Um...Well then..... I’ve been a quart heavy for about 20k with no issues.StealBlueSho said:It’s an extra PINT!!! Or half quart!!!!!! Not a whole quart!!!
I swear I’ve seen an extra quart here somewhere.
glock-coma said:Um...Well then..... I’ve been a quart heavy for about 20k with no issues.StealBlueSho said:It’s an extra PINT!!! Or half quart!!!!!! Not a whole quart!!!
StealBlueSho said:And yes, Brads Tune brings the torque early! We had to dial it back a tad in the lower RPMs cause I was spinning all four tires out of the hole no matter how I launched it...
I cannot speak highly enough of Brad. Best tuner I have worked with out of the four I have.
I agree wholeheartedly, same issue. My PB on the 15 was on a low RPM launch, High IAT2, and pulling spark. High RPM resulted in a good show for the stands and for a brief moment my competitor thought he would win. LOL, not so much winning for him.ClearwaterSHO said:StealBlueSho said:And yes, Brads Tune brings the torque early! We had to dial it back a tad in the lower RPMs cause I was spinning all four tires out of the hole no matter how I launched it...
I agree. I can't express enough how amazing his tune is. I think if I could figure out how to get the power to the ground, prob going to need some springs and better tires, I bet it would be running 12.40's.
Brucelinc said:Tire pressure makes a big difference. Lower pressure will usually hook better and reduce tendency to wheel hop.
By the way, I would like hear opinions from transmission specialists or even other tuners on this business of over filling the transmission.
ZSHO said:To the OP! any vibrations felt in the suspension when driving?
I would try reverting back to stock Tune to see if your symptoms persist!
I highly doubt the warm FL weather will cause wheel hop IMO. Z
I think you stated your lower control arm bushings are starting to look worn IIRC!!!!ClearwaterSHO said:ZSHO said:To the OP! any vibrations felt in the suspension when driving?
Switching to the base three bar tune I have from unleashed cause it to shift like butter. Zero issues. Flashed back to AJPE30 and lowered tire pressure to 32 from 37. The issue was gone. I don’t think it was the FL air, but rather the tires being inflated to 37 psi. Suspension up front is all new. No sounds at all. I emailed Brad, see what he thinks about it. Lowered tire pressure did resolve the issue.
