So I've been looking at new tires to replace my original Goodyear Eagle F1's with 30,000 miles on them. There is still a little life left however I have a concern before putting new tires on. All of the tires have severe, uneven tire wear on the inner part of the tire. Hopefully from the picture you can see what I'm referring to. I do rotate the tires frequently and alternate the direction pattern, so I'm not sure if it's one location, just the front or all corners that have an issue. As I indicated the wear is very uneven which makes me even more confused. Some parts of the tire have no wear and others close to 3/16" of tire is worn off. I do have aftermarket rims (Nurburging) which I believe have the factor offset. Additionally the car has been lowered on H&R springs. I have jacked the car up and do not see any signs of rubbing whether on the front strut towers or fender wells. Also put the car back down on blocks to see how it sits and try to find any issues with clearance. Frankly the only thing I can come up with is rubbing during wheel hop however if that were the case I would assume that I would see rubbing on the bottom of the front struts. I'm at a lose. Does anyone have any ideas or cause of this issue?
