AJP turbo said:I think the OEM gets the fresh air from good location...The air is drawn from outside via the inlet near the grille
FearlessAZ said:AJP turbo said:I think the OEM gets the fresh air from good location...The air is drawn from outside via the inlet near the grille
You saw some logs from when my scoop was screwed up vs when it got replaced. That inlet makes a huge difference.
TopherSho said:AJP turbo said:I think the OEM gets the fresh air from good location...The air is drawn from outside via the inlet near the grille
AJP your alive!! hope all is well..
Hey would you be offended if i had a friend print a chrome decal titled "TUNED BY AJPTurbo" ?
TopherSho said:FearlessAZ said:AJP turbo said:I think the OEM gets the fresh air from good location...The air is drawn from outside via the inlet near the grille
Are you saying the side port you installed yielded better than OEM results? I removed the from weather strip in front of the snorkel, but left the other for better idle breathing. but was thinking like you of maybe putting a port on the right side (facing the front of the car) and then stuffing that tube down behind the lights into that cranny may be better.
AJP turbo said:TopherSho said:AJP turbo said:I think the OEM gets the fresh air from good location...The air is drawn from outside via the inlet near the grille
No I wouldn't be offended lol...One day I'd like to get some stickers made, I have a couple ideas in my head..Need to find a local artist...I know how to draw stick figures
AJP turbo said:No I wouldn't be offended lol...One day I'd like to get some stickers made, I have a couple ideas in my head..Need to find a local artist...I know how to draw stick figures
Agentlongwood said:So about heat shielding the stock intake... Was there ever any feedback on this? From reading around on here it seems like the stock airbox flows plenty of air. Enough that people don't typically see gains when swapping to aftermarket intakes. Would adding some sort of heat shielding to the outside of the airbox and tubing help? Maybe use Mylar or something similar?
So, I know everyone keeps saying "No, not worth it" and "Don't bother" but Ford seems to think it works when it counts.TopherSho said:Anyone do a wrap and see any drop in IAT temps? or does heat soak still set in regardless .. or would it be better to port the airbox and route intake tubing from a better source?
boosted4SHO said:I see... Ever thought about icing your intake pipe between runs at the track?
