WTS: AEM Meth Kit, Custom Mounting Brackets, Noise Eliminator Pipe and more
Status
Not open for further replies.
Wild13SHO
I have for sale the meth kit I pieced together.  It has everything you will need to install the kit MINUS a pump.  The pump went bad before I finished installing everything.  So you will need to buy a new pump.  The pump and tank mount to a bracket I made that mounts to the drivers side frame in front of the wheel behind the bumper cover.  You will need to drill three holes and install two rivnut, which will be supplied.  You will also need to relocate the horn to the bracket that stabilizes the bumper cover.  I also made a bracket to mount the controller inside the car.  The tank is filled remotely from the top of the engine with a tube installed in the cap.
Parts included:
AEM controller V2
AEM 1 gallon tank with low level sensor
AEM filter
AEM meth volume flow gauge
Snow injector and injector housing
T-fitting for boost reference
Noise eliminator pipe
3 Bar MAP
New/never used plugs
All the wires/connectors
All the tubing required to install the kit and a little extra
3.5 gallons of Snow Boost Juice
$455 Shipped
Having a seller that documents their products this deeply is a seller worth talking to!  Talk via this thread, or PM him, but be sure to at least explore this opportunity!
Status
