Wrench icon on dash
Txstrmhntr
Happened at wot almost immediately after the 3 to 4 shift, car went limp mode, after pulling over checking for catastrophic damage underneath ( was none) and restarting car everything seemed fine no limp mode the rest of the way to work. Haven't read codes yet... Any ideas?
SHOnUup said:
Weird. Have you plugged in tuner to see if it set a DTC?
Rich
not yet gonna do that in the morning when i leave work, although talking with Todd it seems he had the same sort of issue early on so im getting Erick@LET to look into it. Good thing is i was logging when it happened so I have all the data
I'm going to bet it's something in the drive by wire part of the tune. The same thing happens in the coyote mustang world when people add forced induction...and with those atp turbos there are any more things that probably need tuned...mention to him wheel torque error and see what he says...it's worth a shot...when delivered torque doesn't match commanded torque the dbw system will put an end to the fun real fast...but will be fine when u restart
Common to see the wrench when a wheel speed sensor has problems or fails.  That would also set off ABS/Advancetrac lights since they are all dependent on that data.
Being that he has a 13' that would be an anomaly but since he has different turbos dimes on dollars that's where the problem is..and it's at wot
How long have you had the turbos on?
