13 SHO in the 11's on stock fueling with PUMP fuel!
92BlackGT said:
wow! awesome run. im seriously thinking about getting me an AJP E30 tune
Brad does amazing work and is super informative on what he does. We fine tuned this bad boy to perfection over 11 revisions. I say give it a try!
sm105k said:
I agree, nothing but happy with my Brad tune.
Absolutely do it.  Worth every penny.
Yep. On my last AJP E30 revision (maybe as our gas here rocks). AJP usually has to loosen up on the controls and just let the SHO go. But E30 is an amazing performer. 0-60 and 60-140 is just nuts now.
I love the videos!  Haha the one against the GTI had me luahging at the end.  He flew by you after the race was over, not sure if that counts for anything but clearly he was the first to get his time slip 😆
StealBlueSho said:
What do you mean “slight modifications made to the tune LMS93 tune”?
Being that lms tunes with hp tuners others can modify the tune. He had a buddy of his lean it out a little and slightly tweak a couple things
LMS does not use HP Tuners from what I understand, HP Tuners still doesn't have full support for the 2010-2012 models. However, LMS does not mask their basic 93 tunes, and with HP Tuner software you can modify the parameters on an unmasked tune... you can do this with any unmasked tune.
There is someone out there who is ripping off other tuners tunes using HP Tuners.. It has happened to LMS and Gearhead at minimum which is just bad form. This is part of the reason why tuners are masking their tunes now. Basically masking the SWPN of the ECU and the Strategy so you cannot make adjustments or rip the tuning parameters off...
And tuners masking their tunes makes it a PIA to revert back to the stock strategy when you take the car to the dealership for work.. I really hope its not your friend doing this.. cause if it is, he is an ***hole.
On a side note: Did you do a baseline dyno before and after leaning out the mixture? Curious if it netted him anything.
It's not him. It's his friend making the adjustments. And that makes sense on what you said. I was just under that assumption. This guy is a small local guy who isn't in the market to sell tunes. Mostly just tunes his own stuff or in this case improving on it.
And he hasn't been to a dyno none really local as far as that goes but he ran a 12.5 with said tune so knowing lms 1/4 times it has to be making a slight difference.
802SHO said:
Haha after all that the last comment was priceless!!  From 😡 to 😏
LMS does run richer than any other tuner I have tried.. they do dyno test their AF mixtures but they always err on the side of safety... I am curious how much more power their tunes can produced if leaned out..
Did he run on the base 93v11 tune from LMS? I am not arguing, simply curious if there is any factual data back up that claim.
Went out on C20 instead of pump fuel couldn't cut a good 60 foot time but here is every run from that day.
Track prep just wasn't there but I had a great time with a bunch of friends!
