Yes but be careful with the fuel vapor hose,red clip.68_GT said:think I'll pull valve cover and have a look my self. Is it OK to remove these quick connect hoses to move them out of the way ?
glock-coma said:The 2 with the white clip are vacuum lines, those are fine to remove.
The red clip one is fuel. Not sure if it's pressurized or a return to the tank.
EXERCISE CAUTION IF YOU REMOVE IT.
68_GT said:
ZSHO said:IMHO would not remove the rear valve cover on a temporary basis because there is a silicone/sealant holding it together so essentially you will have to remove the old sealant carefully and install new silicone/sealant and let it cure for a while and also need to torque down the bolts properly to oem specs. Z
SHOdded said:Sounds like a bad HPFP or rod knock. That is NOT ticking.
Correct RTV/Sealant same crap different smell.lol. ZAJP turbo said:ZSHO said:IMHO would not remove the rear valve cover on a temporary basis because there is a silicone/sealant holding it together so essentially you will have to remove the old sealant carefully and install new silicone/sealant and let it cure for a while and also need to torque down the bolts properly to oem specs. Z
You mean RTV?...nothing special its quite common...you realize dealer level mechanics slap it on and go and torque wrenches are rarely used....its a valve cover, clean the mating services and thoroughly degrease when applying rtv and dont over tighten the bolts since they are going into aluminum easy peasy...
