StinkinLinkin13
Yes sir. Experiment a little to see what works best for you. I did the same.
I needed to correct my temps from yesterday because figured they were too low... I double checked my pids on torque pro and must have entered something incorrectly. Using the Torque supplied Ford Trans Temp pid I ran the same test. The difference is its quite a bit cooler today.... a chilly 73° and raining. My temp after two brisk pulls raised to 140° in about 5 minutes drive time (basically around the block / 3 miles). As you would expect it will take longer to get up to operating temp without the tstat. But It beats the 286+° spikes I had with my 2013 MKS on WOT highway runs. Also it doesn't help that mercon LV is known for breaking down pretty quickly. Personally I'm comfortable with the 160-180 range on our setups. Especially being the lead foot that I am. Also note that it should also help with our condenser temps a little.
Keep in mind my cooler also has about 2 times the area as the PP version.
