I've noticed that I'm seeing 26+ in 1st @ WOT, 20-22 in higher gears.StrawHatShinobi said:So FoMo, your car is adding timing on its own in the 26° range or are you running a tune for that? Im not getting any more out of it than i normally see when going WOT, but when cruising and pulling hills its adds a ton.
The one thing I have noticed in my truck when logging it takes longer for the fuel to catch up and hit the commanded AFR but it is capable of doing it at any blend I've ran.
I'm still trying to figure out the logging on this new software, it polls data so fast I may miss peaks on the gauge screen.
No tune.
i have seen no lag in AFR except when I'm running a new blend percentage, the lag can be felt in throttle response until the ECM learns the new trims. If I return to a previously ran blend, that lag is pretty much non existent.
New times in the drag racing results section.
