Weirdest noise
Flexthis2011EB
Hey yall. Another problem. So for awhile now I've been hearing a grindingish/tire rubbing sound down somewhere between trans and right tire but weirdly mostly happens when i press on the gas. No noise while coasting but the slightest touch to the gas pedal I hear the noise. Best way i can describe it is like when ur on a highway and transfer on a bridge you hear that tire/road rubbing/grinding noise. Idk. Any ideas? Ptu? Bearing? And it's not the tire. I changed them.
Any signs of visible leaks especially on the ground and what color ? also check your trans fluid to make sure its above the fill line ,halfshaft recall done? Z
see if you are part of the recall for the front right axle...  They have had some breaking I heard.  your CV may be taking a poo.
AJP turbo said:
Time to sell that bomb
Lol right!
Not sure if it has halfshaft recall done. I bought it used. No leaks, trans fluid level is good.
I'll check on this
