn the new parameters and adjust before it settles in.
I've flashed the same tune to car at the track and lost 2 tenths...shifts felt harder and more aggressive but weren't as efficient.
If you want the best data to send Torrie I'd drive it for a couple days before logging to send in.
Log as much as you want, but there's a learning curve in the ecu.
Rich
Sent from my iPhone
You do realize the SHO makes closed loop WOT adjustments?
No I did not, thank you.. This makes sense now... I don't think my 93 mustang did that. That car was mass air though, not speed density
Sent from my iPhone
Sent from my iPhone
Ur 93 did not do that....and it has nothing to do with speed density(map) based or mass airflow based logic. It's just how this ecu operates...coyote mustangs do it also that I know of....they are maf tuned
Torrie is going to look at my log. Car seems to be running really good, on a bad note I took my front passenger tire off because it was leaking air. Damn wheel has a crack on the inside lip
Sent from my iPhone
At least you found the culprit!  Beyond repair, I think, but maybe a wheel tech can get it going ...
That's why EBay and posting in the Wanted to Buy section on the Taurus & Ecoboost forums is HIGHLY recommended :)
f8tlSHO said:
I ran a 13.5 stock, what was the da when you ran it?
Sent from my iPhone
I am sure that my 300# self, extra sub, and detailing stuff in the trunk did not help as far as times go.  IDK about DA, it was at MoKan Dragway outside of Asbury, MO.
Here is a slip for my stock 2013 on all-season tires, 1/2 tank of fuel, and no race prep (13.499 @ 103.62 MPH):
http://www.dragtimes.com/2013-Ford-Taurus-Specs-26105.html
Results from the "Correct your ET and MPH using the DA" on the dragtimes web site:
13.573 @ 103.144 MPH
Skeezixzx9r said:
Sent from my iPhone
f8tlSHO said:
I am going to load the 14psi, 6200rpm tune at lunch in a half hour. I watched the gauge last night on stock tune, hit 11.8psi max. Thanks wasinger, I will do that when I datalog
Sent from my iPhone
How's this going? Any reviews yet?
Rich
I am 875 miles away from my car in st Augustine Florida right now on vacation. I could walk to unleashed tuning in a half hour.. Lol. My car has a donut on it, so I can't really pound it right now. Torrie sent me an update but I did not get it loaded before I left. It seems to be running really good though. I uploaded 2 screenshots of my run with pocket last week, and my stock run which was done at the track. But I am pretty sure I let off early. Car seemed to get more refined after a couple of days of driving. It was starting to spin 2nd gear. Not sure if it was reverting back to front wheel drive again though. It did that last week, just burned the front tires to 40mph
Sent from my iPhone
In the last few days I have installed Torries 2 bar tune on a stock car and ran it for a few days then installed my 170* tstat and 3 bar. My question is on the 2 bar the shift point was way higher than the 3 bar. I'm guessing 6100rpm vs 5700rpm for the 3 bar. Is this normal for new tunes? I feel like the car just gets to stretch its legs then shifts. Do I just need to log my runs so torrie can adjust it?
Happy Fourth of July!
Mine were 5700 to start also, I requested a higher shift point because I felt like it wanted to go more rpm
Sent from my iPhone
What is the preferred shift point, what's thre rpm range for the best/fastest 1/4 Mile time? I see people having different shift points, obviously there has to be the sweet spot on these cars.
Can't comment on this other than butt dyno.. But I agree there is a sweet spot I am sure. When I load a new tune on the x4 it's has a bunch of things that can be changed, shift point is one of them. Has any body ever changed any of the settings when loading a tune?
Sent from my iPhone
Sent from my iPhone
I checked mine and set to 6200 for the rev limit. If I'm not mistaking the shift settings are just for transmission firmness. I'm going to wait till after the holiday and send torrie a log. Is there anywhere I can find the PIDs to log for him?
He sent me a file to load on to the x4, then when you log, you pick those settings instead of the 08+ ford
Sent from my iPhone
