wasinger3000 said:So my resusts of 2 stroke oil are turning out to be awesome. I'll get some proof this weekend on a 400 mile trip.
I'm using Royal purple synthetic 2 stroke oil. So far I found I need to cut my dosage back. For the first 160 miles there were hills that would require around 4-6 psi of boost in 6th gear. On those hills I was getting knock around 2-3°. So I filled the car with 8 gallons of 91 (all I could fit). On the last leg of the trip the knock was no longer there on the hill climbs. So 1 ounce for every 5 gallon is to much. I'm going to cut the dose in half next tank.Spartn27 said:wasinger3000 said:So my resusts of 2 stroke oil are turning out to be awesome. I'll get some proof this weekend on a 400 mile trip.
Think this would mix well with a full synthetic like Mobil1? Also what brand do you use?
Thanks and enjoy the trip!
ecoboostsho said:Hmmm. I keep watching learned octane ratio and even mixing it never changes. What are your trims running at?
Its not exactly WOT its going 70 and locking it in 6th gear by using S instead of D and pressing the pedal all the way down slowly. It gives a good impression of how much torque the car has, at least in 5th gear, because once the boost builds it is still fast no matter what speed you start from.ecoboostsho said:Fuel trims let you know if the car is adding or subtracting fuel to maintain the right air fuel ratio. If the number is too big you could be running out of fuel or have a vacuum leak. I never see knock at WOT with or without E85 so you may have something else going on?
Yes I used that BP. I did 2 tanks of blend and now I'm running a tank of 93 to see the difference.SHOnUup said:By locking it in gear when it would usually downshift doesn't sound like the most beneficial thing for the car. Almost replicating glock-coma's, if I remember correctly, non downshift syndrome.
Did you use that BP we talked about?
Rich
Mine does not go open loop during WOT.IHeartGroceries said:The ECU doesn't fuel trim at WOT or under load or before the engine reaches operating temp. It falls back to a predetermined set of fueling tables, ignoring O2S data, also known as closed loop operarion.
Torque, Dashcommand, and OBLlink all show closed loop during WOT.IHeartGroceries said:Is this based on data a scan device is reporting?
Can anybody else report? Specifically pre 2013?
