Macgyver said:Stock.
ChrisxEco said:I would love to run straight e85 and get more performance then having to mix for my e30 tune from torrie
Sent from my SM-N960U using Tapatalk
StinkinLinkin13 said:Well... I'm stuck. My indecisiveness is debilitating.Either way I have to dump more cash... Just how much $$$ vs gains ratio is where I'm at. I don't mind paying if the the requirement (hpfp) is real and the benefits (gains) are tangable.
My best 1/4 time 12.8. Best trap is 109mph. (On LMS Meth tune)
Maybe I'm just being unrealistic/unreasonable in my expectations. But basically whatever (if anything) I'd be able to do to improve on that by at LEAST 5 tenths is what I'm looking for.
Here is what I find odd... My car runs great on this Meth tune. It has been the least problematic tune for me even if NOT running meth (which I am not recommending or condoning). But V11 and V11 HPFP adjusted still sputter out on the top end. I don't understand why if the meth tune is supposed to be more agressive (which the seat dyno would say it is).... We'll IDK. That's where I guess my skepticism lies when it comes to that 1.6k $ hpfp... Plus they still want meth for running e85.![]()
Jordan said:StinkinLinkin13 said:Well... I'm stuck. My indecisiveness is debilitating.Either way I have to dump more cash... Just how much $$$ vs gains ratio is where I'm at. I don't mind paying if the the requirement (hpfp) is real and the benefits (gains) are tangable.
They want methanol for supplementary fueling due to the e85 causing it to lean out.
AJP turbo said:Not sure I like the word can’t...since I’ve been seeing otherwise....what is aggressive?
StealBlueSho said:What was the DA on that run?
I ran a 12.799 on their V11 93 octane tune with the HPFP, CAI, 160tstat, and 3BAR.. the car was also heat soaked and my launch was not the best with a mid 1.85 60ft.
With meth you should be mid 12’s unless your elevation is killing you...
My meth injected 2010 ran 12.4’s on the LMS meth tune...
And you shouldn’t be sputtering on the top end with the LMS meth tune? Unless you are injecting way too much meth as the system is a progressive system.
With the updated E30 tune from LMS I suspect I will back into the 12.4’s easily with my 2016.
Macgyver said:What is the weight difference in the Linc compared to a 12.5sec SHO on E30?
StinkinLinkin13 said:StealBlueSho said:What was the DA on that run?
My goal has always been to run low to mid 12s... I am consistent 12.9. 12.8 is best 13 flat is lowest. Idk DA was high I posted it here somewhere. Ill check in a bit and edit.
To be clear the meth tune is the best tune I run I have very minimal to no sputtering even with NO meth actually being injected...(they do however scaleback the shift point on I believe the 2nd to 3rd shift several hundred rpms) I do have and have always had sputtering on the top end with the V11 and V11 HPFP adjusted tune tho that was covered in earlier threads.
Having said that I recently tried running E30 in my tank with the normally problem free Meth tune and low and behold the return of the top end sputter. Which in turn brought me to this point.
sm105k said:I have never had an issue with my E30 tune. It has never sputtered and is not dependent on Meth.
