Good summary above. LMS can make adjustments for mods like all tuners, but they are based on the three SHOs they own unless you get a dyno tune from them. Again... If. You're in to tinkering Unleashed will datalog... So it's simplicity for 95% of potential vs. data logging and multiple revisions trying to get that last ounce of performance... Each owner has their own preference. You'll love it tuned regardless of who you use.glock-coma said:Depends how you like it.
Set it and forget it -livernois
If you like to tweak and have access to a laptop you can data log with unleashed.
With a 15 you should have the latest plug revision but I would still check the gap.
Should be .30 if your tuning it. Tstat is not necessary but does help.
Not much but a laptop is need to log with the tuning device. You would upload a configuration file that would give you the correct parameters to log then do some 1/4 mile pulls in a safe area while logging. Then send the log to Torrie at unleashed. He then sends you an updated tune correcting anything that needed to be corrected and tweaking a few things to improve the tune for YOUR vehicle.Cbudden said:How much tinkering is needed with unleashed?
I ran 12.90 @106 with his 2bar tune last year with -0- data logs.Brucelinc said:While data logging is optional with Unleashed, it is my understanding that his base tune is very conservative. I don't know of anyone with a Unleashed tuned SHO who has gotten out of the 13s in the quarter without data logging. When revised, however, his tunes can be exceptionally quick while still maintaining a safety margin.
glock-coma said:I ran 12.90 @106 with his 2bar tune last year with -0- data logs.Brucelinc said:While data logging is optional with Unleashed, it is my understanding that his base tune is very conservative. I don't know of anyone with a Unleashed tuned SHO who has gotten out of the 13s in the quarter without data logging. When revised, however, his tunes can be exceptionally quick while still maintaining a safety margin.
DA was crazy low <200 at the time it was around 50°
